Coolant tank - tips on how to clean inside - MG-Rover.org Forums
post #1 of 5 (permalink) Old 27-02-2017, 21:34 Thread Starter
Ed3
On a 2.0 TD L series I started to clean the general sludge that builds up over the years from inside the coolant header tank and find it difficult to clean as there are compartments within the coolant tank. I can rub the sludge off what I can reach. But cannot reach much. Has anyone successfully cleaned up one of these tanks?
Ed3 is offline
post #2 of 5 (permalink) Old 27-02-2017, 21:49
Car: MG TF 135, MG ZS+ 120
Hot water and a dishwasher tablet. Leave to soak, then empty and repeat. A magic eraser sponge stuffed inside while violently shaking helps. Try using a bent skewer to poke the sponge around inside. If your tank is from a 45/ZS then it won't be possible to clean all of the tank due to its compartments but a combination of the above steps should get close.
LeRich is offline
post #3 of 5 (permalink) Old 27-02-2017, 22:33
water and pea gravel works wonders
Andy400 is offline
post #4 of 5 (permalink) Old 17-05-2017, 12:45
Also a bloomin good shake with a handful of dry rice in with the dishwasher solution. It can take a while to get all the grains out, but it is effective.
mrvandango is offline
post #5 of 5 (permalink) Old 17-05-2017, 20:29
Pea gravel as above is what I use. Make sure you get it all out though!
How to clean gunk from coolant pipes/tank/rad? (R25/HGF) replete MG ZR / Rover 25, 200 & Streetwise 23 16-02-2014 23:22
Clean inside of headlight 4743hudsonj Car Care & Detailing Forum 8 08-09-2011 03:34
whats a good way to clean the inside of a coolant box after a SHG blow? GoldDragon MG ZR / Rover 25, 200 & Streetwise 1 28-07-2011 19:46
Got bored ... decided to clean the inside igundwane MG ZS / Rover 45 & 400 13 24-05-2011 12:45
Best way to clean coolant tank... Keefo MG ZR / Rover 25, 200 & Streetwise 12 14-02-2010 09:59
