Sudden onset random rough idle/ rough running issues - MG-Rover.org Forums
post #1 of 3 (permalink) Old 01-03-2016, 00:01 Thread Starter
'98 Rover 420. Had the cambelt work done midway last year. 10,000+ kms since then, been running great, more economical even.
Was running perfectly fine one day. Next day, suddenly rough idle at startup. See sawing between normal idle to almost cutting off and then back to normal and so on, till the engine warmed up. Was a bit juddery when running. Eventually smoothed out though.
Next day still, no rough idle upon startup. Running fine too. Roughly between 3rd and 4th gear, suddenly juddering again. Then smoothing out (but not completely) as the revs went up.
Have been advised that it might be issue with glow plugs, especially considering the rough idle when cold. Still puzzled by the very sudden onset though. And by the juddering when warm.
Doesn't heat up, needle stays in mid. Car has always smoked when revved above 4k. Thick black smoke. Hasn't affected the driving or the mileage.
Might change the glow plugs anyway. But what else could cause this?
onepostwonder is offline
post #2 of 3 (permalink) Old 01-03-2016, 07:35
It isn't the glow plugs so you can safe the effort on that one.
I'd be checking that the wire to number 1 injector isn't chafed and rubbing on the engine block, and also changing the fuel filter if it hasn't been done recently.
post #3 of 3 (permalink) Old 01-03-2016, 13:28
+1 as above also check wiring loom to pump.
minesarover is offline
rough idle silent Diesel Forum! 0 14-05-2015 22:39
Interesting idle issue: Low/rough idle when braking out of gear. Very confusing! DMGRS MG ZT / Rover 75 (Sponsored by Rimmer Bros) 13 24-09-2011 00:54
VVC Idle / cooling fan / rough running danallen Coupe 33 08-03-2010 00:39
Engine seems to be running rough, but OK at idle Buffalo Bill MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 19-05-2008 22:04
rough cost of garage work.. anyone give me a rough figure? dynamis_dk MG ZR / Rover 25, 200 & Streetwise 7 21-08-2006 19:08
