Rover 25 Meshing R25 Grille - Page 2 - MG-Rover.org Forums
post #21 of 31 (permalink) Old 27-03-2011, 20:10
Car: Rover 25 IL TD 3 Door
End Result:
Wow, that chrome was a ******. Tip: When you've got a chunk in the pliers, up away from the grill and not along it, it comes off in bigger chunks. Took me about 2 hours to do, couple of bits (Sides) were awful to get off.
Bit miffed by the end result, I bought 'Tahiti Blue' from my local shop, a holts can, and used Holts grey primer, but the colour is noticeably lighter than my car. Will be leaving it for a while though, so if you see a blue rover with a light blue grill, it's me
Edit: And yes, my O/S fog light surround isn't there
noirenex is offline
post #22 of 31 (permalink) Old 27-03-2011, 20:41
Car: Rover 620 gsi
not a 25 but meshed,
Before
after
coalman is offline
post #23 of 31 (permalink) Old 07-04-2011, 07:34
Car: Rover 216si (95-99) 'Bubble Shape'
hi i've got a rover 216si think its the mk3 version with the grill and bumper in one..... can any one tell me how to remove the grill?????? mucho thanks.....
cooldub101 is offline
post #24 of 31 (permalink) Old 08-04-2011, 10:09
Car: Vauxhall Astra Turbo Diesel. Combo Turbo Diesel. Rover 825 V6 Coupe. Merlin Titanium Mountain Bike.
Talking
not a 25, but I like adding pics too!
Rover V6 Coupe is offline
post #25 of 31 (permalink) Old 08-04-2011, 10:11
Car: -
Where can I obtain numberplates like that ?
BLMC is offline
post #26 of 31 (permalink) Old 08-04-2011, 10:24
Having a different Rover outside my house every day ...People thought I was the Main Rover Dealer, so the number plate appeared at my door 1 day when someone found it lying about!
Yeah, the one below I had painted by Rover, because no other paints (or paint specialists) would/could match the 'ocean blue', and it was as cheap for Rover to paint it (& colour code mirrors) as it was to buy the paint from them, & then have it painted elsewhere. Plus Rover Dealer, made a fantastic job of it, far exceeding what I had expected.
post #27 of 31 (permalink) Old 15-05-2011, 13:15
Car: MG ZR160
thought id add mine too from my old 25. i used different mesh
de chroming is a *****, but defo worth it. it will last so much longer
i used a stanley knife, heat gun and needle nose pliers. heating it up a bit gave the plastic a bit of "give" and i found i ddnt make any nicks. also, the chrome does seem to peel off easier
Popeye 89 is offline
post #28 of 31 (permalink) Old 02-06-2011, 16:08
Buy lots of stanley knife blades prior to doing this, the tips dont last long, and wear gloves, the chrome is sharp as ****!
That grade of mesh is cool as **** but a real fly catcher
RossSherwood is offline
post #29 of 31 (permalink) Old 19-03-2012, 21:37
Car: Rover Streetwise
Love the mesh there Popeye 89! Out of interest where did you get it from - thinking of doing it myself!
George1111 is offline
post #30 of 31 (permalink) Old 02-04-2012, 16:07
Car: MG ZR160
ebay mate. only got it because it was a bit different to everybody else
and yeah it was a real fly catcher.
this time around i havent meshed the grille, not sure i will tbh
post #31 of 31 (permalink) Old 26-12-2015, 17:44
Car: MK1 ZR 105, and MK2 ZR 105
just reading your comments about the chrome on the outer grille, is it an actual metal coating or is it plasticy? if its some sort of sprayed on plastic like in a model kit then soaking it in bleach will dissolve it
another thing, can a ZR mesh be easily fitted?
161racer is offline
Meshing the grille Jabo Rover 600 6 17-11-2008 19:29
Lower Grille Meshing Dupont Rover 600 4 23-06-2008 13:38
Meshing Grille imroberts MG ZR / Rover 25, 200 & Streetwise 3 10-10-2006 13:56
Meshing A 25 Grille michaelb MG ZR / Rover 25, 200 & Streetwise 10 29-04-2004 18:39
meshing the grille adamgroves Others 5 11-11-2002 19:17
