General Pektron SCU/BCU - Page 2 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 140 votes, 5.00 average. Display Modes
post #21 of 297 (permalink) Old 14-02-2011, 21:19 Thread Starter
Mmmm....Rover..
technozen's Avatar
Yes, I can now supply a better quality replacement relay, PM me for details.
A replacement SCU would need to be programmed to the car and also have new fobs coded to it.
technozen is offline
post #22 of 297 (permalink) Old 16-02-2011, 18:15
Car: ZS+115 TD
With regards to replacement scu boxes. When replacing them are the all the same.. As in will one off a V6 work on the diesel model or do they all have their own unique scu with different part number? I have to replace the one in my zs diesel and have noticed one on ebay complete with fobs off the V6 for 100 which would be bargain for me! Assuming it would work of course
Wackyschild is offline
post #23 of 297 (permalink) Old 16-02-2011, 18:19
Question SCU Removal
Where is the SUC located on my facelift 45, and how do I remove it?
Peapilotreturns is offline
post #24 of 297 (permalink) Old 16-02-2011, 21:11 Thread Starter
Mmmm....Rover..
technozen's Avatar
The SCU is located behind the centre console, this will have to be removed to gain access.
post #25 of 297 (permalink) Old 16-02-2011, 21:15 Thread Starter
Mmmm....Rover..
technozen's Avatar
The SCU and the engine ECU share a digital security code for immobiliser purposes, if you replace only one unit then this code will no longer match and the result is an engine that won't run.
You either have to match the pair with diagnostic equipment or swap the original units for a complete matched pair taken from another vehicle, the engine types will have to be the same of course.
The SCU units are all the same.
post #26 of 297 (permalink) Old 16-02-2011, 22:06
Car: ZS+115 TD
That is interesting, in truth it is what I was hoping for. So if I understand correct I can buy the scu with fobs off ebay, then get someone with a T4 to get it to talk to my engine ecu and then all should be OK.. is there any potential problems with this?
post #27 of 297 (permalink) Old 16-02-2011, 22:17 Thread Starter
Mmmm....Rover..
technozen's Avatar
No potential problems, provided the SCU can be disarmed (if need be) with the fobs then programming via diagnostics should be straightforward
post #28 of 297 (permalink) Old 16-02-2011, 22:20
Car: ZS+115 TD
Thumbs up
Brilliant thanks very much for your advice, much appreciated
post #29 of 297 (permalink) Old 24-03-2011, 11:18
I've had problems with my central locking and alarm so took out the scu and found it has burn damage around the connector on the central locking side. The little resistor to the right of the connector (and below the central locking relay) is missing. Does anyone know what value it should be?
Simon
Med_tech3 is offline
post #30 of 297 (permalink) Old 29-03-2011, 02:53
Car: -
technozen have you got a thread where you have dissected one of these ?
BLMC is offline
post #31 of 297 (permalink) Old 29-03-2011, 08:52 Thread Starter
Mmmm....Rover..
technozen's Avatar
I did a detailed pinout for the MFU some years ago.
As for dissecting it... no real point, they are so cheap to buy and the same unit is fitted to so many models, plus there is no programming involved when they are swapped.
post #32 of 297 (permalink) Old 29-03-2011, 14:42
Car: -
Exactly, I was thinking about using the internal relays for other devices.
BLMC is offline
post #33 of 297 (permalink) Old 29-03-2011, 16:03 Thread Starter
Mmmm....Rover..
technozen's Avatar
Do you mean...
taking the relays out to use as parts?
or
using an MFU to do other functions?
post #34 of 297 (permalink) Old 29-03-2011, 17:34
Car: -
Use the MFU to do other functions.
Just wondering how many and what sort of relays it contains.
BLMC is offline
post #35 of 297 (permalink) Old 30-03-2011, 11:07
Car: 160
technozan is there any chance i could buy a peckton drivers window relay ??
nigey82 is offline
post #36 of 297 (permalink) Old 02-04-2011, 20:21
Car: Commision Number 14694
Courtesy light control
I am hoping for your advice on getting my interior lights working after I shorted the bulb terminals in the underfloor storage of my 2003 ZTT cdti.
I have severe arthritis in both hands and when replacing a blown festoon bulb recently I managed to short the bulb holder terminals with the result that all internal lights have failed. I have a pre facelift model with the later type fuse box containing 54 miniature fuses, and have tested nearly every fuse in it to no avail. Since I have the later fuse box, I imagine it is likely that the Pectron type BCU is also fitted, in which case I would suspect the low side driver marked 'B' in your photograph to have died.
Would you agree with this diagnosis or am I looking in the wrong place?
Any help or advice you may be able to offer would be greatly appreciated.
Many thanks.
derek999 is offline
post #37 of 297 (permalink) Old 02-04-2011, 22:41 Thread Starter
Mmmm....Rover..
technozen's Avatar
I didn't think the 75/ZT used the same Pektron unit.
Generally if the control transistors fail they go short circuit which results in the circuit being "on" all of the time.
Have you checked the fuses?
post #38 of 297 (permalink) Old 02-04-2011, 23:05
Car: -
The Rover 75 is a canbus system.
BLMC is offline
post #39 of 297 (permalink) Old 15-04-2011, 18:24
Woof Woof
Wonderful informative thread. Why oh why do these cars need so much electronics these days? Because they can I suspect.
barkingdog is offline
post #40 of 297 (permalink) Old 22-04-2011, 14:06
Really useful thread - thanks
Technozen - YHPM.
Steve_PPP is offline
SCU/BCU problem Loader MG ZR / Rover 25, 200 & Streetwise 2 20-09-2012 14:11
Pektron Clock hoof-hearted MG ZS / Rover 45 & 400 12 30-03-2011 23:22
is it a bcu scu issue??? paulryan1234 MG ZS / Rover 45 & 400 17 24-03-2010 13:26
Lucas or Pektron MGKayaker MG ZR / Rover 25, 200 & Streetwise 38 22-02-2010 19:04
pektron remotes roger1984 MG ZR / Rover 25, 200 & Streetwise 0 03-11-2009 19:09
