How to fit a boost gauge (R25) - Page 3 - MG-Rover.org Forums
post #41 of 109 (permalink) Old 06-01-2008, 19:49
Originally Posted by lukes_r25 View Post
thats suposed to be there. stops the needle buzzin.
Good point.
Maybe i got a duff t-piece as there was a blockage in the body that i didn't notice either.
Now i've cleared that out, I think i will retry it to see if the needle buzz is prevented.
Ac100 is offline
post #42 of 109 (permalink) Old 08-01-2008, 16:05
Refitted the t-piece supplied with the kit after i cleared the blockage. Still getting no reading on the guage, so i think the insert is too restrictive
Ac100 is offline
post #43 of 109 (permalink) Old 15-01-2008, 21:46
Car: 525d, T4 & MG ZR and half a ZS
Tried this today and all I can say is, what a bugger to fit
Am I doing it wrong, fitting to controller and gauge then attach it to accuator and turbo "nipple"? with all pipes in way?
wayner007 is offline
post #44 of 109 (permalink) Old 15-01-2008, 22:08 Thread Starter
Car: MGZT pbt derv
Why not T peice to the MAP sensor, its how i did it. It works fine for me.
Skelo
Dave is offline
post #45 of 109 (permalink) Old 15-01-2008, 22:10
Skelo
Could do, but I have started so I will finish it will have a search for the map sensor location etc... and maybe take a look tomorrow.
post #46 of 109 (permalink) Old 15-01-2008, 22:12 Thread Starter
Car: MGZT pbt derv
The map sensor is on the bulkhead, roughly where the egr valve is on the engine.
Skelo
Dave is offline
post #47 of 109 (permalink) Old 15-01-2008, 22:21 Thread Starter
Car: MGZT pbt derv
Picture of where the MAP sensor is in my engine bay:
Hope this helps
Skelo
Dave is offline
post #48 of 109 (permalink) Old 08-12-2008, 15:24 Thread Starter
Car: MGZT pbt derv
Just a bump to the top, as i know a few newbies might find this guide handy
Dave
Dave is offline
post #49 of 109 (permalink) Old 08-12-2008, 18:15
Yeh after a while changed the boost gauge to the map sensor side much easier to fit. Good guide though, another bump.
post #50 of 109 (permalink) Old 09-12-2008, 19:49
Car: MG ZR+
great guide. i have a Noble boost gauge laying about i used it to ajust my boost. i might plumb it in. its just finding a good place to put it. ill av to av it so every1 can see my bit of noble. ill never aford the whole car.
T.Morris is offline
post #51 of 109 (permalink) Old 18-12-2008, 19:44 Thread Starter
Car: MGZT pbt derv
Could buy it bit by bit
Dave
Dave is offline
post #52 of 109 (permalink) Old 18-12-2008, 19:51
Car: MG ZR+
Haha. My m8s building his own its better than Lee Nobles. he builds um and races um for noble so he nows wots good so he decided to make his own its orsum
T.Morris is offline
post #53 of 109 (permalink) Old 26-01-2009, 20:10
Car: MG-ZR
Help
Hi guys, quite new to this sorta thing, i mean not totally into doing car work my self, BUT i would like info poss pics on how to up the turbo to as many people have said (19/20) psi. just dont fancy paying big store prices for mechanics to look at it for me as my GF is expecting and need to do with as little spent as poss, hope you can help. cheers
Rabbeye is offline
post #54 of 109 (permalink) Old 11-08-2009, 07:12
Would this guide be same for 2004 zs?
Just bought a boost gauge and doing bit of research on fitting.
newryzs is offline
post #55 of 109 (permalink) Old 11-08-2009, 21:53
Originally Posted by GazEaton View Post
Just been out to my car to look for this green pipe, found the green pipe from the inside but cant find it on the engine bay side.
Rover 25 mine is, so aint sure if it's the same as the pictures taken...
Also, when comig to fit a gauge, is it easier to fit with it in the air?
Mate you really dont need car off ground to fit gauge and you dont need to use the same hole in fire wall just shove pipe though anywhere you can get it mines piped through behind glove box ( cut through tear shaped grommet).
Nice guide BTW wish it had been up when i fitted mine.
blaconbomber69 is offline
post #56 of 109 (permalink) Old 11-08-2009, 22:30 Thread Starter
Car: MGZT pbt derv
Take a look behind the engine, against the body/turbo charger area. You should then see the green pipe/cable.
Dave
Dave is offline
post #57 of 109 (permalink) Old 12-08-2009, 10:55
what a guy
Car: Mercedes CLK, Classic Mini, Streetwise TD, ZR Trophy 160, Volvo 244
any ideas how to wire it in to the headlights? eg. when the headlights are turned on, the gauge lights up? I'm sure I could work it out but I'd probably end up either ruining my lights or going about it really long winded way lol.
cheers
Ben
Benny Dub is offline
post #58 of 109 (permalink) Old 12-08-2009, 15:35
Send a message via MSN to R3NN3R
cheers
Ben
I piggy-backed on to the lighting cables that provide the headlamp levelling switch light on the right hand side of the dash. It took seconds to fit.
Dave
R3NN3R is offline
post #59 of 109 (permalink) Old 12-08-2009, 16:09
what a guy
Dave
thats cool, I was thinking something along those lines. Not too hot with the wiring/routing of things dude, fancy giving me a hand with it lol?
post #60 of 109 (permalink) Old 12-08-2009, 16:21
when fiiting the t piece, do u just cut that pipe coming out from under the map sensor? any idea where i could get the tubing through a zs firewall?
newryzs is offline
Boost gauge, boost controller and turbo timer. Cruizer Diesel Forum! 14 21-07-2008 23:21
boost gauge and boost controler Fearless_Phil Diesel Forum! 10 08-09-2007 08:46
Boost gauge fluctuates rapidly and advice setting peak boost kamal Diesel Forum! 6 06-04-2007 22:55
boost gauge help ramdonice Diesel Forum! 5 16-02-2007 01:48
boost gauge reading and boost controller RichMann 'R8' Rovers (aka Wedges!!) 10 10-10-2005 20:37
