Rover 25 / MG ZR How To - Change A Pollen Filter - MG-Rover.org Forums
post #1 of 3 (permalink) Old 12-08-2015, 15:30 Thread Starter
I know most people here probably know how to change a pollen filter, but for the select few who don't, I whipped together a quick walkthrough.
As far as I know this applies to all Rover 25/45 models + MG variants
You will need:
x1 Pollen filter
x1 Socket wrench/screwdriver
x1 8mm socket
x1 7mm socket
x20 minutes (roughly)
1. Put the radio on.
THIS IS IMPORTANT, as it will relive stress and prevent you from wanting to murder small insects.
2. Now that you have some ambient background noise to make you feel relaxed, take an 8mm socket and remove the 2 bolts that hold the glovebox in place
3. Now, remove the glovebox by opening it (It should drop straight down.)
You should end up with something like this.
The pollen filter housing is the massive gap on the right (Previous owner decided to remove the filter + cover and not replace them)
4. Switch to a 7mm socket and remove the 2 bolts that hold the glovebox support bar in place.
4. Now, take your filter:
And insert it carefully into the housing, making sure it is the right way round.
5. Admire your work:
Before bolting everything back (refitting is simply a reversal of removing.
6. Have a cup of tea.
Splop is offline
post #2 of 3 (permalink) Old 14-08-2015, 12:13
for a personal touch, I like to soak the new pollen filter in some nice smelling stuff before fitting.
last time it was F-JAS bubblegum fragrance oil, although I have also used various flavours of Hugo Boss and Paco Rabanne.
All the time the air is flowing, the car smells awesome!
Levaz is offline
post #3 of 3 (permalink) Old 01-01-2016, 17:16
Hi! I recently put in a pollen filter in my 216 Cabrio because I noticed there wasn't any already installed. My question now is which way the air is flowing so that I can be sure I put in in correctly. I have a left-side steering wheel so the access to the filter is on the pasenger side. Is the airflow from left to right or otherwise? Many thanks!
Avuto is offline
Cabin /Pollen filter change. How? victorgte MG ZS / Rover 45 & 400 6 12-11-2014 12:25
How To: Change MGZS + Rover 45 Pollen Filter Jason F VVC MG ZS / Rover 45 & 400 8 10-03-2014 16:07
Change your pollen filter!! hh1 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 8 29-10-2012 10:05
Rover 75 1.8T Pollen Filter Change JeffD MG ZT / Rover 75 (Sponsored by Rimmer Bros) 15 15-11-2011 16:50
How to change pollen filter Shaf MG ZT / Rover 75 (Sponsored by Rimmer Bros) 25 22-04-2007 12:12
