How Do I... Fit an Engine Push-Button Start??? - Page 13 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 20 votes, 4.80 average. Display Modes
post #241 of 248 (permalink) Old 17-11-2011, 20:15 Thread Starter
Good info mate, cheers I've actually not looked into doing it on the Slowver, so that might save me some hassle!
ThumpJunkie is offline
post #242 of 248 (permalink) Old 01-03-2012, 12:52 Thread Starter
Originally Posted by Popeye 89 View Post
did this today on a 2000 25 td.
the wires were different. you will find 4 wires going from the ignition barrel to a whitish plug. there is a black/white, 2 white wires and another wire (dont worry about this one)
cut the black/white and strip a section on the plug side (just making that one clear, you want the side of the now cut wire which is attached to the plug, not the ignition barrel)
then you want to splice into one of the white wires. which one you ask? look at the wires coming from the ignition barrel. you want the white one at the bottom. trace it back and splice accordingly
hope this helps an already excellent guide nice job tj, still useful years on
Just did this on the Slowver, worked a treat Thanks mate.
post #243 of 248 (permalink) Old 19-03-2012, 22:28
Car: bmw 318is coupe
i intergrated mine into the fag lighter on the beemer. looks well trick as you dont know its there. only possible if you dont use your fag lighter
mtechstevo is offline
post #244 of 248 (permalink) Old 01-09-2012, 20:42
That looks awesome and would do it tomorrow. Iv got one huge dilema and question!
If I disconnect the battery will my fob (round one) have to be reprogranmed to the ECU/BCU?
I have a genuine reason for asking as before I bought my car I had to fork out 575 on an ECU/BCU and a fob. The boy I bought it from locked the car as normal with the fob which deadlocked it. His batterry then went flat because of dodgy wiring. Now I cant remember if he said if he removed the battery from the car or fob to replace it which then meant his fob was no longer programmed to the ECU. As far as iv been told the fob has to be eprogrammed by using the key in the lock and turning in a certain sequence. problem being it has been de-locked. So I had to get a hold of an mg zr specialist in glasgow to put in the said above things for me. He told me once a fob has been unprogrammed from the ECU it cant be recoded to it? Funny thing is the key fob he gave me warnt brand new....
varney zr is offline
post #245 of 248 (permalink) Old 21-09-2012, 21:03
Car: Rover 25 TD 135
So bearing in mind that I have the same model car, how would I wire up one of these?
http://www.ebay.co.uk/itm/12V-Car-En...-/221119552275
Gooner86 is offline
post #246 of 248 (permalink) Old 18-11-2012, 16:34
Car: MG ZR160
i used the 1.50 non latching red button from maplins mate, never caused any problems
Popeye 89 is offline
post #247 of 248 (permalink) Old 07-04-2015, 23:19
Smile Remote starter button
Thanks for all of this information. I needed to fit a remote button as the switch on the underneath of the ignition had failed in position 3 and as I have the Mk2 ZR, I would need to grind of the security plate to get to replace the switch. Again thanks for this info.
wardencaller is offline
post #248 of 248 (permalink) Old 21-04-2016, 09:43
hi, ive just blown a fuse doing this now it wont start, any ideas what I might have blown?
rumpy is offline
Push Button Start shadybarry218iS Others 13 10-11-2009 19:59
push button start? diesel_03_uk MG/R Modification & Tuning 9 14-09-2006 18:28
push start button loadsaaaTOP MG/R Modification & Tuning 7 27-08-2006 17:39
push start button Cyer_ricki MGF and MGTF (Sponsored by MGFnTFBITZ) 22 21-07-2006 10:40
push button start Mgfdude MGF and MGTF (Sponsored by MGFnTFBITZ) 19 24-11-2005 15:36
