Rover 200 / 400 Rover 200/400 - My heater Fan doesn't work on speeds 1,2 & 3 - "How Do I?" - Page 4 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 49 votes, 4.98 average. Display Modes
post #61 of 768 (permalink) Old 08-12-2005, 12:56
Car: Classic MG
Originally Posted by Stargazer
just had a go at mine, all I did was to re-attach the broken coil and it worked, yippee, no more gails , don't how long for though, not to keen on paying £5 delivery for a 25 p resistor from maplins
I tried reattaching the broken coil but the solder wouldn't take to the ancient coil !!
leegt5 is offline
post #62 of 768 (permalink) Old 08-12-2005, 12:58
Car: Rover 75 1.8T
I think it is coated in varnish or similar stuff, I used a knife to scrape it off or a file to make a clean surface
mercodus is offline
post #63 of 768 (permalink) Old 08-12-2005, 13:17
Mmmm....Rover..
technozen's Avatar
Originally Posted by technozen
I have changed the resistor values to give a smoother series of speed steps...
A 1.5 ohm, 0.68 ohm and a 0.22 ohm.
This also increases the lower 2 speeds, position 1 was far too slow with the original values.
As mentioned previously the 3 values listed above are the closest match to the original values used by MGR.
The original resistors are made of a special wire callled Constantan and it is difficult to solder.
technozen is offline
post #64 of 768 (permalink) Old 08-12-2005, 13:20
Mmmm....Rover..
technozen's Avatar
If anyone has trouble getting these resistors I can supply the lot for £XXX including P&P.
There are four resistors in total, two resistors are needed to achieve the 0.22 ohm value.
Thanks.
post #65 of 768 (permalink) Old 08-12-2005, 13:23
Car: Rover 75 1.8T
1.5 ohm, 0.68 ohm and a 0.22 ohm. Are these values positioned such as 1.5 on the left, .68 in the middle and .22 on the right?
mercodus is offline
post #66 of 768 (permalink) Old 08-12-2005, 13:31
Mmmm....Rover..
technozen's Avatar
Yes, that's correct.
post #67 of 768 (permalink) Old 08-12-2005, 13:35
Car: Rover 75 1.8T
thanks i'll bear that in mind, when my repair gives up the ghost
mercodus is offline
post #68 of 768 (permalink) Old 08-12-2005, 14:14
Car: Classic MG
Can I send you £1.80 then I know Im getting the right ones !! Only thing is I cannot PM you my address.... You could quickly go on www.rovercoupe.net and sign up and contact me (LEE on that site) !!
LEE
leegt5 is offline
post #69 of 768 (permalink) Old 07-02-2006, 09:58
Thumbs up
Great post guys.. my Civic (sorry) has done exactly the same thing. It did it when it was under warranty so perhaps 2 years old.. now it's almost 5 and it's happened once again. I took it out and yes the highest coil was broken and the smaller coil going from side to side was also broken. Before I found this post I had no idea what part was reponsible.. now I know how to make a new one.
Quick question.. does the zip file contain the latest info such as recommended resistor ratings.
I'll let you know how i get on.
Graeme
D15Z8 is offline
post #70 of 768 (permalink) Old 13-02-2006, 10:37 Thread Starter
If anyone has trouble getting these resistors I can supply the lot for £1.80 including P&P.
I might well take you up on that offer Paul if you still have some handy.
I have a couple of packs here that need repairing.
post #71 of 768 (permalink) Old 13-02-2006, 12:00
Can you tell me if its the same fix for a 2002 52 MG ZR please? number 1 & 2 on the heater just stopped working (still getting heat, but no fan to blow the air through) and if so, where is the resistor located please.
thanks
jasper is offline
post #72 of 768 (permalink) Old 13-02-2006, 15:07 Thread Starter
Thumbs up
Here - on a 400/ZS - your's is basically the same
post #73 of 768 (permalink) Old 13-02-2006, 20:33
Mmmm....Rover..
technozen's Avatar
How many do you need??
Don't forget I still owe you for a Headlight bulb
post #74 of 768 (permalink) Old 13-02-2006, 20:34 Thread Starter
Just three - enough to do one repair and see how it goes!
post #75 of 768 (permalink) Old 13-02-2006, 20:37
Mmmm....Rover..
technozen's Avatar
3 resistors or 3 sets????
Sod it I'll post 3 sets tomorrow
post #76 of 768 (permalink) Old 13-02-2006, 21:13 Thread Starter
Just enough resistors to do one repair!
post #77 of 768 (permalink) Old 13-02-2006, 21:19
Mmmm....Rover..
technozen's Avatar
Oh...ok then!!
I'll post em tomorrow.
post #78 of 768 (permalink) Old 23-02-2006, 15:21
Car: 135
can you send me a set plz technozen, it seems a common problem
and thanks for your posts
nobby66 is offline
post #79 of 768 (permalink) Old 27-02-2006, 19:13
Car: MGTF+WOLSELEY SIX
Flippin 'eck!! that was a quick response!! Thanks very much. Just found website tonight looks like it may prove very useful!! Thanks.
AJ the spray is offline
post #80 of 768 (permalink) Old 27-02-2006, 19:16 Thread Starter
No problem, pleased to have helped!
rover 100 heater fan speeds gator Metro / Rover 100 10 22-08-2014 08:33
Heater fan not workin on speeds 1 & 2 ChrisCoupe 'R8' Rovers (aka Wedges!!) 23 17-05-2010 15:20
Rover 200 / 400 Heater Fan Probs Mr T series MG ZR / Rover 25, 200 & Streetwise 12 06-12-2009 11:54
Heater fan speeds 1 - 3 bob.s MG ZR / Rover 25, 200 & Streetwise 4 27-07-2008 18:44
fan heater speeds 114-gsi Metro / Rover 100 1 27-01-2007 12:43
