How to fit a boost gauge (R25) - Page 6 - MG-Rover.org Forums
post #101 of 109 (permalink) Old 03-04-2013, 21:41
Car: ZR TD Trophy SE 115
Finally got round to 90% fitting my boost gauge (still have to feed the pipe through to the engine) For all the wiring i jus wired it up2 my cd player. works perfectly. thanks for all the info on this thread, was a big help....
MaxpowerIreland is offline
post #102 of 109 (permalink) Old 04-04-2013, 21:14 Thread Starter
Car: MGZT pbt derv
Looks great, almost as if MGR knew to make the vents the right size for a gauge!!!
Dave
Dave is offline
post #103 of 109 (permalink) Old 12-04-2013, 20:42
Car: Mk2 ZR TD
Anybody got a link to a good gauge they are using?
skinny--g is offline
post #104 of 109 (permalink) Old 12-04-2013, 20:56 Thread Starter
Car: MGZT pbt derv
I use this one HERE
Not cheap, but deadly accurate i find.
Dave
Dave is offline
post #105 of 109 (permalink) Old 12-04-2013, 21:02
Car: Mk2 ZR TD
thats a reasonable price though
rather pay that for a good one than 25 of fleabay for one that dies after a month
post #106 of 109 (permalink) Old 12-04-2013, 21:56 Thread Starter
Car: MGZT pbt derv
I've had cheap crap gauges from ebay, total waste of money in my opinion.
Dave
Dave is offline
post #107 of 109 (permalink) Old 12-04-2013, 21:56 Thread Starter
Car: MGZT pbt derv
I see you are in Holbeach, check out the east anglia section for regular monthly meets
Dave
Dave is offline
post #108 of 109 (permalink) Old 03-03-2014, 20:11
If anyone isn't sure what to use to mount the gauge:
Not sure if this will help but I thought I'd try using my pillar gauge holder from my golf, with a bit of trimming it wasn't too bad a fit. It costs about 32 from eBay if I remember rightly.
Scorponok is offline
post #109 of 109 (permalink) Old 26-05-2014, 23:50
Car: 238FDH
On my zs td i fed my boost hose through the heater cable grommit next to the clutch pedal. I now have a 45 td and i dont have this grommit. I think thats due to the 45 having air con.
After looking around on the internet a lot of people seem to get lost when fitting boost gauges. Like the isue i had, they cant find a way through the bulkhead due to no heater grommit so here's my 2p's worth-
Unscrew the 2 bolts holding the expansion tank in place. Move this to one side and put a hole through the large black rubber grommit.
Put a slim solid object through the boost hose as can be seen below.
I used a phillips drill bit-
Then feed the drill bit through the grommit and it will pop out just behind and above the fuse box like so-
Job done :-) Bolt the expansion tank in and fit the gauge.
This is how mine now looks-
Cheers, Dave
dave_6785 is offline
Boost gauge, boost controller and turbo timer. Cruizer Diesel Forum! 14 21-07-2008 23:21
boost gauge and boost controler Fearless_Phil Diesel Forum! 10 08-09-2007 08:46
Boost gauge fluctuates rapidly and advice setting peak boost kamal Diesel Forum! 6 06-04-2007 22:55
boost gauge help ramdonice Diesel Forum! 5 16-02-2007 01:48
boost gauge reading and boost controller RichMann 'R8' Rovers (aka Wedges!!) 10 10-10-2005 20:37
