Clutch pedal high - possible adjustment? - MG-Rover.org Forums
post #1 of 7 (permalink) Old 21-03-2011, 17:24 Thread Starter
Car: Rover 200 SDi
Hi all,
Ever since I have had my 22sdi it's always had a high clutch pedal which often makes pulling off a little jerky which is rather annoying. Is there any adjustments that can be made to help?
Cheers,
BarHopper
barhopper is offline
post #2 of 7 (permalink) Old 21-03-2011, 20:14
Car: ZS+ MKII TD
Someone sells an adjustment kit on here, bet he'll be on in a few mins. I think they are for the 400/45/ZS tho, not sure about your model.
crizd is offline
post #3 of 7 (permalink) Old 21-03-2011, 21:11
Car: 53 MG ZT-T CDTi
AFAIK 400/45/ZS have hydraulic clutches, 200/25/ZR have cable clutch.. could be due a new clutch cable?
I could be wrong
Shuntis is offline
post #4 of 7 (permalink) Old 21-03-2011, 21:52
If it was low it'd need a clutch cable. High clutch cable may just need resetting (its self adjusting I think).
post #5 of 7 (permalink) Old 23-03-2011, 10:34 Thread Starter
Car: Rover 200 SDi
I will have a look at the weekend, I have never had a good look at the cable so will see what I find. Would be nice if I could make an adjustment only if it was a very minor change. It drives me nutty at times lol.
post #6 of 7 (permalink) Old 24-03-2011, 21:30
The clutch cable casing on mine was starting to fail and causing the pedal to feel sticky at points so I got a new cable .When you have removed the old cable there is a bolt with a lock nut on just above the pedal box that can be adjusted to lower the pedal then attach the new cable and it will set itself and your pedal will be lower.
dazzer75 is offline
post #7 of 7 (permalink) Old 24-03-2011, 22:41
Car: trophy
i done mine with out touching the bolt at the top dammmmd bolt pinged off
adamkdeejay is offline
Clutch pedal adjustment cult88 MG ZS / Rover 45 & 400 6 24-06-2009 09:35
CLutch pedal adjustment Bubble_jon MG ZR / Rover 25, 200 & Streetwise 1 19-07-2008 15:03
Clutch Pedal adjustment Paul M MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 30-07-2006 20:20
Clutch pedal adjustment?????? lancylass Others 0 07-05-2005 10:27
ZR clutch pedal adjustment Philip40 MG ZR / Rover 25, 200 & Streetwise 1 01-11-2004 19:11
