Rover 45 2001 diesel cam belt - MG-Rover.org Forums
post #1 of 19 (permalink) Old 30-06-2006, 18:03 Thread Starter
Hi
Does anyone know the mileage intervals for changing the cam belt on this car. I'm currently on 45,000 miles, hopefully its 72,000 miles.
Can't find any reference to the intervals though.
nicolap99 is offline
post #2 of 19 (permalink) Old 30-06-2006, 21:17
Car: Other Rover
Send a message via MSN to bellautos Send a message via Skype™ to bellautos
Rover 45 2.0L Turbo Engine code 20T
Manual tensioner type 2001> 48,000 or 4 years
Auto tensioner type 2001> 84,000 or 7 years
info acording to 2004 AutoData
Both timing belt and injection pump belt recomended
Regards Bell
www.bellautoservices.co.uk
bellautos is offline
post #3 of 19 (permalink) Old 30-06-2006, 21:25 Thread Starter
Thanks for the info.
How will I know whether I've got the Manual tensioner type or the Automatic type.
The registration of the car is on a 51 plate.
post #4 of 19 (permalink) Old 30-06-2006, 21:38
Car: Other Rover
Thats the problem m8,, you realy need to strip the casing of to look.
Cam belt jobs are not for the faint hearted tho.
post #5 of 19 (permalink) Old 30-06-2006, 22:03 Thread Starter
Oh well, looks like I'll have to get the job done then. Any idea of the total cost by an independant garage? Dealer servicing is just too expensive for me.
In fact I rang a dealer today, and they told me the 45 didn't have a belt - that it has a chain - so not much confidence there.
post #6 of 19 (permalink) Old 30-06-2006, 22:06
Car: Other Rover
It is listed in autodata to take 3,10 hrs.
Hope this helps m8
regards bell
post #7 of 19 (permalink) Old 30-06-2006, 22:26
Car: 190 in Firefrost
Send a message via MSN to lates
< 200 if you shop about.
lates is offline
post #8 of 19 (permalink) Old 01-07-2006, 18:42
Car: Corsa 1.5 TD, was 25TD
Hi
I have a 25 TD the 45 may be different. I had a similar dilema as you. So, anyway, I thought best to get the info from the horses mouth - Rover, I phone a Rover (or ex) near me and they very kndly supplied me with the following info :- Bearing in mind I asked about the 25, no idea if the 45 is the same, but it should be shouldn't it ?
Up to chassis number RF 545050 is 84000 miles
After chassis number RF 545050 is 48000 miles
I looked at my Registration Document and there are more letters and digits than the above numbers, but if you look hard enough, you should see the relevant letters, and the numbers on the end. If in any doubt, best to ask a Rover dealer.
RevorTD is offline
post #9 of 19 (permalink) Old 04-09-2006, 22:51
Car: Classic Rover
surely you must have that the other way around, i thought the newer versions had timing belts which lasted 84k, i have a w-reg 2.0 td which is manyfacured in july 2000.
can anyone advise when it recommended to change timing belt.
veggiecar is offline
post #10 of 19 (permalink) Old 05-09-2006, 11:22
its not just mileage but age aswell,as yours is a 2000 model its time to change it regardless of the mileage imo.
ian
muppet is offline
post #11 of 19 (permalink) Old 05-09-2006, 23:07
Car: Classic Rover
ian
better to be safe then sorry, gonna change the timing belt and pump belt. another question does the timing belt pulley have to be changed also?
bit happy today, new maf sensor arrived for bargain price for 35, worked a treat and idling correct and much better performance.
post #12 of 19 (permalink) Old 05-09-2006, 23:20
pre 2001 84k or 7yrs 2001 automatice tensioner 84k or 7yrs manual 48k if doing urself change both belts u need a 6.75 & 9.75 locking pins 4this job
andrew5874 is offline
post #13 of 19 (permalink) Old 06-09-2006, 21:56
Early cars had manual tensioners and 84k belt life
Later cars had auto tensioner and 48k belt life
Progress for ya! NOT
post #14 of 19 (permalink) Old 06-09-2006, 21:59
i wouldnt worry too much about it, think mine was changed at 50k 1st time around, and i had them re done at 140k she runs like a little trooper now
Stu C is offline
post #15 of 19 (permalink) Old 14-09-2006, 22:57
Car: 45 TD
Regards Bell
could someone please clarify here, as one post appears to condradict the other??
doug is offline
post #16 of 19 (permalink) Old 15-09-2006, 16:09
theres always confusion on this matter,
just change it at 50k or 5/6 years whichever comes first for peace of mind if you intend keeping it a while.
spending 200/250 on this is well worth it in the long run imo.
ian
muppet is offline
post #17 of 19 (permalink) Old 15-09-2006, 20:37
Car: 45 TD
Smile
ian
aye, as you say peace of mind, probably change them myself though, doug.
doug is offline
post #18 of 19 (permalink) Old 17-09-2006, 22:35
Car: 45 TD
I may be wrong!, but it would appear that it's just the FIP belt that requires replacing @ 48,000m on the later models?? and the cambelt @84000m....... anyone know for sure??
doug is offline
post #19 of 19 (permalink) Old 18-09-2006, 06:19
I could be wrong on the tensioner types........
BOTH belts need to be changed at the same time & mileage.
Which cam/pump timing belt kits do i need for my 2001 Rover 45 2.0 TD? langadeb Diesel Forum! 7 27-10-2008 14:15
Which cam/pump timing belt kits do i need for my 2001 Rover 45 2.0 TD? langadeb MG ZS / Rover 45 & 400 3 27-10-2008 11:52
For sale, 2001 Rover 45 ixl turbo diesel dap1977 For Sale 8 03-09-2008 19:59
rover 45 diesel 2001 overheating help please!! pkhoopsa MG ZS / Rover 45 & 400 6 01-03-2008 00:43
