General Pektron SCU/BCU - Page 15 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 140 votes, 5.00 average. Display Modes
post #281 of 297 (permalink) Old 01-10-2016, 16:46
I have a Rover 45 mk1 2002 2.0iTD. I already bought the replacement relays but I need to understand how to find the SCU. I already dismantled the central console as you can see in the picture. Can you help in letting me know where it is or if the part from the 2nd picture is the SCU ( it is not written on it SCU ).
Thanks!!!
https://drive.google.com/open?id=0B2...GhtNkxyV3kzb1k
https://drive.google.com/open?id=0B2...Us3RTFMeWRpQVU
rearhorse is offline
post #282 of 297 (permalink) Old 01-10-2016, 17:15 Thread Starter
Mmmm....Rover..
technozen's Avatar
A Mk1 45 will not have the SCU fitted, it was only introduced on the Mk2 from 2003 onwards.
The earlier module, which you have found is called a 5AS, it doesn't suffer from relay failure and is very reliable.
What problems are you having??
technozen is offline
post #283 of 297 (permalink) Old 02-10-2016, 19:13
When I am trying to open the door from the remote, the drivers door won't open, the other doors are opening. With the key will open. When entering the car it happens that the red led from the dashboard to remain on. If I am pushing the open button from the remote will go off. When trying the start the car you can see that the hazard ( orange engine light ) flickers and it make that noise and I can not start the engine. Few days ago it was present also a beep and it was flickering also the light from the glow plugs. In the movie 2 you can see what is happening when trying to open the doors from remote.
The lights that are coming on you can see in the picture ( here under is the link). This happened 2 weeks ago after the car being parked for 2 days, it started fine untill now.
I already checked the plugs under the bonnet and under the dash, tried to reset the remote and ecu from remote and entering the securing code, I changed the battery from the remote, checked also with the spare one and charged the car battery just to be sure. I remarked the sound of clicking under the central console. The horn is not working.
Can you please help me? I was thinking it is the relay and this why I ordered it.
movie 1: https://drive.google.com/open?id=0B2...y13WWVzQUhzTWs
movie 2: https://drive.google.com/open?id=0B2...FZKQ2xqN3Z4eHc
picture: https://drive.google.com/open?id=0B2...XVlU2VnOTktdW8
post #284 of 297 (permalink) Old 03-10-2016, 06:39
On the first looking, to me this looks like bad earth somwhere. There are two earth points above lever for opening the bonnet. Might be worth to look into them.
Roverlike is online now
post #285 of 297 (permalink) Old 06-10-2016, 16:54
The earth near the battery is ok. Where are the other earth points? When I am trying to start the engine there is a sound coming on, if I switch on the lights it stops, but the headlights are not coming on. Is this related to a shortcircuit or earthing? Thanks
post #286 of 297 (permalink) Old 06-10-2016, 19:47 Thread Starter
Mmmm....Rover..
technozen's Avatar
I am in 100% agreement, this is a main wiring or voltage issue.
It isn't an 5AS or electronic module fault.
The negative battery cable is bolted to the chassis above the headlight, check where the wire is crimped into the
metal terminal, this is a known problem area.
post #287 of 297 (permalink) Old 25-11-2016, 14:53
Lost keyfob
Hi i have lost my only key fob and i have the problematic 2005 facelift version of the rover 25. its an oval key fob which has three buttons to also operate the boots. I have been to two rover specialist garages/xpart dealers and called every autolocksmith in my region (West/North yorkshire) and they cant help. Its only done over 60k miles and the it runs well but I am considering selling it for parts.
I am having to use the EKA everytime before i am able to start the engine. The immobiliser arms itself automatically in a few minutes if unused and keys out of ignition.
Is there any cheap solutions to this? Ive considered duplicating my keys, leaving one in ignition and the other to lock/unlock doors... not sure if that will still sound the alarm as temporary solution.
Otherwise, just persist with inputting the EKA everytime (and wait for the 5 minute lockout everytime) after purposely disabling the alarm (havent looked into this yet but thinking of opening the alarm box to damage the speaker cone without messing with the electronics... alarm still sounds even after disconnecting main car battery).
amsleeping is offline
post #288 of 297 (permalink) Old 25-11-2016, 16:51 Thread Starter
Mmmm....Rover..
technozen's Avatar
It isn't possible to program a new fob to an SCU that is armed, a stupid design feature.
I have sent you a PM.
post #289 of 297 (permalink) Old 15-12-2016, 13:54
Cool Technozon maybe answer me on here :D
Hello everybody is it possible to change pektron unit to lucas 5as or something else even with ECU of the same unit included i saw many of this set's on ebay u think this is also can be solution instead of those pektron's units ?
s.afify is offline
post #290 of 297 (permalink) Old 15-12-2016, 18:06
It is 'possible', but you would need to rewire most of the car - not only is the Pektron Systems Control Unit in a different place from both the 5as and the Multi Function Unit it replaces (so the wiring to the various electrical components wont be routed/finish in the same place), but the way some systems are operated is different too. On top of that, the later facelift centre console switches have different connectors, and even where connectors appear the same or similar (as on the Pektron equipped late pre facelift cars), you sometimes find the way they are wired is different.
Why do you want to replace the SCU? The problems that do occur are well documented, and for the most part reasonably cheap and easy to repair; many of which are covered in this thread. Technozen can repair nearly all SCU faults short of a completely fried unit.
david.anthony likes this.
post #291 of 297 (permalink) Old 16-12-2016, 08:17
Well , actually my unit been already with technozon for repair and when i have it back check all was work first time as normal immo Led behave normal and car want to start but once i tried to start just hear cranking and after PCU make one piep voice then again same problem i went to check every thing in the car and found already issue like the famous tailgate wiring loom problem and have fix it and loom of the left door was no't good contact and been fixed but i still have strange problems like flashing light of one side of the car ( left side ) some times get warrning voice every one second from PCU also fob no't responding at all no't lock or unlock i disconnect door looms of all 3 doors which i have and check the continuity of all 3 and also behind dashboard but nothing appear to be wrong also ground of the car in all places all seems ok but only the alarm voice of this unit and clicking voice make me thinking of change the whole system ,i knew maybe the car model no't worth this much try at this time but i done too much things in this car befor with no mechanic problem ML5 gasket and remote thermostat and car have only 81 miles on it , U say it's possible but the modification of the loom because of Lucas 5as have separate units and pektron have all in one unit !!!
I would like to know if the modification have to be for the replacement units only and center console or something else should be changes to do this ? i can't see any body speak about this over here but it may be happens !!!!!
Sorry about my English :S
s.afify is offline
post #292 of 297 (permalink) Old 22-12-2016, 00:34
Originally Posted by technozen View Post
I also found this excellent thread posted by harbottle.
It covers the repair of the SCU fitted to an MG TF115, the central locking relay had failed.
Clicky...
Got a problem with my ZS if you think you can do anything with it mate car is immobilized at the moment. Locked it up as normal but next morning had following faults....
1. Key fob will only open boot and lock car.
2. Central locking button in car no longer works at all.
3. Alarm cant be switched off and car immobilized.
Ive checked the fob with a key reader at work all 3 buttons are sending out RF signals do you think there's anything you can do to help unfortunately dont have any codes from the fob for programing etc
JOHNDQ is offline
post #293 of 297 (permalink) Old 22-12-2016, 00:53 Thread Starter
Mmmm....Rover..
technozen's Avatar
Sounds like the central locking relay in the SCU has failed...
But this shouldn't stop the car from starting, what happens when the ignition
is turned to position II?
post #294 of 297 (permalink) Old 22-12-2016, 08:27
Nothing mate can turn ignition on but doesn't stop alarm or immobilizer I'm thinking maybe the key reader has failed to?
JOHNDQ is offline
post #295 of 297 (permalink) Old 22-12-2016, 08:54 Thread Starter
Mmmm....Rover..
technozen's Avatar
You should have the two-tone chime with the ignition on, what happens if you press the fob unlock button at that point?
post #296 of 297 (permalink) Old 22-12-2016, 08:56
Not a sausage No alarm tone tho. Thanks for your time by the way
JOHNDQ is offline
post #297 of 297 (permalink) Old 22-12-2016, 09:16 Thread Starter
Mmmm....Rover..
technozen's Avatar
Something isn't right?!!!???!
The SCU either recognises the fob or it doesn't, there isn't separate programming for the three buttons.
Therefore if the lock and boot release buttons work but the unlock button does nothing it would point to a fob fault.
The only thing I have encountered that causes strange faults is a damp or wet alarm sounder, I would suggest that
you disconnect this, reset the SCU by removing and reinserting Fuse 1 in the drivers fusebox and see what happens.
post #298 of 297 (permalink) Old 22-12-2016, 10:03
Thanks mate I had to remove sounder as couldn't stop alarm going off. Will try it see what happens if no like can you test the bcu/fob
JOHNDQ is offline
SCU/BCU problem Loader MG ZR / Rover 25, 200 & Streetwise 2 20-09-2012 14:11
Pektron Clock hoof-hearted MG ZS / Rover 45 & 400 12 30-03-2011 23:22
is it a bcu scu issue??? paulryan1234 MG ZS / Rover 45 & 400 17 24-03-2010 13:26
Lucas or Pektron MGKayaker MG ZR / Rover 25, 200 & Streetwise 38 22-02-2010 19:04
pektron remotes roger1984 MG ZR / Rover 25, 200 & Streetwise 0 03-11-2009 19:09
