Rover 75 / MG ZT/T Rover 75/MGZT Service Interval Reset *At your own risk* - Page 4 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 21 votes, 4.95 average. Display Modes
post #61 of 266 (permalink) Old 18-10-2005, 21:00
So what am i doin wrong i cant reset my service light using my high tech piece of wire (i even got some proper car wire) help please my car is reading _1924 at present
MADMICKY is offline
post #62 of 266 (permalink) Old 18-10-2005, 22:02
Double check the connector were you insert the wire. It should go *well* into No.8. If you are sure about that, make sure the timing for grounding it is done correctly. Read my previous post on this, I wanted to make sure I understood it right and seems I do.
Cheers,
JaX
WaveGuide is offline
post #63 of 266 (permalink) Old 18-10-2005, 22:11
RAVE CD-ROM has an error
Another point on this issue. The RAVE CD-ROM has an error in one of the diagrams of socket C0040.
In the Connectors listing, C0040 has the pinouts exactly as discussed in this thread, with Nos. 1 and 9 at the right hand end of the socket. However, under Rover 75/Communications and Data Buses/Description/Diagnostic Bus, socket C0040 is drawn with Nos. 8 and 9 at the same end.
So much for the RAVE CD! Is it known to have errors or is this likely a one off?
Cheers,
JaX
post #64 of 266 (permalink) Old 19-10-2005, 10:50
Unfortunately, there are a number of small errors throughout the disc I am afraid. We've found plenty on the MGF one for example
Rob Bell is offline
post #65 of 266 (permalink) Old 19-10-2005, 11:18
Ok, cheers Bob.
JaX
post #66 of 266 (permalink) Old 19-10-2005, 18:59
re service light reset i failed to say my service light reads -1925could this be why i am not able to reset it please help before i go mad !!!!!!!!!!!!!!!!!!!
MADMICKY is offline
post #67 of 266 (permalink) Old 19-10-2005, 19:14
As I understand it, negative values reset just like positive ones. Your problem must be in the timing used for the reset.
JaX
post #68 of 266 (permalink) Old 19-10-2005, 19:20
Still Confused on this
Going through the timings again, I'm now confused about what has been called an 'Oil Service PLUS an Inspection Service' reset.
My 2004 handbook says three conditions may be displayed.
Oil Service, or Inspection and there maybe a Clock logo (Brake Fluid change). I assume the Clock is a 'Time Service'. Is that correct?
How can you have an Oil Service AND an Inspection displayed together? Is the pre-2004 display different?
Cheers,
JaX
post #69 of 266 (permalink) Old 20-10-2005, 15:21
Confirmed.
You can reset ANY negative value at any time.
RichK is offline
post #70 of 266 (permalink) Old 20-10-2005, 19:05
Oil Service WITH Inspection Service?
I'm still confused about resetting an Oil Service WITH an Inspection Service because they alternate every 15,000 miles.
Surely you can't see both on the display at the same time?
I understand that each has the same 8-25 second reset, but my 2004 handbook says only four displays are possible.
Oil Service
Inspection
Oil Service + Clock sign
Inspection + Clock sign
Cheers,
JaX
post #71 of 266 (permalink) Old 22-10-2005, 16:29
Car: 2004 Mk2 ZS 200
Send a message via MSN to KevG Send a message via Skype™ to KevG
Well, I had a inspection sitting at 6275 and done the rest thing and now the Oil Service is sitting at 15000, I left the bit of wire in for a full 30secs or so......and mine is a R75 2.0V6 Classic on an 2000 (X), Just done a service on it about 1 month ago, and oil service 3 weeks ago, so superb bit of techy knowledge.
A pic of 2 of the Diagnostic sockets
1. Wrong Pinout as in Rave
2. Right pinout is in Connector views from Rave
KevG is offline
post #72 of 266 (permalink) Old 26-10-2005, 12:33
Finally it worked for a 2002 2.0CDT.
I have spent the last couple of days trying this and gave up many-a-time. The suggestion to use two paper clips (one straight and one bent) worked eventually. Keep trying, I must have tried 30 times or so with differing combinations. Try adjusting the depth in which the clips are pushed into the connector. Have both in place but not connected, as soon as the ignition is in position 2 and the service interval comes up, connect the two clips and hold for 10secs, then turn off ignition. Good luck!
Andy1968 is offline
post #73 of 266 (permalink) Old 26-10-2005, 16:29
e668ecp
Guest
Posts: n/a
I've got an OBD II connector and have soldered a switch onto some wire from the connector. Anyone near Leeds needs theirs doing send me a PM (free to members on here)
post #74 of 266 (permalink) Old 26-10-2005, 17:31
Car: MG ZT
Pins 4 and 8 do work on a zt 260
eurorover is offline
post #75 of 266 (permalink) Old 26-10-2005, 20:41
PERFECT solution!
Where'd you get the plug?
RichK is offline
post #76 of 266 (permalink) Old 27-10-2005, 07:22
e668ecp
Guest
Posts: n/a
Off ebay. I'll try and find the source - took me weeks!
post #77 of 266 (permalink) Old 27-10-2005, 12:59
Car: Moonstone Green Rover 75 CDT Tourer Conn SE with Upsolute remap and Synergy 2
Took me quite a few attempts to get it done. I wasn't sure if I could short pins 8 and 4 before turning the key or not. In the end it worked by shorting pins 4 and 8 only when the service indicator was displayed. Next time, I'll be due for an inspection - well the car that is.
Thanks for all the tips guys.
Pete
Isis is offline
post #78 of 266 (permalink) Old 27-10-2005, 14:12
Car: Rover 75 2 Litre Auto and XK8
Angry Why did I not look yesterday!
I paid for this information on e-bay only yesterday and found this forum today! What timing!
As good as when I bought my Rover 75 and within the Month ROVER had gone belly up! What timing again!
wackers is offline
post #79 of 266 (permalink) Old 28-10-2005, 15:08
Car: MG ZTT
Thumbs up
Works on a ZTT+ CDTi. Paper clip and a few goes. Need to shove it in the holes not just the terminals you can see
lbichard is offline
post #80 of 266 (permalink) Old 29-10-2005, 11:32
Car: MG ZT
Just tried this on MGZT CDTI 2003 and it worked a treat, service indicator was at -6200 and has resent to 15000
Beddie is offline
Service Interval Reset Mr Edd MG ZT / Rover 75 (Sponsored by Rimmer Bros) 12 27-11-2008 09:13
Service Interval Reset johna2303 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 28-01-2008 12:07
Rover 75 SE V6 Service Interval Schedule sih73 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 30-07-2007 11:43
Service interval reset on a 75... That ARG guy... MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 14-12-2005 11:15
service interval reset jvs MG ZT / Rover 75 (Sponsored by Rimmer Bros) 30 08-06-2005 11:00
