changing rear brake pads - MG-Rover.org Forums
post #1 of 5 (permalink) Old 29-07-2012, 01:40 Thread Starter
Car: Citroen Dispatch Van
just a quick one really my rear brake pads are down to metal. going to be changing them tomorrow, will i need a wind back tool?
thanks
dudarus1 is offline
post #2 of 5 (permalink) Old 29-07-2012, 01:41 Thread Starter
forgot to say its on a zr 115
dudarus1 is offline
post #3 of 5 (permalink) Old 29-07-2012, 07:51
Car: Focus tdci
i used a screwdriver.
Torkenstine is offline
post #4 of 5 (permalink) Old 29-07-2012, 20:42
I use a bit of flat bar. They need to be wound back in not pressed back in.
post #5 of 5 (permalink) Old 30-07-2012, 11:08
Car: MG ZS TD 115+
Yep i just did this at the weekend, the piston has a large cross in the face, use a steel ruler or somthing to turn them clockwise.
Also remember to slacken the handbrake adjuster back to its stop (a nut on the back of the actual handbrake) and readjust once the job is finished.
If the pads really are down to metal then you will need new discs too!
Sean 220 is offline
Changing Brake pads!! mini-maddog MG ZR / Rover 25, 200 & Streetwise 6 07-10-2010 17:21
Changing brake pads on a 25. alamb200 MG ZR / Rover 25, 200 & Streetwise 6 27-11-2008 16:21
Changing the brake pads boyracer 46 MGF and MGTF (Sponsored by MGFnTFBITZ) 9 04-10-2007 14:26
changing brake pads Cyer_ricki MGF and MGTF (Sponsored by MGFnTFBITZ) 5 01-06-2006 07:57
Changing Brake Pads evian MG ZR / Rover 25, 200 & Streetwise 8 05-06-2004 17:33
