How do I use my EKA CODE? - Page 7 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 187 votes, 5.00 average. Display Modes
post #121 of 124 (permalink) Old 20-10-2016, 21:43
Car: F. Fiesta 1.6 ECOnetic
I believe the 0 is counted as a 10
david.anthony is offline
post #122 of 124 (permalink) Old 21-10-2016, 09:15
Originally Posted by AlysonB View Post
But what do you do when one of the numbers is a zero?
Emergency Key Access codes cannot contain a '0' for obvious reasons. It is worth trying it as 10, but I think it is more likely that what you have is not the EKA code (more likely the radio code or key reference code).
post #123 of 124 (permalink) Old 20-02-2017, 11:32
Originally Posted by SQNLDR View Post
For those that helped thank you, It eneded up being a combinnation of actions so for those that have this problem here is my solution.
Barry Flat
a. recharge battery or replace and install
b. Lock door hold for 5 sec on lock
c. Input EKA code u/l/u/l
d. open door
e. insert key and turn to 3 alarm will sound, press lock on fob 4 times alarm goes off. Start engine take for drive
F. have very large whisky ; and pray stupid security system doesn't have any further hassles.
I have tried all options for getting the fob to work again with the car, including (of course) a new battery and yet I get to this point when the alarm is going off and I can't stop it.
At one point if I did the EKA code and then just clicked the ignition key straight through the start process, the engine actually started, but then straight away it shut down again, presumably the immobiliser kicking in?
Can anybody help further please?
larrywilkie is offline
post #124 of 124 (permalink) Old 20-02-2017, 13:00
Engine firing up and then shutting down almost immediately is a definite symptome of the code the SCU shares with the engine ECU to disarm the immobiliser having been corrupted - seems to happen sometimes if the car has been left with a flat battery, or sometimes when it has been jump started. We seem to be having a crop of cars with the same issue at the moment - you are the third today!.
You may find some answers in this thread: http://forums.mg-rover.org/mg-zr-rover-25-200-streetwise-101/zr-1-8-immobiliser-help-837722/
EKA Code < KEVIN > MG / Rover Related Chat - up to 2005 3 23-10-2012 20:07
Help - EKA Code Ayman osman MG ZR / Rover 25, 200 & Streetwise 4 08-09-2008 11:58
EKA code skymanuk34 MG ZS / Rover 45 & 400 9 17-10-2007 21:50
EKA code help kmcd Others 0 14-07-2007 16:16
i want to know my EKA code Ayman osman MG / Rover Related Chat - up to 2005 7 05-09-2006 19:12
