Pulley-idler ancillary drive - BROKEN! NEED ADVIDE - MG-Rover.org Forums
post #1 of 10 (permalink) Old 12-12-2016, 10:41 Thread Starter
I have a ROVER 25, 2.0 IDT, YEAR 2000, WITHOUT A/C but with this " Pulley-idler ancillary drive" - Part no. PQR101000 -
http://www.rimmerbros.co.uk/ItemImag...0654-Large.jpg
and it use a belt for an A/C car(extralong), and now has broken
My question is: Can i cancel these PULLEY AND USE A NORMAL BELT FOR NO-A/C ROVER because i don't find these pulley without his support(mount)?
I'm from Romania and here i find only original piece...and it's expensive!
alex_orastie is offline
post #2 of 10 (permalink) Old 12-12-2016, 17:33
This is Rimmer Bros in the uk. They will post, but I presume this is still expensive for you?
Rover 200/25/MG ZR Water Pump from YD471565 - 2000 Diesel at www.rimmerbros.co.uk
I don't think you can use a non air con belt because there were other differences on earlier models that had no air conditioning fitted. I think the alternator mounting point was also different.
Bunny_Brain is offline
post #3 of 10 (permalink) Old 13-12-2016, 04:24 Thread Starter
what about intalling an A/C compresor instead of these pulley???? if i find a non-working a/c compresor at a fine cost...can i use it and cancelling the pulley?
post #4 of 10 (permalink) Old 13-12-2016, 05:02
Pully makes tension of the belt. Without pulley you might have slipping belt.
You can mount replacement pully. Measure its diameter and width and see size of mounting hole, and you can try to find replacement one.
post #5 of 10 (permalink) Old 13-12-2016, 06:05 Thread Starter
I don't find a replacing one, but what about replacing the pulley ancillary drive with a A/C compressor....i find a broked one at half a price....can i use it only for tension the belt???
post #6 of 10 (permalink) Old 13-12-2016, 23:00
The idler the poster is talking about is not the tensioner. It is the dummy idler used to replace the aircon compressor in non-aircon cars.
post #7 of 10 (permalink) Old 13-12-2016, 23:02
Short answer is yes that should work in your case I believe.
Another option would be to repair the original idler pulley. You could either fit a larger bearing or weld repair the pulley back together. I actually built one myself out of a spare vacuum pump and some steel plate (I needed a smaller pulley as I was fitting the engine into a smaller engine bay).
post #8 of 10 (permalink) Old 13-12-2016, 23:03
One last option is to obtain a used part here in the UK and send it over. It isn't a common failure so someone may be able to help.
post #9 of 10 (permalink) Old 13-12-2016, 23:33 Thread Starter
I wanted to weld but it's a piece of torn pulley bearing and do not believe they can balance and better ball bearing in a pulley for not eccentric spin and then break again.
post #10 of 10 (permalink) Old 14-12-2016, 08:04
Balance won't be a problem providing you make sure the pulley runs concentrically. You would certainly have to weld in a a new hub and machine the bore of bearing housing afterwards. This would be my solution and it would ensure it rotates true.
I have done repairs to my cars, such as making new a new main seal for my oil cooler using an aluminium disc and o rings and a new nylon pivot bearing for the aux belt tensioner, they have all lasted well and are still lasting to this day. I repaired the oil cooler over 100k ago. So don't be afraid to re-engineer providing you have access to the equipment or people who can do it properly.
Squeaky belt - Idler Pulley? sarie MG ZS / Rover 45 & 400 7 22-07-2014 16:24
To anyone who has changed "Ancillary Drive Pulley Idler" Joonyer Diesel Forum! 9 06-04-2012 16:35
how much is idler pulley worth ? CCM Diesel Forum! 0 14-06-2011 18:44
idler pulley bearings tarathedog Diesel Forum! 0 18-03-2010 20:29
Fan belt idler pulley ukbob Rover 600 0 08-08-2008 14:29
