Freelander k series turbo conversion - MG-Rover.org Forums
post #1 of 36 (permalink) Old 12-01-2014, 21:19 Thread Starter
I'm looking at a few possibilities for a project and thought of the Freelander and as the title says maybe a Turbo. I have checked and can't find any info or anyone who has done it, can't say i have even looked under the bonnet of one but assume plenty of space. I would probably go for an early (read cheap) one so wondered what year mems3 was used so could go with a Z&F remap, anyone done a mems3 conversion, what sort of power can the drivetrain handle, as you can see loads of questions anyone have any answers.
PaulTF is offline
post #2 of 36 (permalink) Old 15-01-2014, 02:57
my first thought when i saw your post was..."if a k series struggles to keep its head gasket together as std how the hell will it stand the pressures a turbo will produce"
my 2nd thought was..."good luck...you may need it"
xamtex is offline
post #3 of 36 (permalink) Old 15-01-2014, 06:46
Trader Supporter
Kmaps's Avatar
Car: MG ZT, MG ZT-T, TF, ZR 1.8 Turbo
The k series gasket issue is down to thermal stresses on the engine
i.e the cooling system is the culprit rather than cylinder pressures.
a 270Nm remapped turbo might be pretty useful in a Freelander..
Kmaps is offline
post #4 of 36 (permalink) Old 15-01-2014, 10:11 Thread Starter
That was my reasoning, turbo grunt Rather than revs just not sure what the drive train can safely handle and as said the k turbo is fine if used within its limits
PaulTF is offline
post #5 of 36 (permalink) Old 15-01-2014, 20:48
Car: Rover 75 Tourer
I looked into doing the same thing a while ago. From research and word of mouth, i'd be more worried about the HG than drive train. There is a KV6 version of the Freelander which will be putting the same torque out as the Z&F turbo map.
Rudder is offline
post #6 of 36 (permalink) Old 15-01-2014, 21:10
Car: MG ZS 120 mk2
People have done this to ZR and ZS's using standard 75/ZT parts and re-mapped ECU's.
Also allot of Freelanders have the PRT thermostats which reduce thermal shock.
Could always an oil cooler.
galley.r25 is offline
post #7 of 36 (permalink) Old 17-01-2014, 10:17 Thread Starter
Just found out that the Freelander changed to MEMS3 in 2001 so if i go for this looks like i need an 01 onwards so save a lot of hassle
PaulTF is offline
post #8 of 36 (permalink) Old 18-01-2014, 14:46
Car: 618IS silver bullet
stick a t series in it?
LOONEY666 is offline
post #9 of 36 (permalink) Old 19-01-2014, 15:32 Thread Starter
I did actually think of that, would have to use an early L series Freelander gearbox so very do able, also looked at converting the V6 to manual which would make an excellent motor but i think turboing the K series is a much more straight forward job and something i can't find that anyone has done before
PaulTF is offline
post #10 of 36 (permalink) Old 20-01-2014, 18:44
i hear you and i had a 414i k series a hammered it all over for 3 months red lined it broke gear box mount speed stopped working even a crash 100% not my fault only did this sort of abuse on private land anyway the thing never died didnt miss a beat dust getting me hooked on rovers. every one said it would blow red lined it for a full 5mins still nothing but 50/50 and if you make the uprated gasket and rethink and upgrade the cooling maybe even over kill on the cooling it may be a good engine when turbo'd
post #11 of 36 (permalink) Old 22-01-2014, 17:38
Why? they made a turbo k series.. and still pretty much do. just make sure you can keep the thing cool and you wont have any problems.
Forrestt is offline
post #12 of 36 (permalink) Old 24-01-2014, 19:48 Thread Starter
Found out some more info, the fuel system on the Freelander is the same as the 75/ZT 1.8 turbo ie it does not have a fuel return to the tank so I'm assuming the compete turbo engine and inlet manifold will bolt straight in. Also the fuel pressure is 3.5 bar, is that sufficient to run the turbo lump.
PaulTF is offline
post #13 of 36 (permalink) Old 24-01-2014, 20:42
Car: zr tdi 180
Go for it the most simple conversion you could ever do its litrially the same as an engine change with changing a few bits, sorting out the down pipe, getting the ecu done and doing the pipe work for the intercooler simple But I would use the gear train out of the v6 as it is uprated a fair amount for the extra torque the gear box Is the same apart from the final drive is increased in the v6 but the transfer box is uprated a great deal in the v6.
zr-td-nutters is offline
post #14 of 36 (permalink) Old 24-01-2014, 22:04
Car: Mk1.5 MG ZR1.8T+, 320D Tourer, C200 Estate
The V6 box wont mount to the K series.. An ordinary PG1 will take all the torque a K turbo can throw at it, and then some.
lukenobrains is offline
post #15 of 36 (permalink) Old 25-01-2014, 07:45 Thread Starter
The KV6 in the freelander only came with an auto box, which is shame as i think a manual version would have been excellent. What needs to be done with the wireing to fit the turbo lump as i want to start sorting all the bits and pieces out first as its going to be a while before i buy the car
PaulTF is offline
post #16 of 36 (permalink) Old 25-01-2014, 17:51
Car: 2000 Rover 75 v6 2.0 Club SE Dorchester Red
I'd be more concerned about the condition of the viscous coupling, ird and rear diif, they need to be decent especially the vc
Marcel Wave is offline
post #17 of 36 (permalink) Old 25-01-2014, 18:06
Car: zr tdi 180
This is why I said the gear train e.g the Transfer bx etc. And There are a fair few manual v6 free lander's Many have been converted and I think some ex demo cars came with manual ones.
post #18 of 36 (permalink) Old 25-01-2014, 18:34
true you did mention the ird but a worn vc can wreck both the diff and ird, it would be a massive shame to see a good idea like dropping a turbo in a hippo if the vc wasn't up to scratch. I had half a mind to try a vvc lump once but i read the engine management would be a problem.
post #19 of 36 (permalink) Old 26-01-2014, 05:31
Trader Supporter
Kmaps's Avatar
We have already supplied an upgraded ecu for a vvc Freelander, the set up is quite simple
Kmaps is offline
post #20 of 36 (permalink) Old 26-01-2014, 10:55 Thread Starter
Do you have any links or further info on the manual conversions as I've scoured the net and not found any trace of one that's been done, be interested to see what's involved.
PaulTF is offline
K Series turbo conversion for MG ZR (How tricky is it?) tabor MG/R Modification & Tuning 3 21-09-2013 21:04
1.8K series Turbo conversion kit pengy_666 For Sale 41 03-02-2013 12:08
MG ZR k series VVC turbo conversion Ian Roberts MG/R Modification & Tuning 6 20-12-2011 10:56
Removal of Turbo freelander 2.00 L series ? Travellers Land Rover 1 15-11-2011 17:23
300bhp K-series turbo conversion. CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 23 07-07-2009 19:31
