Rover 25 heater not working - MG-Rover.org Forums
post #1 of 2 (permalink) Old 18-08-2010, 18:31 Thread Starter
Hi, I have recently bought a 54 plate, 40K on the clock, Rover 25 1.4. Within a week I needed to replace the head gasket and also the water pump. Everything seemed OK, but one chilly night I tried the heater and all I have got is cold air blowing. I have read other posts and have tried to bleed the air but nothing seems to work, all the hoses seem intact no leaks, when I try and use the bleed screw I just get coolant flowing through it.
Any suggestions welcome.
DrTrciky is offline
post #2 of 2 (permalink) Old 21-08-2010, 18:22
Exclamation Heater blowing cold
Hi.
I'm new to this forum and I am not sure this is the right place for technical questions but here goes!
My wife's ZR 105 had a similar problem with only cold air from the heater. Upon checking, I found no coolant in the header tank - not a desirable thing on any engine, never mind a K series. I topped up the tank, but the next day after only 6 miles the tank was empty again. As a matter of routine I replaced the head gasket and water pump ( the parts are cheap and the procedure is straightforwards ) but the next day I found the tank to be empty again!
I took the car for a short drive and after a couple of miles I could hear something going on under the bonnet. The header tank was full to the cap with boiling coolant. The car, an 04 plate, was fitted with the later type of heater hose with the Saab pressure relief by-pass valve. This valve is supposed to open to allow coolant to flow along the by-pass hose to the thermostat when the heater valve is closed. I found that it had disintegrated internally and the rubber button inside had become detached and was totally blocking the inlet to the thermostat. On the K series engine, the thermostat depends on hot coolant flowing down the by-pass hose before it opens to allow the main coolant flow through the radiator. A blocked by-pass hose is a potentially disastrous event for the engine.
A replacement hose with the Saab valve is around 55 from Rimmer Brothers. I fixed my wifes car with the heater hose off an earlier Rover 25 without the valve from a breakers. He didn't charge me for it either as I bought some Rover 45 bits at the same time!
Your problem could be the same, as I understand that the Saab valve is unreliable. Drain the coolant and remove the valve. If you can poke a pencil or similar through it without any obstruction, it is likely that it has failed in the same way as my wife's car, and that the internal parts have worked their way towards the thermostat housing, possibly blocking the flow.
I hope this info is of use.
Best regards,
Steve
steve-d is offline
Rover 75 Heater Not Working TopGearRules MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 06-11-2016 16:30
rover 200 heater not working ramseyrover MG ZR / Rover 25, 200 & Streetwise 6 01-03-2010 10:02
Rover 200 Heater not working badgerboy MG ZR / Rover 25, 200 & Streetwise 27 08-03-2008 07:38
Rover 25 51 plate heater not working after upgrade on engine tony123 MG ZR / Rover 25, 200 & Streetwise 3 04-12-2005 07:57
rover 414si heater not working right Jem. Others 1 17-01-2005 20:09
