Freelander 2 Haldex ECU question - MG-Rover.org Forums
post #1 of 4 (permalink) Old 31-03-2016, 12:29 Thread Starter
I'm thinking of adapting a few things to do with the Haldex 4x4 computer on a Freelander 2 but need to know how it wires up to the car.
Does the haldex ECU connect to the Engine ECU or does it run independently via a 12V source and transmission sensors?
If it doesn't, does anyone have any photos of the connections so I have an idea of what I would need in terms of loom.
The job is going to be transplanting the Haldex system onto another vehicle so I need to know if the Engine ECU needs to be compatible or whether it just runs off fitted sensors and it's own brains.
Also whilst we're here, does anyone know if the rear differential runs as an open diff or an LSD. I know the Haldex is a plate clutch system but given the Freelander's 90/10 power split I'm not sure they would have fitted an LSD to the rear box or not.
If not are there ways of fitting one if required?
Thanks in advance, I know these aren't run of the mill questions like "how do I change my oil?".
Finding suitable technical docs is proving to be a bit difficult.
Stargatemunky is offline
post #2 of 4 (permalink) Old 01-04-2016, 10:56
A quick google found this, not sure if this is what your looking for.
SQS Racing | Haldex Regulator
PaulTF is offline
post #3 of 4 (permalink) Old 05-04-2016, 20:18 Thread Starter
That would be useful to implement but it doesn't quite answer what I need to know which is if the Haldex system is independent of the Engine ECU or whether it requires input to operate.
If it doesn't then I can install a mechanical Torsen C but it would make life easier as I can fit the Haldex with a rear diff already with it saving cost and time.
I don't want to install a permanent central locking diff if I can help it due to various power distribution reasons but it's an option if it comes to it. Though the more I read of it the more useful it seems.
Also I could make a pressure switch like that for about 5 not 200
Who are they trying to kid?
post #4 of 4 (permalink) Old 21-02-2017, 14:21
Did you find enough info on this as I do have a workshop manual for the Freelander 2
Clive
Mgwanderer is offline
Freelander 1.8, fobs and ecu GazW Land Rover 0 22-11-2011 20:08
just quick freelander question paddydel Land Rover 1 13-11-2010 12:03
Question about using a Freelander MAF in a 75... Voyager Diesel Forum! 2 27-10-2009 06:04
freelander question pault100 Land Rover 5 30-12-2008 10:13
Help Rover To Freelander Ecu bandit600 Diesel Forum! 6 23-03-2007 12:49
