rover 75 v6 losing coolant - MG-Rover.org Forums
post #1 of 1 (permalink) Old 31-03-2017, 20:02 Thread Starter
Unhappy rover 75 v6 losing coolant
Hi guys havnt been on for a while as no probs with the car ,i have a 52 plate v6 petrol 49k on the clock, have had the car for 7 yrs, anyway i,m losing coolant and cant find from where ! there are no leaks in the rad or the pipes but if you look between the the 2 piston blocks there appears to be a reservoir of water laying on the casing! are there any pipes near there that could be causing the problem? there is no contamination in the oil or water so i am hopefull the head gasket is ok !any ideas ? thanks in advance tony. ------ updating the car has overheated now ! but the rads cold ! does this mean the water pump is faulty? steam seems to be coming from the left side of the engine under the alternator .
tonycee is offline
Rover 45 Losing Coolant HELP :( r0ver MG ZS / Rover 45 & 400 8 20-04-2016 11:07
Rover 75 1.8T Losing coolant and burning oil Southside MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 07-01-2012 21:47
Losing coolant, losing oil. No milkshake, no mayo. chris1987 MG ZR / Rover 25, 200 & Streetwise 4 01-12-2011 19:07
Rover 400 1.4i losing coolant!!! Er!K MG ZS / Rover 45 & 400 2 07-10-2009 16:51
Rover 216 Losing coolant Rovey MG ZR / Rover 25, 200 & Streetwise 2 14-10-2008 17:05
