Injector 3 leak off pipe. - MG-Rover.org Forums
post #1 of 7 (permalink) Old 13-08-2013, 23:44 Thread Starter
Car: ZR-T
As you look at the engine injector 3, the pipe that comes off the leak off pipes where do this go? Runs down the front of the block, is it a return? Mine has a pin hole in it and looks a right nall ache to change as i can't see where it goes
D
Deckz is offline
post #2 of 7 (permalink) Old 14-08-2013, 06:30
Car: rover 45 L series
it goes to
the return to the pump easy job matter of Seconds
magoguk is offline
post #3 of 7 (permalink) Old 14-08-2013, 08:12 Thread Starter
Car: ZR-T
How do I get the other end of it pal?
Deckz is offline
post #4 of 7 (permalink) Old 14-08-2013, 08:49 Thread Starter
Car: ZR-T
Sorted lol
Didn't see the other end was as easy to get at.
Deckz is offline
post #5 of 7 (permalink) Old 14-08-2013, 16:46
Happy days
glad your sorted :-)
magoguk is offline
post #6 of 7 (permalink) Old 14-08-2013, 18:10
Car: 2004 45 conni TD Saloon
New leak off pipes are on my TO DO LIST.
That's was the one that was worrying me too, so looking at what been said its a fairly easy job to change all 4 of them ?
What do I need to buy - is it worth changing to silicone hose and how much is needed ?
steve-45 is offline
post #7 of 7 (permalink) Old 14-08-2013, 18:26
Car: R45 TD
Silicone will go soft, and fall off/leak pretty rapidly
Just grab some leak-off pipe from ebay, cut to length, and push on May need to use a bit of effort to get the old ones off, as the rubber will have gone hard (I just use wire cutters to get them off)
Takes all of a minute to do the lot
Dastardly-Dan is offline
LHS Diesel Injector pipe wanted For 25 2.0L sti5300 Diesel Forum! 4 03-02-2013 22:56
possible injector leak?? skyrocket Diesel Forum! 15 30-09-2012 08:07
injector leak Torkenstine Diesel Forum! 11 12-04-2012 06:38
Leaking injector pipe saleen Diesel Forum! 5 22-04-2008 22:29
Injector pipe problems James420SDi MG ZS / Rover 45 & 400 6 20-12-2006 10:45
