How to... Fit Rover 800 stalks to your MGF/TF - Page 3 - MG-Rover.org Forums
post #41 of 55 (permalink) Old 22-03-2007, 16:50
Rotary coupler is a plastic 'ring doughnut' with a ribbon cable (tape) wound inside.
The issue here is the spooling of the tape inside the ring going out of sync with the steering of the car.
Attached is a sketch showing how the rotary coupler works:
If you wind the rotary coupler independantly then when you apply full lock on the steering you could wind the tape too tightly and tear it - this will cause an SRS fault.
Taping it in position is a good idea, but if it does go out of sync then all you need to do is find the central position. You do this by winding it to the end, then winding it back completely to the other end, counting the revolutions as you go. Divide the revolutions by 2 and then wind it back this many turns, now wind it the shortest distance until the connector block is at the top (to fit the gap int he steering wheel).
Scarlet Fever is offline
post #42 of 55 (permalink) Old 11-06-2007, 22:04
year?
I have possibility of stalks from a P reg 800 Vitesse Sport - will these fit?
adamelphick is offline
post #43 of 55 (permalink) Old 14-06-2007, 16:14
stalks
Right got em! Now im off out into 'Meg' to change her stalks!
post #44 of 55 (permalink) Old 25-06-2007, 10:26
How did it go?
Oh... and anyone yet manage to get the intermittent wipe function to work yet?
Rob Bell is offline
post #45 of 55 (permalink) Old 11-03-2011, 16:07
gonna try this if i can find a pair of stalks
Carl is offline
post #46 of 55 (permalink) Old 23-01-2014, 14:13
Car: MGF VVC and ZTT 190
Quick question about polarity
I know I'm reviving an old thread but I've got the 800 stalks and have just got hold of the Pektron front wiper control unit YWC10152. A quick question on polarity through - I've got the heated washer jets on the F which are, IIRC, powered from a live on the wiper motor. This intermittent mod needs the wiper leads to be swapped - do I swap them before or after the lead to the washer jets. I'm guessing it's before so the polarity to the jets is the same? Thanks in advance!
EmGeeExe is offline
post #47 of 55 (permalink) Old 21-04-2017, 23:20
What are Rover 800 stalks and why would I want to fit them to my MG TF>
Stargatemunky is offline
post #48 of 55 (permalink) Old 22-04-2017, 10:59
They are steering column stalks from a Rover 800, they look, feel and operate better than the ones fitted in the MG TF.
post #49 of 55 (permalink) Old 24-04-2017, 08:50
Why did they not simply run a couple of copper conductor rings with contactors in the steering rack? It's so much simpler and infinitely more reliable.
post #50 of 55 (permalink) Old 24-04-2017, 17:51
That's ok with one pair of contacts but the F, for instance, has many more than this.
post #51 of 55 (permalink) Old 24-04-2017, 20:00
Freelander Mk1 stalks are the same as Rover 800 and far easier to source these days
dert is offline
post #52 of 55 (permalink) Old 11-05-2017, 12:52
Fitted them to my TF today.
Was very easy.
Didn't get killed by the airbag exploding in my face either.
Tags
variable intermitant wipe
MG TF parts to fit MGF? Dean Carr MGF and MGTF (Sponsored by MGFnTFBITZ) 15 07-08-2008 09:14
Will MGF/TF wheels fit an R25? rangerman77 MG ZR / Rover 25, 200 & Streetwise 6 14-03-2008 17:03
MGF Polybushes - do they fit TF as well? ChrisTromans MGF and MGTF (Sponsored by MGFnTFBITZ) 6 17-04-2007 11:41
would tf exhaust fit mgf ?? fg550 MGF and MGTF (Sponsored by MGFnTFBITZ) 4 12-03-2005 20:24
MGF - Retro fit TF EPAS mr_baz MGF and MGTF (Sponsored by MGFnTFBITZ) 4 16-11-2004 22:20
