Freelander 1.8 k series ! - MG-Rover.org Forums
post #1 of 4 (permalink) Old 04-06-2016, 15:11 Thread Starter
Hello
After buying a basket case 1.8 K series with half the engine in the boot decided to try and fix it!
So after a new piston,sleeve, cylinder head skim, gasket the old girl cracked up first time. Run's great,goes like **** off a stick, no over heating or coolant loss etc.. chuffed as! Except when warm every time you stop it dies and won't start for a few minutes ?? Had it ticking over for over 1hr yesterday & today, occasionaly stalled but started again.Just been out in it and at every junction dies and won't start (easily).
I have cleaned the idle control valve that seems to be working ?? but how can you tell ? Reset it by pressing throttle peddle 6 times !
No carb or points as it's an electronic ignition I'm a bit stumped ?? When you open the petrol tank there seems to be a vacuem and thought maybe fuel filter might be blocked but it runs fine until you stop ?
Changed plugs,leads checked timing about 10 times even ran it one tooth out each way from the crank timing mark and it's the same.
Connecting to a fault reader is not an option as I'm in rural France !
Thanks in advance
Jensen79 is offline
post #2 of 4 (permalink) Old 05-06-2016, 08:18 Thread Starter
Would this be better in the MG bit seeing as it's the same engine as I'm realy stuggling/stuck with this !!
Jensen79 is offline
post #3 of 4 (permalink) Old 05-06-2016, 18:06
Mmmm....Rover..
technozen's Avatar
The only fault I had that was similar to this turned out to be caused by a faulty crank sensor.
With a cold engine the sensor gave a strong output but if the sensor was warmed its output dropped, if it got very hot it had virtually no output.
technozen is offline
post #4 of 4 (permalink) Old 05-06-2016, 18:18 Thread Starter
Thanks for that ! Well worth checking !
Jensen79 is offline
Freelander 1.8 K Series theroyalkit Land Rover 2 06-09-2010 20:40
Freelander series 1 - would you or not? SimonDH Land Rover 17 04-06-2009 12:32
K series engine for MG ZT or Freelander tangerinewizard Wanted 0 27-06-2007 11:37
K series engines and Freelander FSU MGF and MGTF (Sponsored by MGFnTFBITZ) 3 13-02-2007 15:51
Freelander K-Series Orion Land Rover 5 01-12-2003 12:54
