General Upgrading from 262mm to 282mm vented brakes for 200/400/25/ZR - Page 2 - MG-Rover.org Forums
post #21 of 44 (permalink) Old 09-01-2012, 06:04
Ok thanks you've been a lot of help do you happen to know if its possible to replace the rear drum brakes with the rear disks off the ZR 160
scottadoherty is offline
post #22 of 44 (permalink) Old 09-01-2012, 08:54
Car: MG Express
for that i believe you need to change the entire rear beam.
matrix MG is offline
post #23 of 44 (permalink) Old 12-01-2012, 18:05
Hello again this is my last question hopefully before I buy and fit the brakes and its this, will the 282mm set up fit inside the 15" alloy?
post #24 of 44 (permalink) Old 12-01-2012, 21:47
Car: MG Express
really not sure on thet one, iirc it's a very tight fit in the hairpins, so 15'' might be a bit small.
post #25 of 44 (permalink) Old 12-01-2012, 21:50
no it wont 16" or above.
proredcode is offline
post #26 of 44 (permalink) Old 12-01-2012, 22:13
They will fit under SOME 15 inch alloys. The 7 spoke SEi type wheels fit. It is close though!
post #27 of 44 (permalink) Old 13-01-2012, 08:16
I have these alloys sorry about the really poor picture.
post #28 of 44 (permalink) Old 13-01-2012, 08:31
post #29 of 44 (permalink) Old 13-01-2012, 11:48
do you know if they will fit under the fission rims?
cheers
mkultra is offline
post #30 of 44 (permalink) Old 14-01-2012, 12:02
no idea i'm afraid.
post #31 of 44 (permalink) Old 14-01-2012, 12:27
no idea i'm afraid.
There's only one way to find out then. thanks for the info
mkultra is offline
post #32 of 44 (permalink) Old 14-01-2012, 14:44
In order to fit they have to have a "flat face" to clear the calipers. If the face is curved back towards the centre of the car then chances are they won't fit.
The SEi alloys are VERY close. Some pillock when they balanced my wheels stuck the weights on the inside and they catch the caliper, so without weights there is about 3-5mm clearance!
post #33 of 44 (permalink) Old 14-01-2012, 15:41
I thought tyre fitters are genius's.
Would there be any chance if you've got your wheel off at some point be able to take a couple of measurements for me as a rough guide?
cheers
mkultra is offline
post #34 of 44 (permalink) Old 15-01-2012, 15:43
Does anyone happen to know the measurement from the highest point of the caliper to the middle of the hub?
post #35 of 44 (permalink) Old 08-05-2012, 23:57
Ok confused lol! i have a rover 214si bubble with solid discs i just want to know is there a vented disc that will fit straight on without changing calipers and carriers? I have seen these which quote they fit straight on
http://www.ebay.co.uk/itm/3505168405...84.m1438.l2649.
My question is will the pads need to be sledge hammered into the calipers ?
keiths214 is offline
post #36 of 44 (permalink) Old 09-05-2012, 16:23
No there isn't. you need to fit the calipers to match the vented discs as they are MUCH wider.
post #37 of 44 (permalink) Old 13-05-2012, 19:57
Car: Mk1.5 MG ZR1.8T+, 320D Tourer, C200 Estate
Trying to fit Vented discs into a non venter caliper would be like trying to fit a VCR inside a DVD player... But for the sake of 2 bolts and a trip to the scrappy, may aswell get some vented calipers so you can get the discs!
I myself will be doing the 262 conversion for when I get my 160 lump.
The 160 doesnt really need brakes that big I've been told... And the discs and pads are alot more expensive!
And my car doesnt have ABS so it comes down to my tyres too which arent that good atm...
And I have the rear hubs off a 1.8 25 just waiting on some brake lines and H/brake cables then I will fit the rears too
Cant wait!
lukenobrains is offline
post #38 of 44 (permalink) Old 16-05-2012, 16:27
Car: 2005 Rover 25 TD SEI
With regards to a R25 diesel, if I wanted to put a set of drilled and groved 282 vented discs (for a ZR 160 off ebay), would I also need to change the calipers as well?
tony_collett16 is offline
post #39 of 44 (permalink) Old 16-05-2012, 19:23
Stu
Stu's Avatar
Yes you would.
Stu
Stu is offline
post #40 of 44 (permalink) Old 07-11-2014, 17:54
Send a message via MSN to slayvincoln
Hi
Somebody can to send me the pictures? Another forum or website I can find somewhere?
Thank you
Kind Regards
slayvincoln is offline
Upgraded Tims car to 282mm vented brakes, lots of pics Ste MG ZR / Rover 25, 200 & Streetwise 37 25-11-2008 17:38
262mm to 282mm conversion Phil MG ZR / Rover 25, 200 & Streetwise 4 31-03-2007 18:07
262mm Vented Brakes RevorTD MG ZR / Rover 25, 200 & Streetwise 3 26-01-2007 22:30
Vented front disk upgrade for a ZR-TD - will MK2 200 brakes fit? SDI_Tim Others 2 24-10-2005 07:09
262mm EBC Grooved and Drilled Brake Discs - 200/Coupe/25/ZR etc etc dj_wymo For Sale 6 14-03-2005 15:47
