EGR gaskets - MG-Rover.org Forums
post #1 of 11 (permalink) Old 02-11-2016, 13:58 Thread Starter
EGR gaskets
Hi Everyone
If I take my EGR off to see if it needs a clean. Haynes manual says to replace both gaskets. No idea where to get them, so would I be ok once, just putting it back as is?
Seem to remember removing one on a astra once, sure I just put it straight back on
Sent from my iPhone using Tapatalk
Chris.mas87 is offline
post #2 of 11 (permalink) Old 02-11-2016, 16:08
If they come off intact then they are fine to re-use in my experience.
If they get damaged then you either use gasket goop or find another one to replace it.
post #3 of 11 (permalink) Old 02-11-2016, 16:09 Thread Starter
What material are they? And where could I get them if needed?
post #4 of 11 (permalink) Old 02-11-2016, 22:50
Rover 600 Inlet/Exhaust Manifolds - 2000 Diesel from BM246797 at www.rimmerbros.co.uk
19 which is fibre/cardboard but can be replaced with silicone if needed.
14 is a bit more substantial and is cardboard with a metal fire ring in it.
post #5 of 11 (permalink) Old 02-11-2016, 22:54 Thread Starter
Thank you, so would be one of each? Guess I could see the condition of the gaskets in place at the moment first?
post #6 of 11 (permalink) Old 03-11-2016, 13:04
Chances are you'll be able to re-use them. If the intake manifold gasket rips then use some silicone on it - it'll be fine.
I've not replaced one yet anyhow!
post #7 of 11 (permalink) Old 06-11-2016, 09:39
I re-used mine.
Bunny_Brain is offline
post #8 of 11 (permalink) Old 06-11-2016, 10:12 Thread Starter
I can't get it off? The back bolt on the cooler, there is a big pipe in front and I can't get te socket in there.
Any ideas how I could?
post #9 of 11 (permalink) Old 06-11-2016, 11:19
Mine are 6mm caphead bolts, so I used allen keys.
post #10 of 11 (permalink) Old 06-11-2016, 11:30 Thread Starter
Yeah thats them. The ones going into the manifold are bolts.
Even with allen keys, could you reach the back one? There is a thick black pipe that goes front to back across the engine. Found this really restrictive
post #11 of 11 (permalink) Old 07-11-2016, 08:01
I've never needed to remove the metal intercooler pipe but you can do so if needed. It is just a couple of jubilee clips and one bolt or is it two?
MG ZR 1.4 gaskets. elleppahc MG ZR / Rover 25, 200 & Streetwise 3 31-10-2013 22:22
Gaskets toX MG ZR / Rover 25, 200 & Streetwise 1 19-10-2013 11:17
Gaskets Dan Coupe Diesel Forum! 12 08-06-2013 10:15
gaskets Dan200 MG ZR / Rover 25, 200 & Streetwise 1 13-03-2012 10:37
Gaskets charlie214si Others 3 07-02-2005 15:25
