Freelander leaking water please help!!!! - MG-Rover.org Forums
post #1 of 9 (permalink) Old 29-09-2010, 14:24 Thread Starter
Hi everyone
my dad has a 1999 Freelander and he is having a problem with it leaking water as it only seems to leak when the engine is cold when he is topping the water up but after it has been running a few mins it don't seem to be leaking at all so it is very confusing as the temp gauge is as it suppose to be so we dont no what it could be so if you have had the same problem or could suggest what it could be reply to the thread cheers would really apprecaite it
wolle18 is offline
post #2 of 9 (permalink) Old 29-09-2010, 15:59
Car: MGF Lucifer & Ford Clitoris
Send a message via MSN to The Jester
what model is it......?
im looking at purchasing one so asking questions myself
but your dads problem could be the water pump if its the 1.8 petrol as its the same engine as mgf
when the engine goes cold things contract thus the leak....can you source roughly where its coming from?
see this thread if water is leaking from the same area (again its same engine if petrol 1.8)
Is My Water Pump Leaking
if its a diesel or not from same area ignore everything ive just said...just trying to help lol
The Jester is offline
post #3 of 9 (permalink) Old 29-09-2010, 16:16 Thread Starter
yeh mate it is a 1.8 and i changed the cam belt and water pump last week and cant be leaking from there as the water seems to be on the other side and at the back but true it could be threw contracting but cant seem to source the leak lol
wolle18 is offline
post #4 of 9 (permalink) Old 29-09-2010, 19:24
Mmmm....Rover..
technozen's Avatar
Sounds like the inlet manifold gasket.
technozen is offline
post #5 of 9 (permalink) Old 29-09-2010, 23:19 Thread Starter
thanks for the reply technozen but its not leaking right at the front of the engine its like at the back below the injection thingy and below the camshaft oil seals near the air filter
wolle18 is offline
post #6 of 9 (permalink) Old 30-09-2010, 08:03
Mmmm....Rover..
technozen's Avatar
Err, the "injection thingy" is the inlet manifold.
It's gasket is known to perish which results in external coolant leaks and internal leaks into cylinders 1 and 4.
post #7 of 9 (permalink) Old 30-09-2010, 11:50 Thread Starter
o i see mate but the injection thing i mean is where the throttle body onnects to is its under there where the water is or seems to be coming from
wolle18 is offline
post #8 of 9 (permalink) Old 30-09-2010, 19:33
Mmmm....Rover..
technozen's Avatar
The manifold gasket was changed in production because of it's tendency to leak, the older type gasket was black, the modified type is green.
It's hard to know which type is fitted to yours although I have seen the modified type leaking!
This thread covers the gasket replacement....
How do I - change Inlet manifold gasket? (K Series)
post #9 of 9 (permalink) Old 01-10-2010, 17:19 Thread Starter
thank you mate i think you is right with saying it was the gasket so picked one up and will fit it hopefully 2moz hope that stops the leaking thanks agen mate
wolle18 is offline
leaking water? help! bam2009bino Metro / Rover 100 5 12-08-2009 15:59
Leaking Water CARLT MGF and MGTF (Sponsored by MGFnTFBITZ) 14 10-10-2008 14:29
Water droplets under Oil Filler Cap but I have the freelander gasket?! trancera MG ZR / Rover 25, 200 & Streetwise 22 12-07-2007 22:22
leaking water zsgav28 MG ZS / Rover 45 & 400 1 19-05-2007 20:12
leaking water msd26179 MG ZR / Rover 25, 200 & Streetwise 2 10-03-2007 16:38
