Replacing the centre vertical leak off (fuel return) pipe? - MG-Rover.org Forums
post #1 of 4 (permalink) Old 07-04-2017, 20:23 Thread Starter
Ed3
On an L series Rover 45 2.0TD 53 plate how do I replace the centre vertical pipe that goes down and disappears.
I have read the centre vertical pipe goes to a banjo union on the diesel injector pump but I cannot trace which union it goes to. Or which parts I need to take off to get at it. Haynes does not cover this point.
I assume lots of people on this website have done this repair before? What parts do I take off? Is there a diagram? Thanks
Ed3 is offline
post #2 of 4 (permalink) Old 08-04-2017, 15:54
rqt
The leak off pipe is probably no more than 12" / 300mm long & runs underneath the injection pump to the front of the pump.
Remove the flexible pipe from the intercooler to the inlet plenum & you should get sufficient access to replace it.
rqt is offline
post #3 of 4 (permalink) Old 08-04-2017, 23:06 Thread Starter
Ed3
Thanks. I will try that. When I take that intake flexible pipe off, how fussy should I be about cleaning inside it? (The outside does not look it's best.)
Ed3 is offline
post #4 of 4 (permalink) Old 09-04-2017, 11:11
rqt
The inside of the intercooler pipe will be oily but should otherwise be clean. So it should not require cleaning inside. It would be best to clean the outside before removing the pipe - this will keep your hands cleaner & reduce the chances of you transferring oily crud to the inside of the pipe.
rqt is offline
Replacing fuel filler pipe CaptainUnlikely Rover 600 6 17-07-2014 20:14
Replacing heater return pipe MGF MGF NZ MGF and MGTF (Sponsored by MGFnTFBITZ) 8 16-05-2013 05:01
replacing MG ZS fuel filler pipe colscoob MG ZS / Rover 45 & 400 5 04-01-2013 14:36
Leak from fuel filter - is there anti return valve. Mortartube MG ZR / Rover 25, 200 & Streetwise 5 08-09-2011 15:28
If fuel is ******* out of the leak off pipe Dolomite Diesel Forum! 5 26-03-2011 23:38
