Common Diesel Faults - FAQ here - MG-Rover.org Forums
post #1 of 14 (permalink) Old 17-11-2006, 21:11 Thread Starter
This is a thread designed to give owners information for some of the more common problems shared between drivers.
If you have a problem and need information it could be in here.
Alternatively, if you have had a problem and have fixed it, please private message me with information and i will post it up.
Any information is welcome, no problem to big or too small!
Regards Stu C
Stu C is offline
post #2 of 14 (permalink) Old 17-11-2006, 21:12 Thread Starter
Member - Kamal
Loss of boost/performance is also a symptom of a split intercooler hose.
Stu C is offline
post #3 of 14 (permalink) Old 17-11-2006, 21:13 Thread Starter
Member - SDI_TIM
Check engine light comes on and severe lack of performance above 2000(ish) rpm = chafed wiring to the needle lift sensor on injector number 1, or dirty/faulty sensor
Stu C is offline
post #4 of 14 (permalink) Old 17-11-2006, 21:14 Thread Starter
Member - SDI_TIM
Car revs to 1250rpm, accelerator pedal makes no difference = faulty throttle position sensor (TPS)
Stu C is offline
post #5 of 14 (permalink) Old 17-11-2006, 21:14 Thread Starter
Member - SDI_TIM
Check engine light comes on and engine revs erratically - check crank position sensor (CPS) and its wiring
Stu C is offline
post #6 of 14 (permalink) Old 17-11-2006, 21:15 Thread Starter
Member - SDI_TIM
Car hits a brick wall when accelerating hard, especially in 3rd/4th/5th - boost cut activated. Either faulty MAP sensor reporting boost too high (most likely if if untuned), or boost set too high (more likely if tuned) = lower boost by adjusting turbo wastegate actuator.
Stu C is offline
post #7 of 14 (permalink) Old 17-11-2006, 21:15 Thread Starter
Member - SDI_TIM
On older models e.g. the bubble 200's/400's/600's - car is sluggish, no excess smoking from exhaust = check brake light bulbs, check brake switch operation, check for chafed wires in tailgate for chafing causing shorting out of the brake circuit.
Stu C is offline
post #8 of 14 (permalink) Old 17-11-2006, 21:16 Thread Starter
Member SDI_TIM
Car is a nightmare to start, smokes a bit after starting, and then runs fine all day - check fuel pump timing (known to happen on older intercooled models e.g. 200/400/600 DI/SDIGSDI)
Stu C is offline
post #9 of 14 (permalink) Old 17-11-2006, 21:16 Thread Starter
Member SDI_TIM
Difficult starting from cold, runs lumpy for a few seconds with some smoke, fine after that, worse in cold weather = check glow plugs, relay and power feed connections. Also, coolant temperature sensor sends signal to ECU, which decides if glow plugs are needed.
Alternatively - fuel leak, check fuel pipes and connections in engine bay, possibly faulty priming bulb
Stu C is offline
post #10 of 14 (permalink) Old 17-11-2006, 21:16 Thread Starter
Member - SDI_TIM
Car jerky at light throttle/steady speed, no problem when accelerator pushed down a bit more = slightly sticky EGR valve. Clean valve, try an induction system cleaner e.g. 10K boost, or disconnect electronic control plug to disable EGR.
Stu C is offline
post #11 of 14 (permalink) Old 17-11-2006, 21:17 Thread Starter
Member - Ursus 2
Watch the air con pipe near the air box filter ,posible wear of this pipe by the rub against this box
Stu C is offline
post #12 of 14 (permalink) Old 17-11-2006, 21:17 Thread Starter
Member - Rovernaut
On the Intercooled Engine. The Engine Speed Governor Sensor and the Fuel Temperature Sensor are integral to the Fuel Injection Pump. If Diagnostics flag up either of these and you have limited performance. It's bad news I'm afraid. You will need a replacement pump. BUT YOU MUST set up the pump, as in the Haynes Manual, BEFORE you remove it.
Stu C is offline
post #13 of 14 (permalink) Old 17-11-2006, 21:18 Thread Starter
Member - Mad
Came across this yesterday after a ic blew again. If you're having problems getting the car to rev at all from a cold start, there is a boost problem or egr problem, dont ask me whyy but it happens, the car wont rev for maybe 30 secs or so.
Stu C is offline
post #14 of 14 (permalink) Old 15-04-2009, 16:56 Thread Starter
Hi guys, if anyone else has any great tips for this list, drop me a PM and ill add it up for you all
Stu C is offline
Closed Thread
ZT Common Faults? 673NN MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 18-01-2009 13:40
Common Diesel Faults Pol Rover_ron MG ZT / Rover 75 (Sponsored by Rimmer Bros) 10 20-11-2008 07:06
MGF/TF FAQ Please give me some common issues so we can set this up. cjmillsnun MGF and MGTF (Sponsored by MGFnTFBITZ) 58 27-02-2007 16:05
R75 Common faults ROB75 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 26-04-2006 20:40
420 common faults johnthemilk Others 11 05-01-2003 19:37
