Freelander 1.8 Coolant System Proper Job - MG-Rover.org Forums
post #1 of 2 (permalink) Old 26-10-2015, 14:33 Thread Starter
I've picked up a very cheap 2000 Freelander 1.8 with a very leaky coolant system. Since it's for the wife to drive, I want to make sure I've done all I can to avoid problems down the line while she's ab-using it!
So far I've changed all the filters, all the ignition system, new MG/Rover water pump, tensioner and belts. New thermostat - it had the external/ in the hose type already fitted. The timing marks seemed all over the place so had the head off and found it had been skimmed to within .0001 inch of its life. So, a replacement head is off to the machinists for checking/ light skim and pressure test. I've also got an alloy inlet and 52mm throttle body coming - not particularly for any performance increase, more to avoid potential trouble from the plastic intake and its rubber gasket leaking in the future.
Once it's all back together I'll do a coolant flush and change the header tank and cap too.
Is there anything else I should be thinking of doing whilst the engine is in bits?
I was going to go with the MLG from Classic Gaskets on Ebay (new head bolts etc. etc.) but am now wondering if the Payen BW gasket is a safer bet? One local 'specialist' suggested that it'll withstand a couple of overheats as opposed to the MLG breaking up the first time it happens.
The 'new' head was from a low mileage later model, so I'll need to change the cams over to drive my distributor. Should I keep the original to the car cam carrier with its cams, or keep the replacement carrier with the replacement head?
I know that I should use the original injectors rather than the VVC/ 135 spec ones.
Any thoughts appreciated.
The Docmeister is offline
post #2 of 2 (permalink) Old 13-11-2015, 08:51
The type of head gasket to use depends on the liners if they are flush with tbe block then you can only use the old type gasket if the liners are raised cant remember the tolerance but its on the mg forumthen you can use bothe types of gasket
never skim the head unless it needs it when the heads were made apparently tne surface was hardened also there is a mark on the head if that mark has gone the head has been skimmed to far and is scrap
ron
forgot to add many have found new head bolts are not upto the job I have never had to use new as the original have been well in tollarance search on line and you will find the measurements to check the old bolts before you fit new
bugsb is offline
Bodge job, or proper repair? t0m4ever MG ZR / Rover 25, 200 & Streetwise 12 01-03-2012 21:14
My first proper job done :D Sdwboss MG ZR / Rover 25, 200 & Streetwise 14 15-02-2010 17:48
Has my garage done a proper job???? amkdl MGF and MGTF (Sponsored by MGFnTFBITZ) 6 13-06-2007 21:49
Rover 214 SLi HGF, proper job. Rusty Bullet Others 8 02-09-2004 16:50
Why can't people do a proper job... apm055 MG / Rover Related Chat - up to 2005 18 06-12-2003 20:08
