Freelander 2 - window problem advice - MG-Rover.org Forums
post #1 of 4 (permalink) Old 11-02-2011, 09:23 Thread Starter
Car: MG ZT+ CDTi 135
Exclamation Freelander 2 - window problem advice
Technical advice required please:
2007 Freelander 2 HSE Td4
Front passenger side electric window - when you raise the window to close it it will then automatically power down to 2/3 open. You can close the window by using the switch to gradually close it in short stages.
Does it from NS door switch and drivers (OS) door switch.
Any advice would be welcomed.
I have to add this is the first problem I have had with the car since new - but as usual the warranty has recently expired. The two Freelanders before that also had no problems.
AL
Doh! - don't know how I managed to post in Website feedback - I would be grateful if Mods could move to Landrover section!!!!
Alastair is offline
post #2 of 4 (permalink) Old 12-02-2011, 01:03
Send a message via AIM to Ex-MG Send a message via MSN to Ex-MG
Sounds like a faulty motor or regulator, get it checked out at a garage or the dealer.
Ex-MG is offline
post #3 of 4 (permalink) Old 12-02-2011, 12:56 Thread Starter
Talking
Thanks for the reply Steven.
I did a bit of research and the answer turned out to be in the owners Manual. There is a re-set/overide procedure - you try and close the window 3 times and on the 3rd time you hold the up switch for 10 second and all is sorted.
One to note for other owners and a reminder for me to RTBM :-)
Probably caused by opening the window when iced up. Freelander is back to 100% reliability over 3 years - not bad me thinks.
AL
Alastair is offline
post #4 of 4 (permalink) Old 13-02-2011, 01:54
AL
Glad it's sorted .
Ex-MG is offline
Freelander Rear Window Problem Tomredd Land Rover 9 17-12-2009 07:51
Freelander 1 rear window marinabrian Land Rover 8 13-05-2009 23:23
Window/door frame problem - Advice needed Hazkirby MG ZR / Rover 25, 200 & Streetwise 2 14-05-2008 08:14
passenger elec window problem - any advice? lighty07 MGF and MGTF (Sponsored by MGFnTFBITZ) 12 28-07-2007 13:22
Land Rover Freelander electric window jammed eddiesolo Land Rover 4 25-06-2007 15:38
