Swap pipes on Clutch Master Cylinder? - MG-Rover.org Forums
post #1 of 2 (permalink) Old 19-06-2017, 13:13 Thread Starter
Ed3
I am still trying to get my clutch master cylinder to work on L series 45 52 plate (UK right hand drive). It so happens I have a brand new Delphi master for a "left hand drive" car (shorter pipe) and was going to use the internal parts to make my master cylinder work, but wonder whether I can just swap the pipes by removing the pin that seems to hold the pipe union to the master cylinder.
Does anyone know if I hammer the pin out of the union to take the pipe off whether I can swap the pipes? Will they go back on OK?
Ed3 is offline
post #2 of 2 (permalink) Old 20-06-2017, 17:09 Thread Starter
Ed3
i have managed to easily swap the pipes on a clutch master cylinder by taking out the split pin, used a hammer and unused pop rivet to drive out the pin securing the pipe union to the master cylinder, and swapped the pipes. While the pipes were off, I also swapped the seal (rubber O ring) between the pipe and clutch master so that the new seal will be on the car.
Ed3 is offline
75 ZT Clutch Master Cylinder Swap MGJohn MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 03-07-2015 19:39
clutch-slave cylinder,master cylinder cost kumala MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 28-01-2010 16:48
Clutch Master Cylinder alex7127 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 17 12-10-2008 22:34
Clutch Master cylinder KevG MG ZS / Rover 45 & 400 0 25-01-2006 18:30
MS ZS - Clutch Master Cylinder parsec MG ZS / Rover 45 & 400 1 05-02-2005 06:27
