How to... Fit Rover 800 stalks to your MGF/TF - Page 2 - MG-Rover.org Forums
post #21 of 55 (permalink) Old 12-09-2006, 08:50
Richard Moss
Guest
Posts: n/a
Originally Posted by cjmillsnun View Post
Odd. My old metty did, as did my OH's 100
I suspect that it will depend upon the spec of the car.
post #22 of 55 (permalink) Old 14-09-2006, 15:52
my stalks arrived today , bit mucky, but nothing that won't clean up, they appear to operate OK.......so thats a little something for the weekend sir
.........and I've just bagged me a wiper control unit of Ebay
post #23 of 55 (permalink) Old 18-09-2006, 18:51
CJ, had to remove my steering wheel tonight as I was 1 spline out of central, and happened to notice the indicator cancelling ring. I assume the F is the same. This needs lining up with the slots on the steering wheel boss when the wheel is replaced. I just thought it needed adding to your instructions
the 800 stalks feel more substantial than the oe ones, do you find that ?
post #24 of 55 (permalink) Old 18-09-2006, 19:16 Thread Starter
Good point Pete.
And yes, the 800 stalks do feel more substantial. Something I like!
cjmillsnun is offline
post #25 of 55 (permalink) Old 18-09-2006, 19:18
I've missed a thread somewhere I think - but why fit R800 stalks? What does the end result look like? I am intrigued!
Rob Bell is offline
post #26 of 55 (permalink) Old 18-09-2006, 19:23 Thread Starter
I'll find you a linky...
I fitted 800 stalks as I had a spare set, liked the look of em, saw a thread from a newbie asking if there were alternatives and decided to see if they fitted. The results are here
post #27 of 55 (permalink) Old 18-09-2006, 19:23
the end result Rob, when CJ and Chris T sort a resistor out, will be proper intermittant wipers and classier looking stalks imo
post #28 of 55 (permalink) Old 19-09-2006, 07:55
CJ, Pete, it all makes complete sense now!
Having read through both threads, I can see the logic and sense behind this modification - and like you chaps, am left wondering why we got the cheapo stalks rather than these clearly far nicer ones. In fact, why didn't MG Rover go other to these for the face lift rather than make the glossy cheap stalks cheaper by using a matt finish???
Variable intermittent function - brilliant! Been missing this from my car for over 10 years!!!
Next task: sourcing the necessary parts
Great work CJ!
Rob Bell is offline
post #29 of 55 (permalink) Old 19-09-2006, 09:22
Richard Moss
Guest
Posts: n/a
Smile
like you chaps, am left wondering why we got the cheapo stalks rather than these clearly far nicer ones. !
Because 800s are special and a cut above the ordinary cars that you lot drive! LOL!
As I said, 800s are special!
post #30 of 55 (permalink) Old 19-09-2006, 18:42 Thread Starter
And that's why there is tin above your head
post #31 of 55 (permalink) Old 02-10-2006, 10:37
Car: Ford Focus
Send a message via MSN to Dave400
Been following this for a while and have also aquired a set of stalks to see if it's as easy to fit to the 400 saloon as it is the F/TF
edit, just fitted them and found i didn't have to remove the exploding wonder or steering wheel.. still ducked out the way just in case.
What i have found is that i the rest position, both stalks slightly foul the shroud, not so much an issue for the indicator stalk, but the one time wipe on the wiper stalk refuses to spring back when let go.
Nothing that a spot of dremel action won't cure but did you guys have that problem or is there more free room on the F/TF shroud?
next job, variable wipers...
Dave400 is offline
post #32 of 55 (permalink) Old 02-10-2006, 15:35 Thread Starter
The stalks don't foul the F/TF shroud at all.
post #33 of 55 (permalink) Old 09-02-2007, 23:10
Car: MG TF160, Ford Escort Cosworth
Ahh class find!
My biggest gripe with the TF is the shockingly SHONKY stalks!
Are the 800 stalks easy to find??
Cossie Killer is offline
post #34 of 55 (permalink) Old 09-02-2007, 23:13
Ebay is a good bet or local breaker or bran new from a Land Rover dealer
post #35 of 55 (permalink) Old 09-02-2007, 23:24
One of my mates has just started as a salesman for Land Rover!! Do them reference numbers still match LR ref's?
post #36 of 55 (permalink) Old 10-02-2007, 17:01
What's the latest on the variable intermittent wiper function chaps?
Rob Bell is offline
post #37 of 55 (permalink) Old 10-02-2007, 19:40
The new controller is still under construction as I haven't had as much time as I was hoping to dedicate to it but hopefully next week should see some progress.
post #38 of 55 (permalink) Old 10-02-2007, 20:28 Thread Starter
Excellent.
post #39 of 55 (permalink) Old 16-02-2007, 22:20
7. Remove the steering wheel and stick some sticky tape over the rotary coupler so that it cannot move.
8. Undo the 3 philips screws underneath the steering column that hold the plastic steering column trim on. and remove the trim.
9. Undo the 4 philips screws that hold the rotary coupling to the column. remove the multi plug from the back of the rotary coupler and remove the coupler.
Right hoping to do this over the weekend (stalks turned up this week!!) and the only bit thats bugging me is this rotary coupler.... Is it obvious once the steering wheels been removed why it has to be taped secure?
Also in the thumbnails, is the coupler the part the yellow airbag wire comes out of?
Jason
post #40 of 55 (permalink) Old 17-02-2007, 10:04 Thread Starter
Jason
Yes, the rotary coupler is the part the yellow airbag wire comes out of.
It has to be taped secure because inside is a ribbon cable which if the coupler moves has been known to snap, resulting in the SRS light coming on (cos the airbag isn't connected) and the horn not working. Also with them costing stupid amounts of money (about 150) It's best not to risk damage. A piece of masking tape does the job.
Tags
variable intermitant wipe
MG TF parts to fit MGF? Dean Carr MGF and MGTF (Sponsored by MGFnTFBITZ) 15 07-08-2008 09:14
Will MGF/TF wheels fit an R25? rangerman77 MG ZR / Rover 25, 200 & Streetwise 6 14-03-2008 17:03
MGF Polybushes - do they fit TF as well? ChrisTromans MGF and MGTF (Sponsored by MGFnTFBITZ) 6 17-04-2007 11:41
would tf exhaust fit mgf ?? fg550 MGF and MGTF (Sponsored by MGFnTFBITZ) 4 12-03-2005 20:24
MGF - Retro fit TF EPAS mr_baz MGF and MGTF (Sponsored by MGFnTFBITZ) 4 16-11-2004 22:20
