Rover 200 / 400 Rover 200/400 - My heater Fan doesn't work on speeds 1,2 & 3 - "How Do I?" - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 49 votes, 4.98 average. Display Modes
post #1 of 768 (permalink) Old 03-01-2005, 12:49 Thread Starter
Post Rover 200/400 - My heater Fan doesn't work on speeds 1,2 & 3 - "How Do I?"
We get this question pop up many times.
Here's a short article on "How to" replace the heater fan resistor pack on a 1995> Rover 400
Remove the glovebox. Two 8mm bolts secure it at the lower hinged edge. Remove the bolts, press the catch and out comes the glovebox. Magic!
post #2 of 768 (permalink) Old 03-01-2005, 12:53 Thread Starter
Here's the culprit.
Release the connector, it's quite tight.
Move the cable aside, to allow access to the securing screws.
Undo the two screws, a stubby cross-head screwdriver is best for this, as the dash moulding gets in the way.
post #3 of 768 (permalink) Old 03-01-2005, 12:55 Thread Starter
Carefully remove the resistor
The fault is plain to see.
Refitment is a simple reversal of the above process.
post #4 of 768 (permalink) Old 03-01-2005, 17:40
Send a message via MSN to sjc59
This is quite handy as my heater has just packed up and only works on 3 and 4 not 1 or 2, do you have any handy parts numbers so i can go buy the right part? Also how much is a new one?
sjc59 is offline
post #5 of 768 (permalink) Old 03-01-2005, 18:35
Car: Volvo S60 R, Rover 25 1.8Auto, VW Passat TDi Estate (Until I get rid of it)
Send a message via MSN to santa20
hehehe I couldnt find the bolts when I did mine, and it was a rainy day, so ended up sitting in the seat unside down, and tried to look under it whilst unbolting it, god it killed my back lol
santa20 is offline
post #6 of 768 (permalink) Old 04-01-2005, 05:42
Car: 75 Conn. S.E. CDTI
i dont know the part number sorry but i got one a few weeks ago and it was about 26 or 27 if i recall correctly!
marley is offline
post #7 of 768 (permalink) Old 04-01-2005, 19:28
MGJohn's Avatar
Excellent illustrations Major - Thank you.
As it happens, one by one the five speeds on my 1985 Montego Turbo's heater fan packed up this winter. Speed number 4 the last to do so. I know access means complete removal of the whole fascia which is about half an hours work. Having done that, as I'm handy with the soldering iron I now wonder is there a relatively easy resistor fix or do I wait for one to turn up in a local breakers and get that?
Any advice here appreciated.
B>>M>>W ....
MGJohn is offline
post #8 of 768 (permalink) Old 04-01-2005, 21:05 Thread Starter
I remember replacing those resistors years ago! Split the heater box itself to replace it!
Not sure about any workarounds though, John.
post #9 of 768 (permalink) Old 04-01-2005, 23:32
Car: MGF MK2 1.8i,BMW 330i
Dont suppose someone could help me with the same problem on a 214si. only works at 3 and 4 in SO's car and it is very annoying as 3 and 4 are quite loud!
cheers and happy New Year
Broon is offline
post #10 of 768 (permalink) Old 05-01-2005, 19:23
Mmmm....Rover..
technozen's Avatar
Well done Major!
Broon, the procedure is the same for the 200 series.
sjc59, here are the part numbers.......
200 series.......... JGM10002
400 series.......... JGM100050
technozen is offline
post #11 of 768 (permalink) Old 05-01-2005, 20:07
Car: none
Cool thread Major!
Everytime I see one of the resistor packs I think they look really primitive, with just the bendy metal on there to increase resistance. Now as you've probably gathered I know very little about electrics etc but surely something a bit more hi-tech can be thought up, maybe using proper resistors or something? Maybe a good mod?? Do the new rovers like the 45/75 use this style resistor pack?
Also, would resoldering the 'springs' fix a blown one?
mikew7790 is offline
post #12 of 768 (permalink) Old 06-01-2005, 02:02
Cheers for the info, now I just need a dry weekend to have a bash at it.
Broon
Broon is offline
post #13 of 768 (permalink) Old 06-01-2005, 06:35 Thread Starter
Yes, probably but the solder would melt fairly quickly as the coil heats up. Thought about doing it on this one, but thought better of it.
post #14 of 768 (permalink) Old 06-01-2005, 12:33
Cheers guys gonna go order me one 2moro and give it a go. I agree they must be a better modern option to fix this.
sjc59 is offline
post #15 of 768 (permalink) Old 06-01-2005, 13:27
mine had the same problem, not working in positions 1 and 2. I went yesterday to a scrap and got one for 3, yes three poonds.
it was raining heavily... i thought about doing it in a sunny day..but i might be waiting for a long time , especially in Glasgow!!
TAHER is offline
post #16 of 768 (permalink) Old 09-01-2005, 01:49
Mmmm....Rover..
technozen's Avatar
I had to sort this problem on a mates 200 today, rather than buying a new resistor pack I decided to replace the resistors using standard ceramic resistors. I had already done this on my own car a while ago.
More details to follow, Dave I used some of your pics in the tutorial I made up.
post #17 of 768 (permalink) Old 09-01-2005, 06:41 Thread Starter
No problem Paul, good stuff!
post #18 of 768 (permalink) Old 09-01-2005, 12:27
Car: none
Thats brilliant, Paul - any plans on selling them ?
Mine is stuffed on setting number one at the moment, once number 2 goes i'll use your mod!!
Thanks..
post #19 of 768 (permalink) Old 03-02-2005, 09:55
Car: ZS180/R45 2.0TDi
Stupid question time, any need to disconnect the battery to do this?
parsec is offline
post #20 of 768 (permalink) Old 03-02-2005, 10:31
Mmmm....Rover..
technozen's Avatar
Not really, there is no power at the resistor pack connector as long as the ignition is in the off position.
rover 100 heater fan speeds gator Metro / Rover 100 10 22-08-2014 08:33
Heater fan not workin on speeds 1 & 2 ChrisCoupe 'R8' Rovers (aka Wedges!!) 23 17-05-2010 15:20
Rover 200 / 400 Heater Fan Probs Mr T series MG ZR / Rover 25, 200 & Streetwise 12 06-12-2009 11:54
Heater fan speeds 1 - 3 bob.s MG ZR / Rover 25, 200 & Streetwise 4 27-07-2008 18:44
fan heater speeds 114-gsi Metro / Rover 100 1 27-01-2007 12:43
