Hi Guys I'm Jamie. MG TF Coolant Question. - MG-Rover.org Forums
post #1 of 5 (permalink) Old 20-03-2017, 15:40 Thread Starter
Send a message via MSN to Hamish2505
Hi Guys,
Just joined your site. I have a lovely 2004 MG TF in Solar Red. 'Ruby' is her name!! Anyway, I have just put some SS coolant pipes on her and have bled the radiator bleed point but then have gone to do the bleed nipple to the heater matrix and nothing is coming out!! I have took her for a spin and got up to temp and everything seems fine, no air locks etc and have hot air coming from the heater so cant figure out why. I presume you have to do them in order? Radiator then heater matrix then the rear pipe?
Any help would be much appreciate.
Jamie
Hamish2505 is offline
post #2 of 5 (permalink) Old 29-03-2017, 15:15
Hi Jamie Coolant Bleed procedure
Regards
Glenn.
esotericman1967 is offline
post #3 of 5 (permalink) Old 29-03-2017, 15:21
Hi Jamie...I tried to post a link but it was having none of it. Just Google 'how to bleed a mg tf coolant system' and you'll get several really good step by step guides with pictures.
Glenn.
post #4 of 5 (permalink) Old 29-03-2017, 20:44
Hi and welcome to the forum
Personally I start at the lowest point (the engine), then the rad and finally the matrix, I go round several times. There is lots of info here.
James
post #5 of 5 (permalink) Old 03-04-2017, 11:14 Thread Starter
Cheers guys, both the matrix nipple and the one above the gearbox were blocked. 13 years of cr*p!! All sorted now though. Thanks
Sorry guys another c/l question J-ZR MG ZR / Rover 25, 200 & Streetwise 6 20-08-2010 20:29
sorry guys but its lots of coolant questions :P andyseadog MG ZR / Rover 25, 200 & Streetwise 8 09-06-2010 17:42
Hi guys have a question for you House MG ZR / Rover 25, 200 & Streetwise 11 30-08-2009 16:42
Coolant: help from the wise guys please liberclavis MGF and MGTF (Sponsored by MGFnTFBITZ) 5 20-06-2009 01:03
help, coolant again guys !! aar0n MGF and MGTF (Sponsored by MGFnTFBITZ) 2 25-09-2006 13:16
