clay bar - MG-Rover.org Forums
post #1 of 14 (permalink) Old 08-02-2015, 15:46 Thread Starter
Car: MG ZR TD, MG ZS VVC
clay bar
Who's used what clay bars and from where? And what did you think about them? As I am thinking about getting one but don't just want to buy a crap one.
ben zr td is offline
post #2 of 14 (permalink) Old 08-02-2015, 15:56
I just got the Maguiars kit from Halfords to try. It was pretty good. It's surprising how gritty your paint work feels before you use it and how smooth it felt afterwards. If you've never done it before, give it a go.
http://www.halfords.com/motoring/cle...rface-clay-kit
Fast Guy is offline
post #3 of 14 (permalink) Old 08-02-2015, 16:44
+1 for the meguires, its conveniant, reasonably priced and is availible at most halfords or motor save or anything like that, gives a good result too
i have moved onto dodo juice clay bars and clay lubricant, cannot say if it is any better or worse as it seems to do exactly the same job, only you get more clay and lube so lasts longer
also, meguires clay lube smells amazing (but not as good as the tyre gel lol) and i think i am right in saying the meguires clay comes with a very useful plastic case to keep the clay in
Furryroo is offline
post #4 of 14 (permalink) Old 08-02-2015, 17:00 Thread Starter
Thanks for the replies guys, so after it's clayed do you do anything after or is that it done and looking shiney?
post #5 of 14 (permalink) Old 08-02-2015, 17:03
what i do is:
-Wash
-Clay
-Wash again
-Dry
-Polish
-Pre wax
-Wax
claying your car will remove all traces of any previous polish or wax, leaving your paintwork open to the elements, at the very least i would apply a good polish like auto glym super resin polish, or get some decent wax on there
Furryroo is offline
post #6 of 14 (permalink) Old 08-02-2015, 17:23 Thread Starter
All I've ever done to a car before is wash it and the odd bit of t cut, what products do you recommend etc??
post #7 of 14 (permalink) Old 08-02-2015, 17:55
Wash: Meguires ultimate wash and wax (the yellow stuff) is what i use, purists will say that wash and wax in one doesnt work, but i have used it for years without issue
Clay: Meguires or dodo juice, both are just as good and cost about the same (same for lube)
Dry: I use a large sillicone car squeegee to remove large water droplets, then a large microfiber car towel to dry the car completely to make sure there are no watermarks! got both from the car section in ASDA
Polish: Auto Glym Super Resin Polish all the time, have not found a car polish that comes close to this stuff
Pre wax: Dodo juice Lime Prime (with the micro abrasives) helps to remove small scratches and also polishes, bonus is it can also be used with a machine polisher for better scratch removal
Wax: Dodo juice orange crush, it has some sort of oil in it that really deepens the gloss of the car, is also easy to apply!
Aftercare: after each wash thereafter i spray the car with meguires ultimate detailer spray, brings the car back up to shine and protects the wax layers
Results are pretty good i think:
(sorry for shameless showing off lol)
Furryroo is offline
post #8 of 14 (permalink) Old 08-02-2015, 18:16 Thread Starter
Wow that looks awesome, mines a mk1 blue so should look good
However I do work on a steel works where my car gets very dirty would it make it easier to clean all the crap off from there aswell then??
post #9 of 14 (permalink) Old 08-02-2015, 18:37
Always wash the car before claying it, this will remove any loose dirt or dust and will stop the clay bar from becoming unusably dirty in seconds, the clay is there to remove dirt that has embedded itself into the clear coat, such as industrial fallout, brake dust and the like (yes you can clay your wheels, but do these AFTER the bodywork, then discard the clay bar after)
Also, a few rules
1 - DO move the clay bar in streight lines in the direction that air would move over the car (i.e. from front to back)
2 - DO NOT move the clay bar in circles
3 - DO NOT drop the clay bar, if you do, bin it
4 - DO use plenty of lube
5 - DO giggle like a schoolgirl whenever "Lube" is mentioned
6 - DO fold the clay inwards when it becomes dirty on one side
7 - DO wash your hands before using the clay
8 - DO soak the clay in clean, warm water to soften it
once an area has been clayed, run your (clean!) fingers over the surface, it should feel as smooth as glass, if it does not, then send the clay over it again and again until it does
Furryroo is offline
post #10 of 14 (permalink) Old 08-02-2015, 18:49 Thread Starter
Cheers for all the advice I'll write it all down along with my shopping list
post #11 of 14 (permalink) Old 08-02-2015, 18:56
Car: MG ZT400 SE,MG SV-R, MG RV8, MG ZT-T AWD, MGF 1.8i & MG6 Magnette
First time I clawed my MG ZT400. I thought, will this make any difference.....was amazed with the results!-used Autoglym and did one half of the boot lid first-was so smooth that the cloth just slid straight off it!
john newey is offline
post #12 of 14 (permalink) Old 10-02-2015, 22:03
you clawed your car? god can only imagine the length of your toe nails. Try bilt hamber its by far the best and you only need water as lube
frazeb is offline
post #13 of 14 (permalink) Old 21-02-2015, 06:34
Car: MG ZT 200 Celestial
If you like the Farecla G3 kit, they now do a clay mitt for around 12 which they claim can be machine washed and will last ages.
I'm sceptical as once you've used it the contaminants will be in the mitt, so if you used it again surely you'd be scraping over your panels with whatever's in the mitt?
Canonite is offline
post #14 of 14 (permalink) Old 04-04-2015, 08:02
Did you end up getting a clay kit ben? me and lehman got a meguirs one a while back & it was good,could do with getting another as my paint feels like sandpaper
lewis_ztd is offline
Clay bar! tommyd007 MG ZR / Rover 25, 200 & Streetwise 7 07-08-2012 21:10
clay bar northernbeasle MG ZR / Rover 25, 200 & Streetwise 6 19-04-2012 02:51
The sky was clear so i pulled out the clay bar clay bar clay bar! kev321 MG ZR / Rover 25, 200 & Streetwise 20 02-02-2012 14:33
Clay Bar alexward Car Care & Detailing Forum 4 17-11-2008 09:22
Got my first clay bar! Dr Dave Car Care & Detailing Forum 9 27-12-2006 05:13
