SDi injectors - Information for prospective purchasers - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 13 votes, 4.38 average. Display Modes
post #1 of 347 (permalink) Old 13-08-2009, 18:52 Thread Starter
Car: MGZT pbt derv
Following quite a few posts asking about SDi injectors, thought i would resolve a few questions.
Q What car are they from?
A They are found in all SDi/SD models from the following cars:
Rover 400
Rover 200
Rover 600
Q What cars can SDi/SD injectors fit?
A They will be a direct replacement into the following cars:
Rover 45
Rover 25
MGZSTD
MGZRTD
Q What are the approximate power increase after fitting them?
A Without a re-map, approx 130bhp, 200ftlb of torque (depending on additional mods to the car at the time).
With a re-map, approx 150bhp, and 240ftlb of torque (depending on additional mods to the carat the time).
When replacing injectors, always changed the copper sealing washers for new ones. These can be bought cheaply from places such as RimmerBros, or your local Xpart dealer.
Hope this clears things up.
If anybody else wants to add ant further info, then please do so
Would it be possible for a mod/admin to sticky this please?
Dave
Dave is offline
post #2 of 347 (permalink) Old 13-08-2009, 19:13
Car: MG ZR 160TDi
Handy as this is a very common question! Injector seal part number is ERR4621A for reference..
radion_auto is offline
post #3 of 347 (permalink) Old 13-08-2009, 19:20
Car: MG ZS+ TD135+
Yes agreed this could be very useful for some.
Is it worth adding that 130bhp is about what a car with the 99bhp map will get, and the 111bhp mapped cars about 140?
Nomad76 likes this.
SDI_Tim is offline
post #4 of 347 (permalink) Old 13-08-2009, 19:33 Thread Starter
Car: MGZT pbt derv
Any extra info is appreciated, i am sure it'll help people out.
Dave
Dave is offline
post #5 of 347 (permalink) Old 13-08-2009, 20:07
what a guy
Car: Mercedes CLK, Classic Mini, Streetwise TD, ZR Trophy 160, Volvo 244
Don't forget you can always get the new seals from a Land Rover dealer as well...about 1.50 for a set and usually have them in stock.
Cheers,
Ben
Benny Dub is offline
post #6 of 347 (permalink) Old 13-08-2009, 20:08
Car: MG ZS+ TD135+
Dave
I think we've had a couple of cars with the 111bhp map giving over 140bhp, there was Mel45 (149bhp?) and another one. I'll try and find some threads.
SDI_Tim is offline
post #7 of 347 (permalink) Old 13-08-2009, 21:03
Car: Megane RS 225
Added this to the list of Sticky's in that thread i made with all sorts of useful links. Might be worth somebody putting a link to the page on Rimmerbros with the sealing washers for the injectors as this is useful also
Cheers, James
James is offline
post #8 of 347 (permalink) Old 13-08-2009, 21:32 Thread Starter
Car: MGZT pbt derv
Cheers, James
Well added mate, but a lot of newbies still don't read that thread
Hopefully this one will get into the sticky section as well.
Dave
Dave is offline
post #9 of 347 (permalink) Old 13-08-2009, 21:43
Car: MG ZS+ TD135+
Not much time tonight to look, can't find any SDi injector RR results. Hopefully Dakta can chip in with some of the data from his power database....
SDI_Tim is offline
post #10 of 347 (permalink) Old 13-08-2009, 22:03
Does it matter what miles the car u take the injectors out of has on it?
Good info in this thread
newryzs is offline
post #11 of 347 (permalink) Old 13-08-2009, 22:07 Thread Starter
Car: MGZT pbt derv
Obviously the lower the miles the better, but you can send them off to be re-conditioned, no idea how much that is tho.
Dave
Dave is offline
post #12 of 347 (permalink) Old 14-08-2009, 00:14
Car: Rover 220SD
finally a definitive answer! i want power but i don't want to sacrifice reliability,
Flexibility and have ungodly fuel consumption all the time!
mercedeslimos is offline
post #13 of 347 (permalink) Old 14-08-2009, 01:11
So my 220 sd already has sdi injectors???? so i should probably try to stop buying some then lol how stupid do i feel
blaconbomber69 is offline
post #14 of 347 (permalink) Old 14-08-2009, 08:58
Car: ZR-T T16 Turbo 260
I had my car (99bhp standard) RR'd before my remap with the sdi's in and it came out at 139bhp 215 lbs/ft torque.
It did have freeflow backbox, K&N filter & decat on aswell tho
Storm_9010 is offline
post #15 of 347 (permalink) Old 14-08-2009, 20:51
Car: MG ZT+ 135 CDTI facelift Auto + Nissan Micra 1.4 SVE Auto
Question
If i fitted a set of SDI injectors to my bog standard 45TD, is it likely to go from it's usual smoke free zone to looking like a 100 a day chain smoker ? Or is it likely to stay the same as in fairly smoke free ?
mogodon is offline
post #16 of 347 (permalink) Old 14-08-2009, 21:04
what a guy
will probably start kicking out a fair bit of smoke with a set of sdi's, if you up the boost and fit the usual decat/air filter etc. it should clear it up a bit.
The streetwise smokes like a ***** tbh, however boost is standard. I've got a flowed inlet manifold to go on and i'm upping my boost soon so it will probably get rid of most of the smoke.
post #17 of 347 (permalink) Old 14-08-2009, 21:44
Car: MG ZS+ TD135+
Mine with the 111bhp map is "acceptable" with SDi injectors - a quick puff of smoke in the rear view mirror when floored at around 1700rpm, and a light haze up to the red line. Boost at 18psi, ITG panel filter, DIY decat, no other mods. Turning the MAFAM right down helped a lot.
I would imagine a 99bhp map car would be better for smoke, but don't know for sure.
ETA - the Sdi injectors I fitted were brand new.
SDI_Tim is offline
post #18 of 347 (permalink) Old 15-08-2009, 06:49
Car: 53 plate Rover 45 2l TDI
I bought a set of SDI injectors here for my 99bhp 45 and the performance boost is noticeable and no smoke.
JohnthePilot is offline
post #19 of 347 (permalink) Old 20-08-2009, 06:40
mad
Car: mg zr t16 mk2, mad r25 td, anni golf tdi, mondeo st tdci
Send a message via MSN to mad
i would just like to add, that when buying injectors, mileage etc can effect how they perform. You should get them ultrasonic cleaned before putting them in the car, as since i have started doing them, ive never had a bad running set yet. Used injectors can cause bad running.
also i have some dyno print outs of cars with only sdi's in, will try and find them.
mad is offline
post #20 of 347 (permalink) Old 20-08-2009, 21:01
Smile
You have PM, MAD
newryzs is offline
sdi injectors cjaycouper MG ZR / Rover 25, 200 & Streetwise 8 26-04-2009 12:05
sdi injectors rearhorse Diesel Forum! 1 16-04-2009 06:36
SDi injectors Ben202 Diesel Forum! 4 09-10-2007 20:58
I need Rover 620 SDi User manual (tecnical information) DigiSoft MG / Rover Related Chat - up to 2005 0 07-03-2006 20:32
