Sloppy PG1 Gear Linkage - How To fix it! - Page 4 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 55 votes, 5.00 average. Display Modes
post #61 of 224 (permalink) Old 18-05-2007, 15:37 Thread Starter
Car: Rover 200 Coupe
Originally Posted by Friggerpants View Post
Hey, you know the walkthrough, it has no pictures, can somebody get some please?
I want to do this as well as shorten the shifter and extend it at the bottom.
I need a UJ and what else?
pictures added
Hacksaw, file and apropriate spanners. - oh - and plasters as per instructions
The Mad Hat Man is offline
post #62 of 224 (permalink) Old 18-05-2007, 15:38 Thread Starter
Originally Posted by technozen View Post
Excellent mod, did it last night along with the two polyurethane bushes on the stabiliser linkage.
yup - poly bushes are the dogs wotsits.
post #63 of 224 (permalink) Old 18-05-2007, 22:21
Mmmm....Rover..
technozen's Avatar
Using the Mk3 200 universal joint I found that the "shorter" end fitted fine onto the gearbox selector shaft, it measures 14mm diameter approx.
The gear selector rod was larger in diameter, approx 16mm, so I needed to reduce it down to fit the U/J.
I managed to obtain a rubber hose from a washing machine at work which does a splendid job as a protective gaiter.
technozen is offline
post #64 of 224 (permalink) Old 19-05-2007, 07:08
If anybody wants a MK3 UJ I will have one available soon, probably bung it up on ebay.
post #65 of 224 (permalink) Old 16-06-2007, 15:19
C2K
Location: Preston or Peterborough depending on what day it is :P
Car: Rover 200 (-95)
I went to try this today, and my gearbox end is 14mm, whereas the selector shaft itself is 16mm. Neither end of the UJ taken from a 94 Coupe Turbo would fit the 16mm.
As above I was using a 94 steering column UJ and mine is a 94 Turbo. 16 mm selector rod shaft, and 14mm gearbox shaft. I too had to modify the gear selector rod to get it to fit properly. Certainly not as quick and easy as the tutorial.
1994 220 GSi Turbo.
C2K is offline
post #66 of 224 (permalink) Old 16-06-2007, 18:05 Thread Starter
It is a long time since i did the mod - but I am sure the Steering UJ had two different hole diameters. Maybe it is not the same for all UJ's - if any do not have 14 and 16mm holes please post what they came from and I will make a note on the tutorial.
post #67 of 224 (permalink) Old 17-06-2007, 09:56
C2K
Mine was a 94 Turbo, and the UJ was from a 94 Coupe Turbo. I can't see Rover having changed the part tbh, but it seems that both ends of mine were 14mm - perhaps Technozen found this too.
Knowing those brummies they probably used whatever was on the parts rack. lol.
C2K is offline
post #68 of 224 (permalink) Old 17-06-2007, 10:23
any chance of a part number please?
empsburna is offline
post #69 of 224 (permalink) Old 04-09-2007, 11:11
Send a message via MSN to boom Send a message via Skype™ to boom
what UJ would you use for a 620ti gearbox?
boom is offline
post #70 of 224 (permalink) Old 04-09-2007, 11:31 Thread Starter
UJ sizes
you will need to measure the diameter of your gearshift and the gearbox input shaft to determine this.
post #71 of 224 (permalink) Old 16-02-2008, 17:08
Car: Too many!
Send a message via MSN to FreddieS
Anyone reckon this might work?
http://cgi.ebay.co.uk/Land-Rover-Ran...QQcmdZViewItem
just because size wise the one we had on our old landy looked about the same, and it wouldnt suprise me if rover dipped into the parts bin?
FreddieS is offline
post #72 of 224 (permalink) Old 16-02-2008, 17:41
Mmmm....Rover..
technozen's Avatar
As a U/J it will certainly work, whether it would fit will depend on the internal diameter.
A bit expensive though...
post #73 of 224 (permalink) Old 18-03-2008, 19:53
Car: Lotus Elise S2 K Series, R26.R
Where's the univeral joint?
Am I right in thinking it's actually under the dashboard, in cabin?
Friggerpants is offline
post #74 of 224 (permalink) Old 18-03-2008, 23:21 Thread Starter
Yup
at the bottom of the steering column.
post #75 of 224 (permalink) Old 23-03-2008, 23:18
Originally Posted by The Mad Hat Man View Post
Yup
Cheers dude.
Gonna rip a couple off some mk3's and fit them on both my Rovers .
post #76 of 224 (permalink) Old 27-03-2008, 14:33
Sorry to revisit this thread - I've only just found the Forum. I have a 99 420 GSI TD. I have the usual rattling problem and it's getting worse and worse. It seems to be the UJ rather than the bushes at the lever end. Will I have the same box and linkage that's referred to in this thread? On what range of cars can I find the steering column uj? Is the uj at the top or bottom of the column? Is it easy to get off if I can find a car in the breakers?
Tks a lot
Paul
ptjs1 is offline
post #77 of 224 (permalink) Old 27-03-2008, 16:26
Mmmm....Rover..
technozen's Avatar
Welcome to the forum.
Your car will have the same gearbox and linkage.
I have only taken the U/J from the "bubble" Mk3 200 steering column, on this car the joint is at the base of the column before it exits through the floor.
It is easy to remove.
post #78 of 224 (permalink) Old 27-03-2008, 17:24 Thread Starter
I concurr entirely with Mr Technozen.
post #79 of 224 (permalink) Old 27-03-2008, 17:38
Car: MG ZS120(2005) ■■■■■□□□□□□
Tks a lot
Paul
If the only problem is a rattle, it may be worth just putting some grease in the existing uj first - a lot easier if it works, and it completely solved my rattle.
Windy is offline
post #80 of 224 (permalink) Old 28-03-2008, 15:27
Car: '98 420 GSi
Has the steering u/j got 2 open splined joints, and does fit over the sawn end of the link arm.
johnthemilk is offline
PG1 Quickshift and Gear Linkage chiesa Diesel Forum! 15 23-10-2008 09:57
is this what i need to fix my sloppy gear stick? Star 620 Rover 600 0 29-04-2008 13:15
pg1 gearbox linkage question devon vi MG ZR / Rover 25, 200 & Streetwise 0 25-11-2007 13:01
Rover 620 Diesel - Sloppy gearstick easy fix ? jasonc46 Rover 600 20 05-09-2007 22:01
PG1 Gear Change Linkage Hood994dwp Wanted 0 20-11-2005 13:28
