L-series with over 200bhp already created... - Page 5 - MG-Rover.org Forums
post #81 of 297 (permalink) Old 21-11-2010, 20:06
Car: Clio 1.2dynamic
Send a message via MSN to kaz19880
sorry leymans terms please surely the turbo is run by the air in the exhaust or will this setup be using one of these smarty pants vnt setups that dont understand
kaz19880 is offline
post #82 of 297 (permalink) Old 21-11-2010, 21:31 Thread Starter
Car: ZS+ 170TD
When i said standard i meant hybrid standard
Either way it is certainly going to be interesting, how are you planning to deal with the inevitable torque steer with this setup then, as that is a fairly huge dollop of torque, and i am also making the assumption that it will have a lot of that big dollop available for more of the rev range than the hybrids.
I wait to read of the good results tho and keep my fingers crossed the car makes it through the 24hrs
p_b82 is offline
post #83 of 297 (permalink) Old 22-11-2010, 17:28
Adding a bigger turbo won't give you that huge torque spike as it'll be higher in the rev range and thus smoothed out a fair bit.
Hence my aims to keep the standard clutch.
post #84 of 297 (permalink) Old 22-11-2010, 17:35 Thread Starter
Car: ZS+ 170TD
Would not a VNT though cause this to happen as it spools and is a 'little turbo' down low and then becomes bigger as the revs\boost\magic increases?
I thought as a result it would have a similar quick spike, but the curve would be flatter for longer, thus holding more torque up to the rev range allowing for higher bhp as a result.
p_b82 is offline
post #85 of 297 (permalink) Old 22-11-2010, 17:47
Yes to some degree, sorry I was referring to a big normal turbo like mine.
A VNT will generate more boost lower down than a normal turbo which is why diesels have them pretty universally now.
post #86 of 297 (permalink) Old 22-11-2010, 18:35
Car: Audi
Send a message via MSN to pocketbikeuk
limited slip diff, we did look at equal length drive shafts but it was too much work.
pocketbikeuk is offline
post #87 of 297 (permalink) Old 22-11-2010, 19:14
Car: Rover 220 GTi diesel conv.
Anyone had a go in a sporty VAG TDi?
The power delivery is very different from a tuned L-series, it's very linear/progressive like the torque curve is flat across the powerband and a continuous wall of torque; like V8 in a way.
My same VAG mates have drove my ZS and comment that it feels faster as the torque initially comes in much stronger but fades away as the revs build, like a big surge.
I think I'd look at having the torque limited below 2500rpm to aid traction, so it's like now where it's around 240ftlb from 1800rpm. Also to take the strain off the driveshafts and gearbox. Alot of posts on tdiforum recommend nomore than 300ftlb @2000rpm to stop the transmission components suffering, and their gearbox is rated to 300ftlb in oem form! I'm sure the PG1 is rated at 180ftlb on the oem bearings!
Russ220 is offline
post #88 of 297 (permalink) Old 22-11-2010, 20:58 Thread Starter
Car: ZS+ 170TD
I guessed as much, using a Quaife or Torsen?
Sorry being nosey i know but i am really curious as to how it all turns out
that is one reason why i have left the the OE torque limiters in place on mine ( i have no idea if it is done of fuelling % of max or whether it is a set value) but it seems silly to munch the box by flooring it in those gears imo.....
I had hoped that the hybrid would be like how you describe, and it is is to a lesser exent, it still has more torque than standard at 4400 than we have at 2000
i think the rating was 195 with the uprated box as that was the OEM 115 map's max value..... tho originally it was probably a lot less than that!
p_b82 is offline
post #89 of 297 (permalink) Old 23-11-2010, 17:02
Car: Audi
Quaife lsd is what we have and straight cut gears may even go sequential eventually
post #90 of 297 (permalink) Old 26-11-2010, 08:14
Car: Audi
Just thought id add we are making a new inlet manifold now and intercooler piping kit so we will have a full diy install kit ready off the shelf so you can bolt on at home to save on costly garage bills. Also the price of the kits depends if you want stainless or mild steel manifolds and down pipe as the kit will be available in both.
post #91 of 297 (permalink) Old 26-11-2010, 08:43
this is getting better and better
Matt, if i was to bolt the kit on at home, how would i go about getting the mapping done? Is it a case of booking one of your agents to visit my car at home etc and have the new VNT map added?
cheers
Russ220 is offline
post #92 of 297 (permalink) Old 26-11-2010, 09:14
Car: Audi
cheers
this would be the ideal case yes.
post #93 of 297 (permalink) Old 26-11-2010, 10:20
Have you go a rough idea of the prices of the kits yet mate?
Im sure you have quite a few interested members
Catterall1 is offline
post #94 of 297 (permalink) Old 26-11-2010, 10:45
Car: Audi
not yet but not too far off knowing
post #95 of 297 (permalink) Old 26-11-2010, 10:56
Fair enough mate.
Is it likely to be more than 500 would you say?
post #96 of 297 (permalink) Old 26-11-2010, 12:02 Thread Starter
Car: ZS+ 170TD
i would say so yes, seeing as Matt said he would only supply a brand new turbo
p_b82 is offline
post #97 of 297 (permalink) Old 26-11-2010, 16:44
Indeed.
However if a uprated clutch and "used" turbo was already sourced?
Forgot to mention it in the previous post. I was supposed to be working lol
post #98 of 297 (permalink) Old 26-11-2010, 17:43
Car: Bubble 220 SDi (98).
You would have to find a way to control the turbo as we can use erg control on your car to control it. we are looking at controllers to work with the electronic actuator. Fitted as standard to the turbos.
So would any of these kits work with the older 200 engined L series with intercoolers ?
I'd be interested in a 180 kit, don't want the out and out top stuff just something to wake a few people up with....
220Deano is offline
post #99 of 297 (permalink) Old 26-11-2010, 20:06
I think 180 would piddle rings round most things as my boys ZR with sdi injectors, decat, remap and 19psi of boost will pull away from my diesel M Sport with 177bhp from a roundabout in 2nd as I recently found out.
Paul
PaulTF is offline
post #100 of 297 (permalink) Old 26-11-2010, 21:00
Car: MG ZR 160TDi
Paul
So much for it being an "ultimate driving machine"?
radion_auto is offline
I have created a website dedicated to exhausts jbomb MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 18-05-2010 00:21
Fixed one problem but created another Doug1982 MG ZS / Rover 45 & 400 3 28-04-2010 12:29
200bhp 1.4 K series Turbo... MGJohn MG / Rover Related Chat - up to 2005 6 13-01-2007 20:36
New Austin (created by me)... VandenPlas MG / Rover Related Chat - up to 2005 9 16-02-2005 22:54
