General Pektron SCU/BCU - Page 3 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 140 votes, 5.00 average. Display Modes
post #41 of 297 (permalink) Old 01-05-2011, 07:30
Pektron
Hi you mention that you can now supply new replacement relays for the Pektron SCU - 25% discount for .org Supporters - PM for details.
Could you supply the deatails please as I am in need of two such beasts.
Kind regards, Dennis Broom.
dbroddlo is offline
post #42 of 297 (permalink) Old 03-05-2011, 09:11
scu realys
Originally Posted by technozen View Post
I have made a few enquiries regarding replacement relays.
Pektron don't really want to know...
Hello Paul
Unfortunately are not able to sell just relays but as this is a spares
product you can still purchase the SCU from Caterpillar Xpart who deals
with Rover spares.
Hope this helps.
Kind Regards
Carole Davies
Customer Service Co-ordinator
Strange that they point me towards XPart when their own spares section lists the SCU as a complete item available for 125.
Willow Electronics have not replied... so annoying.
An American component supplier have been extremely helpful, hopefully it will bear fruit.
you can get relays off E.bay i just did worked a treat, just type in pekron replacement relays, and up it pops 7.86 each, i ordered them and got them next day., and my zr td has everything working, one point these new ones are 40amp load which are better than the silly originals, so i replaced them all, you will need to unsolder the old one,s and resolder in new one's, or you could get a rover dealer to do it and charge you for a recon board, like one of them tried with me, hmmmm 300 not think so. also when i refitted the scu box back to car i covered it with a water proof bag worth doing. if anyone is having problems doing this you could send box to me on next day post and i'd fix it and send back next post, email;terry.wilkinson67@btinternet.com.
tezmike is offline
post #43 of 297 (permalink) Old 22-05-2011, 16:36
Car: Mk2 ZS T16 turbo
Send a message via Yahoo to pscott
Interesting post.
I am trying to convert a mk2 zs from manual to electric front windows, the installation of components has been fine, however I can't get either of the front windows to operate, is this likely to be a failed relay in the scu, or do I possibly have a problem elsewhere.
All advice gratefully received.
pscott is offline
post #44 of 297 (permalink) Old 22-05-2011, 16:57 Thread Starter
Mmmm....Rover..
technozen's Avatar
The SCU has to have the windows "enabled".
This in turn activates the SCU control of the external relay which supplies 12 volt power to the windows and it also enables the Drivers window relay within the SCU.
technozen is offline
post #45 of 297 (permalink) Old 22-05-2011, 16:59
Ah right.
Thank you for the quick reply, someone else has also suggested this might need doing, now to find someone to do it.
pscott is offline
post #46 of 297 (permalink) Old 22-05-2011, 21:57
Car: MG ZS 180 MK2
Smile
I'm not sure it's that straightforward, you need to find someone with T4 diagnostics to do it I believe?
I take it your ZS is a 110 or 120? Mine has been fitted with aftermarket electric windows and someone has made a right hash of the wiring. Thinking it couldn't of worked on my scu, so they wired the windows to the cigarette lighter via a 30amp fuse.
Marky Mark is offline
post #47 of 297 (permalink) Old 13-06-2011, 17:24
I have a few original relays, PM me if you need one.
Can you get me a fujistu relay for fogs and horn please. Also can you ID the cables for fogs and horn as I want to do a temp swap to get horn working to get me back to UK.
MaccaMG&Healey is offline
post #48 of 297 (permalink) Old 13-06-2011, 17:59
plektron
my plektron scu has fried the motherboard any one no were to get one every thing works exept c locking
les1 is offline
post #49 of 297 (permalink) Old 14-06-2011, 19:19
Car: Ford Focus ST
Evening all,
I've only got one fob left with my '05 ZR. I bought 2 new fobs (sealed with barcodes on packaging) and went to MG Silverlink to enquire about costs. They said there's only a 50% chance of successfully linking them together without the SCU going scatty and going into lock down mode. Is there any truth in this? I'm a bit wary about going with only 1 fob for so long!
Liquidfox is offline
post #50 of 297 (permalink) Old 14-06-2011, 19:24
Car: -
Originally Posted by Liquidfox View Post
Evening all,
Yes .
BLMC is offline
post #51 of 297 (permalink) Old 15-06-2011, 20:12
I used www.mgroverservices.co.uk they enabled all the functions in the scu, and coded 2 new fobs, 100% success.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
pscott is offline
post #52 of 297 (permalink) Old 14-07-2011, 20:14
mgzs scu horn prblems
it would appear that my horn is stuck on once pressed untill engine is turned off and restarted is this the relay faulty
tomandmel is offline
post #53 of 297 (permalink) Old 14-07-2011, 20:29 Thread Starter
Mmmm....Rover..
technozen's Avatar
No, this is usually caused by a faulty IC which controls the relay.
This IC, a TPIC6C595, is marked as "D" in the pictures at the beginning of this thread.
post #54 of 297 (permalink) Old 20-07-2011, 21:23
Smile Pektron SCU
Thankyou for a fast informative reply, I believe I have a friend that can swap the ic for me however I am strugling to find the exact part to purchase can you suply or point me in the right direction
Are you also able to tell me where on the car is the SCU? is it behind the glove box somewhere ?
post #55 of 297 (permalink) Old 20-07-2011, 22:00 Thread Starter
Mmmm....Rover..
technozen's Avatar
The IC is available from Farnell....
http://uk.farnell.com/texas-instrume...33v/dp/1651926
...and RS...
http://uk.rs-online.com/web/p/counte...ister/0526909/
On the ZS the SCU is fitted behind the centre console.
post #56 of 297 (permalink) Old 20-07-2011, 23:53
...and RS...
Is it going to be the ic that is faulty as my fog lights turn on and off as they should its only the horn sticking on. These are definatly controled by the same IC? I have ordered some of these ic's to try. Do I Need to remove the cenre console to get to the scu. Once again thankyou for the order details
post #57 of 297 (permalink) Old 22-07-2011, 20:29 Thread Starter
Mmmm....Rover..
technozen's Avatar
This IC can control up to 8 separate items, such as the relays fitted to the SCU.
A single channel in the IC can fail yet the other 7 channels continue to operate properly.
The horn fault is quite common with the SCU, I have never known it to be anything other than the driver IC.
post #58 of 297 (permalink) Old 03-08-2011, 15:09
I've just replaced the drivers window relay and it's again working now Thanks technozen for this thread and the relay I got this morning, great stuff.
celeronmanuk is offline
post #59 of 297 (permalink) Old 12-09-2011, 20:48
hello i was wondering if you still have replacement relays for the pektron scu or if you dont do you know where i would be able to get them from
mhodgy is offline
post #60 of 297 (permalink) Old 02-10-2011, 19:32
Red face Alarm wont sound
Hi
I have a 2005 tf problem where my alarm wont sound the hazards flash but no horn. the horn works fine in everyday use but nothing when alarm is activated. Wiring diagrams show a power sounder with battery back up, but the manual talks about it sounding the horns under the bonnet. Any help/info would be much appreciated, thanks.
simesr9999 is offline
SCU/BCU problem Loader MG ZR / Rover 25, 200 & Streetwise 2 20-09-2012 13:11
Pektron Clock hoof-hearted MG ZS / Rover 45 & 400 12 30-03-2011 22:22
is it a bcu scu issue??? paulryan1234 MG ZS / Rover 45 & 400 17 24-03-2010 12:26
Lucas or Pektron MGKayaker MG ZR / Rover 25, 200 & Streetwise 38 22-02-2010 18:04
pektron remotes roger1984 MG ZR / Rover 25, 200 & Streetwise 0 03-11-2009 18:09
