How to fit a boost gauge (R25) - Page 2 - MG-Rover.org Forums
post #21 of 109 (permalink) Old 27-01-2007, 16:02 Thread Starter
Car: MGZT pbt derv
Originally Posted by GazEaton View Post
Just been out to my car to look for this green pipe, found the green pipe from the inside but cant find it on the engine bay side.
Rover 25 mine is, so aint sure if it's the same as the pictures taken...
Also, when comig to fit a gauge, is it easier to fit with it in the air?
Look around the back of the engine for the turbo actuator, the green pipe will be coming out of the fire wall near that area.
The photo's are from my own Rover 25.
Skelo
P.S
Don't quite understand this comment, have you been drinking the antifreeze???
Dave is offline
post #22 of 109 (permalink) Old 27-01-2007, 16:06
Car: R25 TD
Send a message via MSN to GazEaton
Are the photos from under the car?...
GazEaton is offline
post #23 of 109 (permalink) Old 27-01-2007, 16:11 Thread Starter
Car: MGZT pbt derv
Juist added you on MSN.
The pics are from the top of the engine, (bonnet open)
Cheer
Skelo
Dave is offline
post #24 of 109 (permalink) Old 13-02-2007, 20:57
Car: rover 75 club cdt
Send a message via MSN to ramdonice Send a message via Skype™ to ramdonice
just bought a boost gauge for my diesel goes upto 30psi http://cgi.ebay.co.uk/ws/eBayISAPI.d...6340&rd=1&rd=1
ramdonice is offline
post #25 of 109 (permalink) Old 15-02-2007, 12:17
got my boost gauge today
the thing is i have an non intercooled diesel 400 and i can find the maf senser, dose my have one if not were to i connect it to
post #26 of 109 (permalink) Old 09-03-2007, 12:21
Car: R25 TD
i've jsut bought a gauge... how easy is it to fit in place?... i'll hopefully looking to get it mounted in an A pillar. and also for a power source
GazEaton is offline
post #27 of 109 (permalink) Old 14-03-2007, 20:21
Car: MG ZS+ TD135+
In answer to Skelo's earlier quesiton, Rover quote the boost as 1.2 bar (17.4psi) for the newer L series in the 25/45/ZR/ZS diesels, and from memory it's 1 bar (14.7psi) for the older L series found in the 200/400/600
SDI_Tim is offline
post #28 of 109 (permalink) Old 16-03-2007, 23:11
cool , but i need to tweek the actator , firstly what is it where is it what does it look like and what do i turn before killing my engin 1800 td with 200k on the clock
LLOYDY is offline
post #29 of 109 (permalink) Old 04-10-2007, 19:06
Send a message via MSN to zijnstra
Originally Posted by Skelo View Post
hi,
Im trying to find this location to fit my new boost gauge on my 25 IDT but cant find it at all!!!
pls help me out.
grtz from Holland
zijnstra is offline
post #30 of 109 (permalink) Old 05-10-2007, 09:14
Car: 45 2.0 Diesel
Originally Posted by zijnstra View Post
hi,
pls help me out.
grtz from Holland
Thats the MAP sensor. The picture is at a funny angle, on my R45 it is in the middle of the engine bay, at the top, at the back.
Chrisund123 is offline
post #31 of 109 (permalink) Old 05-10-2007, 12:37
Smile
yes now I reconise it! thnx!! its the strange angle that makes it hard to find
zijnstra is offline
post #32 of 109 (permalink) Old 05-10-2007, 14:28
the boost gauge gives only 0.5 bar (7 PSI) at most, is this normal??? Ive read the diesel can handle 1.4 bar (20 Psi) easely
zijnstra is offline
post #33 of 109 (permalink) Old 05-10-2007, 15:43 Thread Starter
Car: MGZT pbt derv
Have you adjusted the actuator?
If you have, then you probably have a split intercooler hose.
Skelo
Dave is offline
post #34 of 109 (permalink) Old 06-10-2007, 07:01
Car: 45 2.0 Diesel
yep, you're losing the boost somewhere!! Do you get lots of smoke when you put your foot down?
Check the actuator linkage is connected up OK, and take the hoses off and look for splits. Get an assistant to hit the accelerator while you snoop in the engine bay and look/listen/feel for an air leak.
post #35 of 109 (permalink) Old 06-10-2007, 14:23
I didnt adjust the actuator, and there are no split hoses also.
and no black smoke when hitting the pedal. and the car drives fantastic!
maybe the gauge isnt working correct?? this is the one ive bought from SLM:
http://www.fullcartuning.nl/details....D=10&intMerk=0
zijnstra is offline
post #36 of 109 (permalink) Old 05-01-2008, 13:23
Ok, i have followed this guide just as per Skelo's pictures, but my guage is not reading anything!?!
Any suggestions on what could be wrong
As there any way i can test the guage off the car? Compressor i suppose
Ac100 is offline
post #37 of 109 (permalink) Old 05-01-2008, 16:45
Car: 45 2.0 Diesel
You should be able to move the gauge by blowing/sucking the pipe, this will tell you if the gauge works. If you leave the pipe connected to the turbo you can take the gauge off and see if there is air coming out of the pipe when you rev it.
post #38 of 109 (permalink) Old 06-01-2008, 16:49
I bought a Powertek kit from ebay, part of which was a t-piece. I didn't take the time to examine it, but the 'leg' of the t had a brass/bronze insert that reduced the diameter down to about 1mm - i think this was why there was no reading on the gauge.
Bought another t-piece and it all works fine
For anyone thats interested, a 05 ZR TD seems to produce 16psi as standard
Ac100 is offline
post #39 of 109 (permalink) Old 06-01-2008, 17:36 Thread Starter
Car: MGZT pbt derv
Nicely sussed out
Nice to see a good result, especially from somebody fairly local to me!!
Skelo
Dave is offline
post #40 of 109 (permalink) Old 06-01-2008, 18:17
thats suposed to be there. stops the needle buzzin.
lukes_r25 is offline
Boost gauge, boost controller and turbo timer. Cruizer Diesel Forum! 14 21-07-2008 23:21
boost gauge and boost controler Fearless_Phil Diesel Forum! 10 08-09-2007 08:46
Boost gauge fluctuates rapidly and advice setting peak boost kamal Diesel Forum! 6 06-04-2007 22:55
boost gauge help ramdonice Diesel Forum! 5 16-02-2007 01:48
boost gauge reading and boost controller RichMann 'R8' Rovers (aka Wedges!!) 10 10-10-2005 20:37
