Default Keyfob not turning off Immobilizer after changed case (other old key works fi - MG-Rover.org Forums
post #1 of 1 (permalink) Old 29-04-2016, 03:40 Thread Starter
Keyfob to 05 LR3 had a hole in the front. Took it apart and put board in new case as per threads on this board. It was working fine prior to switching cases. My other remote still works fine. But while the doors lock and unlock, the immobilizer circuit does not work and the LR3 will not start. As the other one works, clearly it is a problem with the key. Don't think I damaged the board removing from the old case. Anyone have suggestions on what I can try short of having the key reprogrammed? Is there any particular area I can inspect for damage to the immobilizer circuit? Thanks.
quartzsand is offline
2 button keyfob case bugsb MGF and MGTF (Sponsored by MGFnTFBITZ) 1 21-06-2013 10:24
MG ZR Keyfob only works in footwell glaw MG ZR / Rover 25, 200 & Streetwise 2 13-12-2012 21:27
changed battery in keyfob but..... chriswatton MGF and MGTF (Sponsored by MGFnTFBITZ) 7 22-02-2012 18:55
ooh no, here we go. Changed me fob case for new one, guess what happenend next mgzr wanna be MG ZR / Rover 25, 200 & Streetwise 16 15-06-2011 13:09
Rover 200 R plate keyfob not turning immobiliser off. Help! Tranzic MG ZR / Rover 25, 200 & Streetwise 2 24-01-2008 21:48
