no compression - MG-Rover.org Forums
 7Likes
  • 1 Post By E_T_V
  • 1 Post By Roverdose
  • 1 Post By JOHNDQ
  • 1 Post By barkingdog
  • 1 Post By coalman
post #1 of 12 (permalink) Old 12-07-2016, 22:36 Thread Starter
no compression
i have a freelander 1.8 which has had the head skimmed and replaced due to hgf but there was no compression on building back up so took the head off and put another gasket on and rebuilt it but still no compression! took the hydrolic tappets out and refilled them with new oil and replaced them still nothing! im at my wits end and tomorrow will try a tow as the last resort as ive been told it can help get the compression back ! any advice would be appreciated thanks
bigrab22 is offline
post #2 of 12 (permalink) Old 12-07-2016, 23:46
Belt timing correct?
Have the tappets been stored the wrong way up?
bigrab22 likes this.
post #3 of 12 (permalink) Old 13-07-2016, 05:48
Car: MG ZS180 :D
Why/how have you filled the tappets with oil? Take the cam cover off turn the engine by hand to get cylinder 1 at tdc. Look at the cam lobes on cyl 1. The lobes should be pointing away from each other slightly downwards. If not turn the engine over by hand 180 degrees so cyl 1 is at tdc again and take another look.
Sent from Drew @ Roverdose
Roverdose is offline
post #4 of 12 (permalink) Old 13-07-2016, 06:24
Did you remove the camshaft wheels?
JOHNDQ is offline
post #5 of 12 (permalink) Old 13-07-2016, 10:48
Woof Woof
Squirt some oil into the bores and see if the compression returns.
barkingdog is online now
post #6 of 12 (permalink) Old 13-07-2016, 21:45
Car: Rover 620 gsi
Timings 180 degrees out
coalman is offline
post #7 of 12 (permalink) Old 14-07-2016, 16:37 Thread Starter
the tappets have been taken out drained and refilled (a 2 hour job) the timing has been set bang on by a mechanic we even towed the car to see if that would help but still not a peep not even moving the tester needle!
bigrab22 is offline
post #8 of 12 (permalink) Old 14-07-2016, 16:38 Thread Starter
been stripped down for a head skim and rebuilt and set up spot on by my friend who is a mechanic
bigrab22 is offline
post #9 of 12 (permalink) Old 14-07-2016, 17:08
Car: MG ZS180 :D
Take the cam cover off. Get it to tdc on cyl 1. Take a pic of the cam lobes
coalman likes this.
post #10 of 12 (permalink) Old 03-08-2016, 13:47
Car: Rover 620 gsi
No pics so we can assume it's either sorted or cubed
coalman is offline
post #11 of 12 (permalink) Old 03-08-2016, 15:15
Car: MG ZS180 :D
Realised it 180 degrees out
coalman likes this.
post #12 of 12 (permalink) Old 24-09-2016, 13:48
Car: Classic MG
Anyone know a good, reliable independent shop in the KC or mid-west area?
kaufen is offline
compression creon Diesel Forum! 4 07-04-2012 21:13
what should the compression be on a zr 1.4 rich30mex MG ZR / Rover 25, 200 & Streetwise 5 21-12-2009 19:08
No compression marts66 MG ZS / Rover 45 & 400 4 16-04-2009 17:54
compression gone. please help Safrican Others 21 23-02-2006 22:20
Compression Rusty Bullet Others 7 14-03-2005 17:07
