high clutch pedal, easy cure - MG-Rover.org Forums
post #1 of 51 (permalink) Old 11-03-2005, 12:50 Thread Starter
Smile high clutch pedal, easy cure
Simply attach a universal u shaped mudflap bracket to the pedal lever, it rests on the housing and is totally adjustable sliding either up or down to alter pedal height. Ive done about 8 mods so far without a problem, mine has done 30000 miles since the mod was carried out, no problems at all.
glynmitchell is offline
post #2 of 51 (permalink) Old 12-03-2005, 08:49
Car: Silver Stormer ZR turbo.
Do you mean high biting point or actually high pedal?
We need some pics of this to see what you mean exactly.
I have managed to mod the biting point on my clutch, which now bites lower down and makes the car a lot mire drivable.
Some others have done the same, but I'm not sure as to what you have done.
ashy is offline
post #3 of 51 (permalink) Old 15-03-2005, 20:17 Thread Starter
High clutch pedal
I mean clutch pedal sits high, biting point normal.
post #4 of 51 (permalink) Old 16-03-2005, 07:33
The thing is don't really understand what you have done.
We really need to see what you mean here with some images.
I think what you have done will only work on your car too. The 200 's have auto adjusting clutch cables so what you have done wouldn't work.
If you alter the height of the clutch pedal then that would mean that the clutch would not be fully engaged when released.
ashy is offline
post #5 of 51 (permalink) Old 16-03-2005, 07:38
If you alter the height of the clutch then that would mean that the clutch would not be fully engaged when released.
I agree as a high clutch pedal is a problem to a few of us a picture or two would really help.
Ken75 is offline
post #6 of 51 (permalink) Old 20-03-2005, 18:01
Send a message via MSN to ZR Stevo
I would be keen to see this mod too!
ZR Stevo is offline
post #7 of 51 (permalink) Old 20-03-2005, 18:07
I have a feeling its going to be a long wait for any pictures or any explanation
Ken75 is offline
post #8 of 51 (permalink) Old 20-03-2005, 18:08
Shame
ZR Stevo is offline
post #9 of 51 (permalink) Old 14-05-2005, 11:55
Car: Something Else
This is indeed a very simple mod the only problem i have found is what to use to adjust the pedal. But stick your head under the dashboard and have a look at the clutch pedal. You will notice that on many models there is free play due to the spring returning the pedal further than it needs to. So basically the first inch of movement does not move the piston to start applying the clutch. Now if you use a stopper (or more acurately extend the existing stopper) you can remove this free play so that as soon as you touch the pedal the clutch cylinder will start to move. The clutch bite point does not alter but there is a potential to lower the return height of the pedal by around 1inch with no ill effect or added wear to the clutch.
You just gotta work out what to use extend the stopper.
Nomad76 likes this.
Schtopper is offline
post #10 of 51 (permalink) Old 14-05-2005, 20:23
stiff clutch pedal
does anbody know how to ajust a stiff clutch pedal,iseem to have to bury the pedal to the floor to engage it into gear,its hard work,my zs 120 had a nice easy pedal but my 180s is hard.any help please.my ankle realy hurts tonight.
zedster zs is offline
post #11 of 51 (permalink) Old 17-05-2005, 06:09
never driven a defender
Phil is offline
post #12 of 51 (permalink) Old 20-05-2005, 15:41
Car: MG ZTT
Ah - now I understand. I've got really long legs and always struggle with the clutch. I had a hire van a few months ago - almost undriveable. Just couldn't get my foot of the clutch
So the bracket approach is simply to take the slack out of the mechanism. I like it...
selwonk is offline
post #13 of 51 (permalink) Old 11-07-2005, 22:54
I would really like to see photos too; the clutch on my car is unusually high, and consequently I still stall as I lose the biting point (much to my embarrassment). Due to the time it takes for the local garage to get anything done, Ive been loathe to take it in (took him 3 days to diagnose a problem when I had already told him exactly what was wrong, then a further week to fix it and fit new tires).
Fascination is offline
post #14 of 51 (permalink) Old 12-07-2005, 08:14
Car: Mazda3 MPS
Send a message via MSN to Xorro
Is it possible to adjust the biting point though?
I find that I cannot change from 1st to 2nd without jerking, this is because the last few millimeters are where the biting point is and by the time you foot is that high up its difficult to control the pedal.
Xorro is offline
post #15 of 51 (permalink) Old 12-07-2005, 08:30
Car: Something Else
No i don't think you can adjust the biting point, it's a hydraulic clutch and as such i think it's self adjusting, i find the biting point a bit on the high side as well but i've become acustomed to lifting my leg halfway, then resting my heel bring my toes up slowly onto the biting point. Alternatively just floor it and dump the clutch
post #16 of 51 (permalink) Old 12-07-2005, 08:36
Car: Moonstone Green Rover 75 CDT Tourer Conn SE with Upsolute remap and Synergy 2
This might affect cars with cruise control. I was puzzled why my cruise control wouldn't always engage (75 CDT T), then I realised it was because I have the naughty habit of driving with my foot resting on the clutch rather than using the proper foot rest.
Isis is offline
post #17 of 51 (permalink) Old 16-10-2005, 23:31
Car: Alfa 159 2.4 JTDm 210
I found the clutch pedal very high on my Zr but it can be adjusted so long as there is slack on the pedal (before the clutch cable is actually moved). If you have a look in at the top of the pedal you can see where it pulls the clutch cable on the other side of the pivot. Beside this you can see the little stop that limits how high the pedal can go. So if you press down the pedal from the top and it moves before it actually pulls the clutch cable, you can screw in the adjuster until there is no slack. Its pretty ackward getting the bugger screwed where its at, but it took about half an inch from my pedal and makes it feel much nicer now.
damo_mc is offline
post #18 of 51 (permalink) Old 03-12-2005, 10:36
Hi did a smilar mod on my 1st 400, the clutch pedal sat was to high for my little feet!! I removed the pedal and put some washers (3off M8 from memory) between the mounting studs(on bulkhead) that hold the pedal on and the pedal. The top bracket has a slot so dosesn't need any mods,This fixed it for me
Seamus
shiftyseamus is offline
post #19 of 51 (permalink) Old 05-12-2005, 21:58
i m thinking to fit a prolonger bar with a little hinge .to adapt my feet to the pedal clutch
ursus-2 is offline
post #20 of 51 (permalink) Old 05-12-2005, 23:14
Send a message via MSN to Mitch - ZR
someone will have to do an illustrated guide for this, i was considering taking a section out of my left leg, looks like there is a much better solution!!!
Mitch - ZR is offline
Clutch Pedal Gone High langleys MG ZR / Rover 25, 200 & Streetwise 7 30-04-2008 14:18
Clutch pedal seems way too high! bear007 MG ZR / Rover 25, 200 & Streetwise 2 27-02-2008 18:24
ZS High Clutch Pedal keir1163 MG ZS / Rover 45 & 400 14 10-01-2008 20:43
clutch pedal too high ? cannonoball MG ZR / Rover 25, 200 & Streetwise 1 02-12-2007 18:47
