Maf unit on freelander - MG-Rover.org Forums
post #1 of 13 (permalink) Old 13-04-2015, 18:44 Thread Starter
Car: freelander mk1
hi all.
hello all. I am not a rover driver but my power plant is rover as in the rover l series 2.0 di. I have most of the mods that you can do on the engine and am very happy with what im getting out of the Freelander now. there is one mod that you have said about I cant get my head around now as I have only 4 wires and you all say bridge 1and5. can any one help on this. it is the bridging of the MAF unit on the Freelander. my wires start 2.3.4.5 no number (1). yours colin.
freelander col is offline
post #2 of 13 (permalink) Old 13-04-2015, 19:19
220coupe's Avatar
Car: BMW 1 Series Sport
Post moved.
Mike
220coupe is offline
post #3 of 13 (permalink) Old 13-04-2015, 20:14
Originally Posted by freelander col View Post
hi all.
Freelander with the L series doesn't use the MAF sensor to control the fuelling. It is the same (but slightly different) setup as in the 200/400/600 intercooled L series diesels.
Best performance mod for these is a TU1/garf/evry mod to up the fuelling and manually wind the boost up a little. 19psi is the usual max level.
post #4 of 13 (permalink) Old 13-04-2015, 20:40 Thread Starter
Car: freelander mk1
ok and thanks. psi is at 19 and happy with that just wondered about the bypass mod but as Freelander they don't do things simple.
post #5 of 13 (permalink) Old 13-04-2015, 22:25
Evry Mod is very simple to do and makes a HUGE difference to driveability. Worth looking at in my opinion.
The freelander also doesn't rely on the MAF for fuelling so it is a LOT more reliable.
post #6 of 13 (permalink) Old 14-04-2015, 11:44 Thread Starter
Car: freelander mk1
thank you for reply. I have done most of the mods and I am happy with what I am getting from the Freelander and fuel is still good on her. I have done the egr bypass and the dcat as well moved the pump timing a bit and put a cone filter on as well. at the moment in in progress of doing the intercooler pipes but as it is the Freelander I cant use the rover upgrade pipes so sorting it out myself with new rubbers and aluminium pipes.
post #7 of 13 (permalink) Old 14-04-2015, 13:22
You only get a good performance benefit from upping the fuelling. Trust me you'll be glad you did!
post #8 of 13 (permalink) Old 14-04-2015, 15:49 Thread Starter
Car: freelander mk1
im happy with the top end power as she runs all day long at 80/85 and I have some power lefted if I need it she only slow on tack off witch made wonder about maf bypass. as for top end more power and then I need more stopping power to slow down.
post #9 of 13 (permalink) Old 14-04-2015, 16:08
MAF sensor is not used for fuelling control on yours. You can unplug it and remove it entirely if you don't believe me. It'll make no difference to the running of the hippo
Evry mod makes a HUGE difference to drivability making towing much much easier. My 600 will happily tow a car trailer with another 600 on it. (not legally in the UK but it'll happily do it).
post #10 of 13 (permalink) Old 14-04-2015, 21:09 Thread Starter
Car: freelander mk1
what is the best may to up the fuelling and is it a diy job or specialist job ????
post #11 of 13 (permalink) Old 15-04-2015, 13:52
DIY certainly possible just a few wires and resistors. Dasterly Dan will be along shortly I'm sure as he has just got himself a hippo and already done the mod so he can confirm the wiring colours.
Whereabouts are you in the world?
post #12 of 13 (permalink) Old 23-04-2015, 17:07 Thread Starter
Car: freelander mk1
sorry been a bad time as car problems but all done now and back on the road. as for where I am in in Kingsbridge devon.
post #13 of 13 (permalink) Old 08-07-2015, 11:45
Car: R45 TD
will admit, I don't usually look in this area (I considered it a "dead" area tbh) hence how I've missed this
from memory, It's the yellow/black wire, and the red wire. Fit a 2k variable resistor across the two, and sit it inside the car for easy adjustment. I've found once you've got it set, you never really need to touch it again
Dastardly-Dan is offline
2000 1.8 freelander alarm/fob unit wolle18 Land Rover 1 20-12-2014 20:34
freelander maf function crislander Diesel Forum! 6 24-09-2013 07:55
Rover 800 / Freelander Light Unit users! Aden MG ZR / Rover 25, 200 & Streetwise 12 11-07-2012 06:52
freelander ird unit stevejb Land Rover 0 27-02-2010 20:13
Question about using a Freelander MAF in a 75... Voyager Diesel Forum! 2 27-10-2009 06:04
