SDi injectors - Information for prospective purchasers - Page 2 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 13 votes, 4.38 average. Display Modes
post #21 of 347 (permalink) Old 27-08-2009, 13:06
Car: MG ZR TD@160CV + Rover 200SDi
Send a message via MSN to Miky060
I would add that a well done map can help reducing a bit of smoke (expecially on low revs..) and not only to give more BHPs..
Miky060 is offline
post #22 of 347 (permalink) Old 20-09-2009, 21:52
Can anyone suggest the best place to get a set of sdi injectors for my 45?
Would it be best to get them mail order or from a scrapper?
And waht should I pay?
Jonathan
j0ngreen1 is offline
post #23 of 347 (permalink) Old 21-09-2009, 08:35
Car: ZS+ 170TD
ebay or scrapper would be my advice. if they have done loads of miles get them cleaned up by a pro (or some-one that knows what they are doing)
p_b82 is offline
post #24 of 347 (permalink) Old 21-09-2009, 10:27
Make sure they are sdi injectors ie 200bar. As quite a few ebay sellers just list them as diesel injectors which YOU ALLREADY HAVE and are from 25 ,45,......
minesarover is offline
post #25 of 347 (permalink) Old 23-09-2009, 17:34
Excellent info chaps - thanks. Can anyone confirm their mpg before and after fitting these, either with or without a remap? - thanks.
popshot is offline
post #26 of 347 (permalink) Old 28-09-2009, 14:16
Why SDi
Why are these injectors better?
Perhaps the question I should ask is; why would Rover have changed to a lower performance injector?
(Or have I misunderstood as I'm a bit of a novice but looking to improve performance)
DHillary is offline
post #27 of 347 (permalink) Old 28-09-2009, 16:08
Car: S60 D5
Send a message via MSN to AndBurG
they offer a lower break pressure allowing more fuel through, but they dont have as fine a spray pattern which makes them heavier on emmisions and economy
AndBurG is offline
post #28 of 347 (permalink) Old 03-10-2009, 09:54
Car: Nissan X Trail 2.2 Dci
D'oh! After buying injectors, preparing to fit them today, I realise I have forgotten new washers. How essential are they?
Also, as they are used, should I attempt to clean them in some way before fitting?
Villager is offline
post #29 of 347 (permalink) Old 03-10-2009, 11:21
Car: Corsa 1.5 TD, was 25TD
Washers are very essential. Go to a Land Rover dealer and get them, ask for Freelander L-series engine injector seal washers.
Do not attempt to clean them yourself, professional only job.
Anyone fitting SDi injectors, remember this, your boost will be raised by about 3 psi due to the extra fuelling, so if you've already raised your boost you may have to turn it back down.
RevorTD is offline
post #30 of 347 (permalink) Old 03-10-2009, 12:30
Right, thanks, I'll order some and wait !
Villager is offline
post #31 of 347 (permalink) Old 15-10-2009, 10:50
Car: MG ZR TD (mk2)
What sort of difference to the 0-60 does this make on the 99bhp diesel?
Leckenby is offline
post #32 of 347 (permalink) Old 15-10-2009, 10:53
Car: ZR-T T16 Turbo 260
If you are just putting in the sdi's i would say it would be running around 125 - 130bhp. I would guess the 0-60 would be around 8 - 8.5 (standard on a 99bhp is 9.7) but not 100% sure as its just a guess. The torque you gain is the best part which makes overtaking really easy.
I think mine (152bhp 250 lbs/ft torque) is running 0-60 around 7.5 but again just a guess
Storm_9010 is offline
post #33 of 347 (permalink) Old 25-10-2009, 09:09
Car: LeMans Green 5Dr '03 ZR TD 115
Send a message via MSN to shunteruk
Anyone know how much it costs and where I can get it done to have the injectors professionally cleaned/refurbed?
shunteruk is offline
post #34 of 347 (permalink) Old 29-10-2009, 14:10
hi, on my zr 115 td 2005 i have:
1) sdi injectors,
2) bmc air filter,
3) mafam booster by roveron,
4) decat pipe with diameter 62mm.
i don't have tested my zr but wath power it's my zr second you?
MGFAST&FURIOS is offline
post #35 of 347 (permalink) Old 29-10-2009, 18:14
1) sdi injectors,
2) bmc air filter,
I'd estimate about 135 bhp.
RevorTD is offline
post #36 of 347 (permalink) Old 06-11-2009, 10:34
Why don't you add a link to ziobobby's tutorial here? It's full of pictures and infos..
How to remove/swap injectors (pics)
Miky060 is offline
post #37 of 347 (permalink) Old 01-12-2009, 10:03
Send a message via Skype™ to zs-in-spain
Please could you add to the FAQ, what's involved in fitting them?
zs-in-spain is offline
post #38 of 347 (permalink) Old 08-12-2009, 10:45
Car: 820 Vitesse*RIP, MG ZS+ 115, 825 Sterling Coupe *RIP, 825 Sterling Saloon, Subaru Legacy 3.0 specB
Send a message via MSN to gibbzy2k1
How much difference do they make to economy? Does the mpg drop a lot?
gibbzy2k1 is offline
post #39 of 347 (permalink) Old 08-12-2009, 17:03
Car: MG ZS+ TD135+
For me I estimate around 2mpg in town and on a fast run, on a gentle run maybe 5mpg (when less fuel is used anyway, so it only takes a small increase in fuel use to drop the mpg quite a bit).
This is all guesswork though, as I had a ZR before without SDi injectors (but remapped), before the ZS with SDi injectors fitted but not mapped. The ZS weighs a bit more but is more aerodynamic, so it's hard to know exactly how much of the reduced mpg around town is due to the extra weight compared to the ZR, and how much down to injector differences. On a run I haven't hit 60mpg with the ZS yet (only 57mpg, but I've done less long journeys driving sensibly in it), but on the ZR I got over 60mpg twice (64mpg and 69mpg).
Taking into account that remaps to gain 140bhp or there abouts on standard injectors will put extra stress on the fuel pump, I can live with slightly less mpg's with the SDi injectors, as they are not stressing the fuel pump as much, and cost me less than half the price of a remap.
Bang for buck the SDi's win for me, but if I was doing high mileage then I would consider a remap instead.
SDI_Tim is offline
post #40 of 347 (permalink) Old 21-12-2009, 14:53
would these fit a rover 220d?
if so how long does it take to put them in?
brivtec is offline
sdi injectors cjaycouper MG ZR / Rover 25, 200 & Streetwise 8 26-04-2009 12:05
sdi injectors rearhorse Diesel Forum! 1 16-04-2009 06:36
SDi injectors Ben202 Diesel Forum! 4 09-10-2007 20:58
I need Rover 620 SDi User manual (tecnical information) DigiSoft MG / Rover Related Chat - up to 2005 0 07-03-2006 20:32
