timing belt change - MG-Rover.org Forums
post #1 of 3 (permalink) Old 05-02-2017, 13:02 Thread Starter
timing belt change
Hi guys, can anyone tell me how I need to change belts including water pumps and related spare parts codes? thank you
MGFAST&FURIOS is offline
post #2 of 3 (permalink) Old 05-02-2017, 14:17
rqt
L series water pump is not driven by the timing belts & is accessible with all the belts in place - so you can happily leave the water pump out of your plans until it starts to leak.
rqt is offline
post #3 of 3 (permalink) Old 05-02-2017, 14:55
https://www.dmgrs.co.uk/collections/...45-zr-zs-99-06
That has all the parts you need for the cambelts. I'd also add in the aux belt too as it'll be cracked when you take it apart - they usually are.
I'd also recommend using a timing pin kit too. If you don't have anything suitable then this will work fine:
https://www.dmgrs.co.uk/collections/...00-25-45-zr-zs
How much for 2003 MG ZS TD timing belt / injector belt change? DMGRS Diesel Forum! 23 26-08-2012 20:02
Timing belt change ZR Rekinu Diesel Forum! 18 25-05-2012 06:58
When to change the timing belt? andythebus MG ZR / Rover 25, 200 & Streetwise 12 01-12-2011 11:57
Timing belt change bobbybrown Diesel Forum! 14 11-11-2011 21:22
When is the timing belt change on 75 1.8t? John Bell MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 03-07-2008 20:29
