Sloppy PG1 Gear Linkage - How To fix it! - Page 12 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 55 votes, 5.00 average. Display Modes
post #221 of 224 (permalink) Old 13-06-2016, 12:50
Car: 45 2.0 Diesel
Originally Posted by richardsoniscoo View Post
Hi pal, have you got a picture of what you done? Was any welding needed
Cheers, mike
I only have one (bad) pic to hand, but here it is:
Absolutely no welding required for it, just some drilling and M6 bolts.
The part in question, looks like this:
It's quite easy to "liberate" from a scrap MG, just undo the two bolts, and then undo the steering column bracket. Go into "beast mode", give the column a good tug and it'll come off soon enough.
Then if you cut off the collar (blue in the picture), the two parts will separate and you're left with a UJ on a hollow shaft (which I cut the shaft in half lengthways and then bolted to my selector shaft) and a UJ on a rod, which could be welded on as per MG John's method.
Chrisund123 is offline
post #222 of 224 (permalink) Old 13-06-2016, 18:28
cheers, i think this may the way i go. unless anyone on here want to make me one
richardsoniscoo is offline
post #223 of 224 (permalink) Old 06-07-2016, 21:48
Unhappy sloppy gear stick "i wish"
hi guys i have just taken the gearbox out of my saloon mg zs 180 v6 2.5l and put it in my mg zs 180 2.5l v6 hatch back saloon is a 53 plate hatch is an 03 plate.
now io have a sloppy gear stick " ha ha ah if only" the gear stick is all over the shop i mean even when its in a gear the stick can move from first to revese all by its little self
revese is almost impossible to find. now before i start stripping it all can any guide me to the exact part that causing the issue the forward and back is sfine but no stability on the left to rigt its everywhere.
thank you in advance and sorry for highjacking but it seamed to be the same issue as this post but a little worse lol
Ffe Remap is offline
post #224 of 224 (permalink) Old 21-09-2016, 10:56
Anyone that have measured the inner diameter of the gear linkage bar from Rovers such as the 620ti and 600 Diesel? The outer diameter is about 22mm, but would really like to know the inner diameter. If anyone have done the mod with a welded stub on top of the bar, there should be easy access to measure the ID of the open hole.
heltfeil is offline
PG1 Quickshift and Gear Linkage chiesa Diesel Forum! 15 23-10-2008 09:57
is this what i need to fix my sloppy gear stick? Star 620 Rover 600 0 29-04-2008 13:15
pg1 gearbox linkage question devon vi MG ZR / Rover 25, 200 & Streetwise 0 25-11-2007 13:01
Rover 620 Diesel - Sloppy gearstick easy fix ? jasonc46 Rover 600 20 05-09-2007 22:01
PG1 Gear Change Linkage Hood994dwp Wanted 0 20-11-2005 13:28
