Rover 200 / 400 Rover 200/400 - My heater Fan doesn't work on speeds 1,2 & 3 - "How Do I?" - Page 2 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 49 votes, 4.98 average. Display Modes
post #21 of 768 (permalink) Old 03-02-2005, 10:39
Car: ZS180/R45 2.0TDi
Originally Posted by technozen
Not really, there is no power at the resistor pack connector as long as the ignition is in the off position.
And there's no other live systems round there? I suppose it wouldn't matter anyway, apart from the ignition system everything else is low voltage right?
parsec is offline
post #22 of 768 (permalink) Old 21-02-2005, 19:57
Car: none
I had to sort this problem on a mates 200 today, rather than buying a new resistor pack I decided to replace the resistors. I had already done this on my own car a while ago.....
It can be downloaded here.
Hi Paul
My heater pack has failed and i'm going to follow your tutorial but i'm stuck already LOL.
mikew7790 is offline
post #23 of 768 (permalink) Old 21-02-2005, 21:52
Mmmm....Rover..
technozen's Avatar
Sorry....might not be too clear...
you will need a total of 3 resistors.....I gave four alternative part numbers..
so 3 of the first....Maplin H1R....OR 3 of Farnell 3270555 OR etc...etc.
you dont need one of each!
I have sent you a PM which might help.....
***The resistor values have been superceeded by ones closer to the manufacturers original values, please see posts further in this thread.***
technozen is offline
post #24 of 768 (permalink) Old 21-02-2005, 23:12
Car: none
Ahhh - thats me being thick more than you not being clear.. I didn't even notice that there were only 3 resistors in the pic! doh..
post #25 of 768 (permalink) Old 23-02-2005, 10:45
Car: Rover 200 (-95)
Exclamation
Great British engineering.
Shanghai Automotive must be dying to get their hands on this..
--Alan
AlanC is offline
post #26 of 768 (permalink) Old 26-02-2005, 18:29
Car: none
Yay!!!!! All my heater settings work now!!
Thanks Paul!! A well worthwhile 'mod'!
My handiwork ain't too pretty, but it works!!!
cheers
Mike
post #27 of 768 (permalink) Old 26-02-2005, 18:31 Thread Starter
--Alan
Ah, this type of failure happens to many cars, not just MGR, Alan..
post #28 of 768 (permalink) Old 26-02-2005, 18:32 Thread Starter
cheers
Mike
Well done Mike (Cheers to Paul!)
That's what we refer to as a "Result"
post #29 of 768 (permalink) Old 26-02-2005, 19:59
Mmmm....Rover..
technozen's Avatar
Oooohh......lookin forward to my "royalties" cheque in the post
Glad it worked Mike...well done!
post #30 of 768 (permalink) Old 03-03-2005, 14:45
Smile
My heater has just stopped working on 1 and 2. Didn't notice untill i started to get cold, will have to turn the music down. Thanks for the thread guys this seems a really easy mod to do. Will have a look in my scrap box, else it's a trip down to Maplins.
PhilG is offline
post #31 of 768 (permalink) Old 09-03-2005, 15:48
Richard Moss
Guest
Posts: n/a
VW are just as bad. I bought a LHD Mk2 Golf when I moved to Spain. The owner had had this problem, bought resistors from the VW agent (v. expensive) only to find that the RHD resistor which he'd bought was different from his LHD one on the car.
He just left the new one in the glove box - so I desoldered the new resistors, fitted them to the old LHD resistor pack and "voila" - a free fix for me.
Then the fan motor died - bearings sheared - so rather than spend 100 on a USED LHD one, I fitted one from a Rover 200 mk2 which cost 10! So at least the car had one classy part on board.
post #32 of 768 (permalink) Old 09-03-2005, 21:12
It does seem incredibly low-tech for a modern car. Low-tech is fine if it works, but it obviously doesn't in this case. It looks like the cheapest solution done quickly rather than an 'engineered' solution. Frustrating.
Just my tuppence worth.
--Alan
AlanC is offline
post #33 of 768 (permalink) Old 09-03-2005, 21:15 Thread Starter
Yeah, know what you mean Alan. This arrangement works but not for much more than 6 to 8 years....
post #34 of 768 (permalink) Old 10-03-2005, 12:18
Car: '99 Rover 200 Vi
This would be a perfect topic for the "How Do I" section .
Striker is offline
post #35 of 768 (permalink) Old 10-03-2005, 12:41 Thread Starter
Great idea....shall I move it?
post #36 of 768 (permalink) Old 10-03-2005, 13:05
I would - this thread was invaluable for me when I fixed my dad's R45 that had this problem.
We just need a few more now, door alignment and taking door cards off would be ace
parsec is offline
post #37 of 768 (permalink) Old 10-03-2005, 13:10
What are you waiting for .
Striker is offline
post #38 of 768 (permalink) Old 10-03-2005, 17:54 Thread Starter
Went back to work!
Moved....
post #39 of 768 (permalink) Old 05-04-2005, 14:31
wob
On the basis that the original resistors are gigantic, open, wire wound resistors that are designed to have lots of air freely moving across them, if I replace them with more conventional resistors as suggested above will this not cause a heat dissipation problem as the resistors will not have as much surface area but will still have a high amount of heat coming out of them???
Obviously there isn't much room for air to move very well, so I am concerned that I'll end up burning out more resistors (which could be why the original broke in the first place).... Not that it really matters at the cost of a couple of resistors every couple of years....
wob is offline
post #40 of 768 (permalink) Old 05-04-2005, 14:46
The resistor pack problem is also common to Nissans, Citruins and others.
I got one for a mkII 400 you can buy - a tenner inc postage if you're interested.
DD
Diesel Dick is offline
rover 100 heater fan speeds gator Metro / Rover 100 10 22-08-2014 08:33
Heater fan not workin on speeds 1 & 2 ChrisCoupe 'R8' Rovers (aka Wedges!!) 23 17-05-2010 15:20
Rover 200 / 400 Heater Fan Probs Mr T series MG ZR / Rover 25, 200 & Streetwise 12 06-12-2009 11:54
Heater fan speeds 1 - 3 bob.s MG ZR / Rover 25, 200 & Streetwise 4 27-07-2008 18:44
fan heater speeds 114-gsi Metro / Rover 100 1 27-01-2007 12:43
