25 TD temp gauge sensor - MG-Rover.org Forums
post #1 of 3 (permalink) Old 01-01-2017, 21:20 Thread Starter
Hi all,
Has anyone managed to change their temperature sensor without dropping the alternator out of the way? If so, how the hell did you do it? There's no room for my fat hands.
Cheers,
Scott
Turner261183 is offline
post #2 of 3 (permalink) Old 11-01-2017, 16:19
Originally Posted by Turner261183 View Post
Hi all,
Cheers,
Scott
I have the same problem, but more importantly I had a minor leak between the elbow and cylinder head. You can remove the elbow by jacking up the engine and swinging the alternator forwards, it is not easy, but can be done. You need to loosen the long alternator pivot bolt, but that is not too bad to do. I did it whist changing the cam belt and did not have the sensor.
Re removing the sensor in situ, not sure but I suspect you can, if not as above you can do it by removing the elbow but you need the rubber gasket first.
O ring-cylinder head coolant o - Genuine MG Rover at www.rimmerbros.co.uk
My temperature gauge has started working again after about a year of not working.
Bunny_Brain is offline
post #3 of 3 (permalink) Old 12-01-2017, 06:58
Also bear in mind there are two different setups in terms of alternator placement depending on whether the car has aircon or not. The later cars all had the aircon setup (even if they didn't have aircon), which from memory makes fitment even more tricky.
TF oil temp sensor/gauge tAgC MGF and MGTF (Sponsored by MGFnTFBITZ) 10 07-01-2013 17:53
temp gauge sensor zrover MG ZR / Rover 25, 200 & Streetwise 2 07-08-2011 15:07
Where do I find the temp gauge sensor? dangerousdavec MGF and MGTF (Sponsored by MGFnTFBITZ) 3 07-05-2011 08:01
rover 100 temp gauge sensor gator Metro / Rover 100 1 04-05-2009 20:33
where is temp gauge sensor jctyson MG ZR / Rover 25, 200 & Streetwise 1 02-12-2008 14:30
