How to fit a boost gauge (R25) - Page 5 - MG-Rover.org Forums
post #81 of 109 (permalink) Old 26-05-2011, 15:42
Car: ****roen Saxo
Done it
Fitted my boost gauge today as I had adjusted the boost a few weeks ago but didnt notice any difference. Turns out I'd turned the boost down. What a nob!!!
All working now and temp mounting in the ashtray on my 600.
Does anyone know if any pods made fit the 600 a pillar?
simondhopkins is offline
post #82 of 109 (permalink) Old 30-05-2011, 21:03
I've recently plumbed in m Garrett style gauge using your method, no problems until it came to wiring. The wiring instructions given with the device say it was a 3 wire device, one goes to 12 lights, on earth and one to ignition, I'm pretty lose here, was hoping to tap into the headlight height adjustement switch as mentioned before, this is 3 wire again but im a bit lost with it all really. whats the best route? The gauge is mounted in a homemade FG pod to the right of the steering wheel, in where the stationary vent is.
RossSherwood is offline
post #83 of 109 (permalink) Old 30-05-2011, 21:06 Thread Starter
Car: MGZT pbt derv
I've got the Garret boost gauge from GBE, and have only used 2 of the 3 wires. So i have earth, and a light feed from one of the switches, for when i put the lights on.
Dave
Dave is offline
post #84 of 109 (permalink) Old 30-05-2011, 21:10
Ah so the ignition one is not needed? How do you tap into the headlamp leveling switch? It's not connector block if i remember? Sorry im new to car wiring completely
post #85 of 109 (permalink) Old 30-05-2011, 21:59 Thread Starter
Car: MGZT pbt derv
I have my gauge in the centre air vent, so i scotch locked into the earth, and lighting wires of one of the switches. I used black wire to black wire, and red (from the gauge), onto a red/black wire of the switch.
Dave
Dave is offline
post #86 of 109 (permalink) Old 21-06-2011, 18:43 Thread Starter
Car: MGZT pbt derv
Thought i'd bump this up, not seen it in the list for ages.
Dave
Dave is offline
post #87 of 109 (permalink) Old 18-10-2011, 13:22
Send a message via MSN to RickZRTD
BUMP For a very handy guide
RickZRTD is offline
post #88 of 109 (permalink) Old 18-10-2011, 16:33
mad
Car: mg zr t16 mk2, mad r25 td, anni golf tdi, mondeo st tdci
Send a message via MSN to mad
yea why is this not stickied. Weres the moderators.
mad is offline
post #89 of 109 (permalink) Old 18-10-2011, 16:55 Thread Starter
Car: MGZT pbt derv
It used to be a sticky ages ago, then some mod/admin in there wisdom decided to 'un' sticky it.
Cheer
Dave
Dave is offline
post #90 of 109 (permalink) Old 19-10-2011, 12:21
Car: 2006 MG ZR 2.0TD
Since this is back up on the list, and I was reading through some posts I remembered something. A friend of mine had one of them 1.5DCi Renault and he had a boost gauge installed. It never occured to me until now that he was actually running 29psi boost on that thing. It's been discussed a few times on the forum that 19psi is the safe limit. So do you guys think its because of the very small turbo the Renault has or was he just lucky that it never gave in?
Zack is offline
post #91 of 109 (permalink) Old 19-10-2011, 23:00
Car: MG ZR160
hes just lucky. iirc those turbos are smaller than a gt15 and wouldve been suffering stupid heatsoak at that pressure
Popeye 89 is offline
post #92 of 109 (permalink) Old 19-10-2011, 23:05
Diesel Tuning Dude
Dakta's Avatar
excessive backpressure and turbine/shaft speeds too.
Turbos can take a bit of abuse but I bet it would have given up eventually.
Dakta is offline
post #93 of 109 (permalink) Old 08-03-2012, 18:42
Car: MG ZS MK2 DIESEL
Heres my boost gauge that i fitted today i had to butcher the dial surround but i think it looks quite good
[IMG][/IMG]
I had a pod that came with the gauge so i used that to put in the slot i cut out of the surround, i put some glue underneath to hold it in place.
[IMG][/IMG]
All in all im very happy with it
I put the tpiece in at the map sensor and i think my car is running at 17psi but i havnt had it on a motorway yet so not going to adjust the actuator just yet until ive had a good motorway run to get a better reading.
BenZS is offline
post #94 of 109 (permalink) Old 17-02-2013, 22:01 Thread Starter
Car: MGZT pbt derv
Think this thread should be stickied, its a common mod, so makes it easier for folks to find.
Dave
Dave is offline
post #95 of 109 (permalink) Old 01-03-2013, 08:18
Car: zs saloon td x power in goodwood green
Quick question. If i do plumb it into the map sensor does it still read vac pressure or just boost pressure?
Glen
05ZR is offline
post #96 of 109 (permalink) Old 01-03-2013, 08:30
Car: MK2 ZS TD
Glen
Just boost, there shouldnt be vacuum on a diesel..
Chaz is offline
post #97 of 109 (permalink) Old 01-03-2013, 09:17
LOL, thats me told then. Cheers bud
05ZR is offline
post #98 of 109 (permalink) Old 01-03-2013, 09:54
Car: MG ZR Express Derv
Any ideas why my gauge sits at 2 psi? Installed yesterday and it works fine. When unplugged it reads 0 after a run it stays at 2.....
Leigh_EvoIX is offline
post #99 of 109 (permalink) Old 01-03-2013, 12:56
Usually a sign of a cheap gauge I'm afraid.
post #100 of 109 (permalink) Old 01-03-2013, 14:47
Yea, it's one of the 30 halfords jobbies. Came with the car. I took it out when I first got her home. Now I've added the SDIs etc I reinstalled it so I could check boost. Does the job. Just doesn't go back to 0.
Boost gauge, boost controller and turbo timer. Cruizer Diesel Forum! 14 21-07-2008 23:21
boost gauge and boost controler Fearless_Phil Diesel Forum! 10 08-09-2007 08:46
Boost gauge fluctuates rapidly and advice setting peak boost kamal Diesel Forum! 6 06-04-2007 22:55
boost gauge help ramdonice Diesel Forum! 5 16-02-2007 01:48
boost gauge reading and boost controller RichMann 'R8' Rovers (aka Wedges!!) 10 10-10-2005 20:37
